    RepRapFirmware 3.0RC2 now available
    Beta Firmware
    11
    39
    3.0k
      I've just published this release at https://github.com/dc42/RepRapFirmware/releases/tag/3.0RC2. The change list and upgrade notes are at https://github.com/dc42/RepRapFirmware/blob/v3-dev/WHATS_NEW_RRF3.md.
      • denkeundefined
        denke
        Trying to update from :
        Board: Duet WiFi 1.02 or later
        Firmware: RepRapFirmware for Duet 2 WiFi/Ethernet 3.0RC1 (2019-12-16b8)
        Duet WiFi Server Version: 1.23
        Duet Web Control 2.0.4
        to this release, but I get:
        "Error: In-application programming binary "Duet2CombinedIAP.bin" not found".
        I can see the thread https://forum.duet3d.com/topic/13401/cant-change-from-v3-0-to-v2-05-missing-file
        So I added "Duet2CombinedIAP.bin" from 3.0RC1 is this OK? is this normal? If so, could you please add the "compatible IAP" to the release notes? Or is this a one time thing and we don't have to worry about it anymore?
        Thanks!
        • nraynaudundefined
          nraynaud
          Hi, thanks for your work,
          I seem to have an issue with this RC that I didn't have with beta12 (I skipped RC1).
          The issue is that the homing of Y is blocking :
          ; homey.g
          ; called to home the Y axis
          ; generated by RepRapFirmware Configuration Tool on Wed Nov 15 2017 23:36:04 GMT-0700 (MST)
          ; Lift Z relative to current position
          G91
          G1 Z2 F6000
          G90
          M117 Z hop
          ; M98 P"outdanger.g"
          M117 after outdanger
          ; Move quickly to Y axis endstop and stop there (first pass)
          G53 G1 Y-415 F10000 H1                                    ;     <---@@@@@@@@@@@@@@@ BLOCKS HERE
          M117 coarse endstop
          ; Go back a few mm
          G91
          G1 Y3 F6000
          G90
          ; Move slowly to Y axis endstop once more (second pass)
          G53 G1 Y-415 F360 H1
          G53 G1 Y2 F10000
          ; Lower Z again
          G91
          G1 Z-2 F6000
          G90
          the web interface shows 'Idle' but subsequent commands don't seem to execute, upon editing, homey.g fails to save because it's locked.
          Clicking the endstop manually doesn't unlock the situation.
          I would like to activate some logs to help with diagnostics, could you guide me on using M111 please?
          here is my endstop configuration (had to change it to satisfy the disparition of S0 in M574) :
          M584 X0 Y1 Z3:4 E9:8 W5
          M208 S1 X0 Y0 Z0 W0  ; Set axis minima
          M208 S0 X415 Y340 Z295 W1000 ; Set axis maxima
          M574 S1 X1 P"!^xstop"
          M574 S1 Y1 P"!^ystop"
          M574 S1 Z1 P"!^zstop+!^e0stop"
          M574 S1 W1 P"!duex.e2stop"
          M569 P3 S0 ; Drive 3 goes backwards
          M569 P5 S1 ; Drive 5 direction
          M569 P6 S1 ; Drive 5 direction
          M350 X16 Y16 Z16:16 E16:16 I1 S3; Configure microstepping with interpolation
          M350 W16 I1 S3; micro-stepping
          M92 X320 Y320 Z1600:1600 S64 ; Set steps per mm
          M92 E100:100 S4;
          M92 W10 S1;
          M906 X1000 Y1000 Z800 E800:800 I50 ; Set motor currents (mA) and motor idle factor in per cent
          M906 W1000 I50; current
          M84 S10 ; Set idle timeout
          M915 XY S10 F1 R2 ; stall detection
            1. Please run M98 P"config.g" to see if there are any error messages, especially relating to endstop configuration.
            2. Use M119 to test the endstops.
            3. Otherwise, the only thing I can see that is unusual is that you are using a G1 H1 move in absolute coordinate mode and with a G53 prefix. G1 H1 moves should normally be done in relative coordinate mode (G91), which makes the G53 prefix redundant. But I would not expect this combination to cause a lock-up.
              Phaedrux Moderator @denke
              @denke said in RepRapFirmware 3.0RC2 now available:
              It is in the upgrade notes of RC1.
              You should also upload the new IAP file for your system. You will need it when upgrading firmware in future. These files are called Duet2CombinedIAP.bin, DuetMaestroIAP.bin, Duet3_SBCiap_MB6HC.bin (for Duet 3+SBC) and Duet3_SDiap.bin (for Duet 3 standalone systems). You can leave the old IAP files on your system, they have different names and you will need them if you downgrade to earlier firmware.
              • nraynaudundefined
                nraynaud
                Thanks for your help.
                1. ouch, that reboots the duet, I probably did something very bad.
                  here is my log after a few tries:
                18:28:44: Connection established!
                18:28:43: Disconnected.
                18:24:52: Connection established!
                18:24:51: Disconnected.
                18:24:38: Connection established!
                18:24:35: Disconnected.
                I don't even get the acknowlegement of the M98 in the logs
                here is my config.g:
                ; Configuration file for Duet WiFi (firmware version 1.17 to 1.19)
                ; customized by hand
                M80
                M111 S0 ; Debugging
                G21 ; Work in millimetres
                M555 P2 ; Set firmware compatibility to look like Marlin
                M669 K1 ; switch to CoreXY mode
                M98 P"configmotors.g"
                ; PROBE
                M558 P5 I1 H3 F400 T2000 A5 ; Set Z probe type to switch, the axes for which it is used and the dive height + speeds
                G31 P600 X-35 Y-10 Z0.40 ; Set Z probe trigger value, offset and trigger height
                M557 X20:380 Y20:380 S20; Define mesh grid
                ; speed planning
                M566 X100 Y100 Z100 E300 W300; Set maximum instantaneous speed changes (mm/min)
                M201 X4000 Y2500 Z1500 E2000 W1000 ; Set per axis accelerations (mm/s^2)
                M204 P4000 T12000 ; Set global accelerations (mm/s^2)
                M203 X35000 Y35000 Z10000 W5000 E10000 ; Set maximum speeds (mm/min)
                ;   BED
                M308 S0 P"bedtemp" Y"thermistor" T100000 B3950 ; configure bed thermistor
                M950 H0 C"bedheat" T0 ; configure bed heater
                ;   HEATER 1
                M308 S1 P"e0temp" Y"thermistor" T100000 B4388 C7.06e-8 ; define tool0 temperature sensor
                M950 H1 C"e0heat" T1 ; heater 1 uses the e0_heat pin and sensor 1
                M143 H1 S280 ; Set temperature limit for tool0 to 280C
                ;   HEATER 2
                M308 S2 P"duex.e5temp" Y"thermistor" T100000 B4388 C7.06e-8 ; define tool1 temperature sensor
                M950 H2 C"duex.e5heat" T2 ; tool1 heater
                M143 H2 S280 ; Set temperature limit for tool1 to 280C
                M950 F1 C"duex.fan7"; fan1 is tool0 cooling
                M950 F2 C"fan1"; fan2 is tool1 part cooling
                M950 F3 C"duex.fan5"; fan3 is tool1 cooling
                ; Tool 0
                M563 P0 D0 H1 S"T0 (0.6mm)"; Define tool1
                G10 P0 L1 X0 Y0 Z-1.4 ; Set tool 0 axis offsets
                M106 P1 S0 T70:120 H1 L120 ; Set fan
                ; M572 D0 S0.4 ; pressure advance
                ; M591 D0  P2 C9 S1; filament sensor
                ; M591 D0 P7 C"e1_stop" S1 L1.76 A1 E34 R70:200 ; encoder sensor
                ; Tool 1
                M563 P1 D1 H2 F2 S"T1 (0.4mm)"; Define tool1
                G10 P1 L1 X-2.5 Y2.5 Z-1.4 ; Set tool 1 offsets
                G10 P1 R0 S0 ; Set initial tool 1 active and standby temperatures to 0C
                M106 P3 S0 T70:120 H2; Set tool cooling fan
                ; M572 D1 S0.2 ; pressure advance
                ; Tool 2
                M563 P2 S"T2 (empty)"; Define tool2
                M550 Panycubic ; Set machine name
                M552 S0 ; awaken wifi module and set to idle
                ; <snip>
                M552 S1 ; connect the wifi module to the network
                M586 P0 S1 ; Enable HTTP
                M586 P1 S0 ; Disable FTP
                M586 P2 S0 ; Disable Telnet
                M564 H0 ; allow movement of un homed axes
                M207 S3.0 R0.3 F60 T200
                M501 ; read saved config (PID coefficients)
                G0 F40000 ; set travel speed
                here is configmotors.g:
                M92 E100:100 S4;
                M92 W10 S1;
                here are a few version strings:
                Firmware Name:	RepRapFirmware for Duet 2 WiFi/Ethernet
                Firmware Electronics:	Duet WiFi 1.02 or later + DueX5
                Firmware Version:	3.0RC2 (2019-12-29b1)
                Web Interface Version:	1.22.6
                1. in the web interface the Y switch status display changes in sync with me pushing on it manually, it looks fine.
                2. My homing is in G53 because my home switch senses the tool holder not the tool tip, and every tool has a different offset ( https://www.thingiverse.com/thing:4010872 some mechanical context here ). I felt like I was skipping steps so I re-home after every tool change, but I see in the RC2 release notes that there was a bug of position after tool changes, so it might be something else.
                dc42undefined Phaedruxundefined 2 Replies Last reply Reply Quote 0
                  dc42 administrators @nraynaud
                  @nraynaud said in RepRapFirmware 3.0RC2 now available:
                  Please post the result of running M122 after it has rebooted due to running that command.
                  nraynaudundefined 1 Reply Last reply Reply Quote 0
                    Phaedrux Moderator @nraynaud
                    Shouldn't this be 2.0.4?
                    nraynaudundefined 1 Reply Last reply Reply Quote 1
                    • nraynaudundefined
                      nraynaud @dc42
                      @dc42 said in RepRapFirmware 3.0RC2 now available:
                      M122
                      I see the software got afraid of the boss, here is my log now (I don't think I changed anything, probably a race condition):
                      19:24:18M122
                      RepRapFirmware for Duet 2 WiFi/Ethernet version 3.0RC2 running on Duet WiFi 1.02 or later + DueX5
                      Board ID: 08DDM-9FAM2-LW4SD-6JKD4-3S46L-92X3W
                      Used output buffers: 3 of 24 (16 max)
                      Static ram: 30516
                      Dynamic ram: 93164 of which 44 recycled
                      Exception stack ram used: 256
                      Never used ram: 7092
                      Tasks: NETWORK(ready,640) HEAT(blocked,1240) DUEX(suspended,160) MAIN(running,3668) IDLE(ready,156)
                      Owned mutexes:
                      Last reset 00:08:29 ago, cause: software
                      Last software reset at 2019-12-29 19:15, reason: User, spinning module GCodes, available RAM 7100 bytes (slot 1)
                      Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0041f000 BFAR 0xe000ed38 SP 0xffffffff Task 0x4e49414d
                      Error status: 0
                      Free file entries: 10
                      MCU temperature: min 35.1, current 35.4, max 36.0
                      Supply voltage: min 24.0, current 24.1, max 24.3, under voltage events: 0, over voltage events: 0, power good: yes
                      Driver 5: standstill, SG min/max not available
                      Driver 6: standstill, SG min/max not available
                      Driver 7: standstill, SG min/max not available
                      Date/time: 2019-12-29 19:24:16
                      Cache data hit count 1397321660
                      Slowest loop: 128.51ms; fastest: 0.10ms
                      Hiccups: 0(0), FreeDm: 169, MinFreeDm: 169, MaxWait: 0ms
                      === MainDDARing ===
                      === AuxDDARing ===
                      Segments left: 0
                      Movement lock held by null
                      http is idle in state(s) 0
                      telnet is idle in state(s) 0
                      file is idle in state(s) 0
                      serial is idle in state(s) 0
                      aux is idle in state(s) 0
                      daemon is idle in state(s) 0
                      queue is idle in state(s) 0
                      Code queue is empty.
                      === Network ===
                      Slowest loop: 200.23ms; fastest: 0.00ms
                      Responder states: HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0)
                      HTTP sessions: 1 of 8
                      - WiFi -
                      Network state is running
                      Failed messages: pending 0, notready 0, noresp 1
                      WiFi firmware version 1.23
                      WiFi MAC address 60:01:94:34:3b:19
                      WiFi Vcc 3.37, reset reason Turned on by main processor
                      WiFi flash size 4194304, free heap 24312
                      WiFi IP address 192.168.0.28
                      WiFi signal strength -59dBm, reconnections 0, sleep mode modem
                      19:22:24Connection established!
                      19:22:23Disconnected.
                      19:22:15M98 P"config.g"
                      Error: M558: Missing Z probe pin name(s)
                      Error: G31: Invalid Z probe index
                      all of a sudden it spits the error message. I'll look at the documentation, the error was probably here before.
                      • nraynaudundefined
                        nraynaud @Phaedrux
                        @Phaedrux I am using the old page at /reprap.htm# it's more confortable and shows more things for diagnostics.
                        @dc42 actually after commenting M558 and G31 I still get the reboot:
                        19:32:11M122
                        Used output buffers: 1 of 24 (17 max)
                        Static ram: 30516
                        Tasks: NETWORK(ready,640) HEAT(blocked,1240) DUEX(suspended,160) MAIN(running,3676) IDLE(ready,156)
                        Owned mutexes:
                        Last reset 00:00:46 ago, cause: software
                        Last software reset at 2019-12-29 19:31, reason: User, spinning module GCodes, available RAM 7432 bytes (slot 0)
                        Error status: 0
                        MCU temperature: min 34.3, current 35.7, max 36.2
                        Date/time: 2019-12-29 19:32:09
                        Cache data hit count 105424755
                        Slowest loop: 128.25ms; fastest: 0.09ms
                        === MainDDARing ===
                        === AuxDDARing ===
                        Segments left: 0
                        === Network ===
                        Slowest loop: 116.61ms; fastest: 0.00ms
                        - WiFi -
                        WiFi flash size 4194304, free heap 24608
                        WiFi signal strength -60dBm, reconnections 0, sleep mode modem
                        19:32:06Connection established!
                        19:32:05Disconnected.
                        19:31:41Connection established!
                        19:31:41Page Load complete!
                        I deny that this reboot was directly asked by me, I don't see any reboot command in my files, and it is the result of the M98 P"config.g"
                          It's not requested by you, the diagnostics make that clear. Can you pin down which line causes the reboot? For example, take a copy of config.g, and delete about 50% of the lines at the end of the copy. Then use M98 to run that copy. If it still crashes, delete 50% of the lines remaining at the end; otherwise reinstate some lines that you deleted. Then try again, and so on.
                          • nraynaudundefined
                            nraynaud
                            thanks for your help, I'll start right now.
                            • nraynaudundefined
                              nraynaud
                              I may have been chasing a red herring:
                              M587 S"NUMERICABLE-B290" P"PASS" ; send this line to be saved in wifi module
                              of course, those lines looks like a reboot.
                                Not a reboot, just turning the network off and on again. The only one of those lines you need is M552 S1.
                                • nraynaudundefined
                                  nraynaud
                                  yes.
                                  I don't have a reboot in my configuration, but I still have a weird hang during homing.
                                  is there a way to dump the state of the machine? I feel like it's waiting for something.
                                  here is a log during homing:
                                  21:59:09M122
                                  Used output buffers: 10 of 24 (16 max)
                                  Static ram: 30516
                                  Dynamic ram: 93164 of which 12 recycled
                                  Exception stack ram used: 488
                                  Never used ram: 6892
                                  Tasks: NETWORK(ready,640) HEAT(blocked,1184) DUEX(suspended,160) MAIN(running,3676) IDLE(ready,156)
                                  Owned mutexes:
                                  Last reset 00:27:43 ago, cause: software
                                  Last software reset at 2019-12-29 21:31, reason: User, spinning module GCodes, available RAM 6788 bytes (slot 0)
                                  Error status: 0
                                  Free file entries: 9
                                  MCU temperature: min 33.9, current 35.2, max 35.7
                                  Driver 0: standstill, SG min/max 359/1023
                                  Driver 1: standstill, SG min/max 344/1023
                                  Driver 3: standstill, SG min/max 56/1023
                                  Driver 4: standstill, SG min/max 0/196
                                  Date/time: 2019-12-29 21:59:08
                                  Slowest loop: 8.01ms; fastest: 0.09ms
                                  Hiccups: 0(0), FreeDm: 169, MinFreeDm: 165, MaxWait: 1652015ms
                                  === MainDDARing ===
                                  Scheduled moves: 8, completed moves: 3, StepErrors: 0, LaErrors: 0, Underruns: 0, 0
                                  === AuxDDARing ===
                                  Segments left: 1
                                  Stack records: 2 allocated, 1 in use
                                  Movement lock held by http
                                  http is doing "G53 G1 Y-415 F360 H1" in state(s) 0 8, running macro
                                  === Network ===
                                  Slowest loop: 15.86ms; fastest: 0.00ms
                                  - WiFi -
                                  WiFi flash size 4194304, free heap 19376
                                  WiFi signal strength -57dBm, reconnections 0, sleep mode modem
                                  21:58:58G28 Y
                                    Looks like it thinks it is executing the Y homing move and waiting for the endstop to trigger. Maybe the Y motor current or motor current percentage is set to zero? Or the Y motor mapped to the wrong driver?
                                    • nraynaudundefined
                                      nraynaud
                                      ; homey.g
                                      G91
                                      G1 Z2 F6000
                                      G90
                                      ; Go back a few mm
                                      G53 G1 Y3 F40000
                                      G53 G1 Y2 F10000
                                      ; Lower Z again
                                      G91
                                      G1 Z-2 F6000
                                      G90
                                      it has moved and done the coarse homing right before that.
                                      executing it line by line seems to work ok:
                                      22:48:41G90
                                      22:48:35G1 Z-2 F6000
                                      22:48:28G91
                                      22:48:22G53 G1 Y2 F10000
                                      22:48:16G53 G1 Y-415 F360 H1
                                      22:48:05G53 G1 Y3 F40000
                                      22:47:56G53 G1 Y-415 F10000 H1
                                      22:47:47G90
                                      22:47:40G1 Z2 F6000
                                      22:47:32G91
                                      22:47:31Connection established!
                                      I really don't know. running `M98 P"homey.g"' triggers the issue too.
                                      edit: I get the bug both with and without the pullup, but I don't see any influence of this setting the web interface anyways (the switch works perfectly in my tests in the web interface)
                                        You really ought to be using relative movement commands with G1 H1. Also, i still donm;'t understand why you think you need the G53 prefixes. What happens if you use relative movement and no G53 prefixes?
                                        • nraynaudundefined
                                          nraynaud
                                          In my limited testing (the software side of this project feels like being a ball at a rugby game, everything is just hard, I don't know what conclusion actually hold), homing without G53 was placing the tool center at the switch trigger point instead of placing the machine zero there.
                                          I will look into the relative movements, I need to find the original example files, thanks.
                                          • nraynaudundefined
                                            nraynaud
                                            I found it! Thanks for your help.
                                            I need more time or more distance to back out of the switches after the coarse homing (what's weird is that I had the same issue in X and Y). That's why I couldn't find the issue line by line.
                                            have you de-bounced the switches or changed the execution order?
