    RepRapFirmware 3.0RC2 now available
    Beta Firmware
    11
    39
    3.1k
      dc42 administrators @nraynaud
      @nraynaud said in RepRapFirmware 3.0RC2 now available:
      I deny that this reboot was directly asked by me, I don't see any reboot command in my files, and it is the result of the M98 P"config.g"
      It's not requested by you, the diagnostics make that clear. Can you pin down which line causes the reboot? For example, take a copy of config.g, and delete about 50% of the lines at the end of the copy. Then use M98 to run that copy. If it still crashes, delete 50% of the lines remaining at the end; otherwise reinstate some lines that you deleted. Then try again, and so on.
      • nraynaudundefined
        nraynaud
        thanks for your help, I'll start right now.
        • nraynaudundefined
          nraynaud
          I may have been chasing a red herring:
          M552 S0 ; awaken wifi module and set to idle
          M587 S"NUMERICABLE-B290" P"PASS" ; send this line to be saved in wifi module
          M552 S1 ; connect the wifi module to the network
          of course, those lines looks like a reboot.
            Not a reboot, just turning the network off and on again. The only one of those lines you need is M552 S1.
            • nraynaudundefined
              nraynaud
              yes.
              I don't have a reboot in my configuration, but I still have a weird hang during homing.
              is there a way to dump the state of the machine? I feel like it's waiting for something.
              here is a log during homing:
              21:59:09M122
              RepRapFirmware for Duet 2 WiFi/Ethernet version 3.0RC2 running on Duet WiFi 1.02 or later + DueX5
              Board ID: 08DDM-9FAM2-LW4SD-6JKD4-3S46L-92X3W
              Used output buffers: 10 of 24 (16 max)
              Static ram: 30516
              Dynamic ram: 93164 of which 12 recycled
              Exception stack ram used: 488
              Never used ram: 6892
              Tasks: NETWORK(ready,640) HEAT(blocked,1184) DUEX(suspended,160) MAIN(running,3676) IDLE(ready,156)
              Owned mutexes:
              Last reset 00:27:43 ago, cause: software
              Last software reset at 2019-12-29 21:31, reason: User, spinning module GCodes, available RAM 6788 bytes (slot 0)
              Error status: 0
              Free file entries: 9
              MCU temperature: min 33.9, current 35.2, max 35.7
              Supply voltage: min 24.0, current 24.1, max 24.3, under voltage events: 0, over voltage events: 0, power good: yes
              Driver 0: standstill, SG min/max 359/1023
              Driver 1: standstill, SG min/max 344/1023
              Driver 3: standstill, SG min/max 56/1023
              Driver 4: standstill, SG min/max 0/196
              Driver 5: standstill, SG min/max not available
              Driver 6: standstill, SG min/max not available
              Driver 7: standstill, SG min/max not available
              Date/time: 2019-12-29 21:59:08
              Slowest loop: 8.01ms; fastest: 0.09ms
              Hiccups: 0(0), FreeDm: 169, MinFreeDm: 165, MaxWait: 1652015ms
              === MainDDARing ===
              Scheduled moves: 8, completed moves: 3, StepErrors: 0, LaErrors: 0, Underruns: 0, 0
              === AuxDDARing ===
              Segments left: 1
              Stack records: 2 allocated, 1 in use
              Movement lock held by http
              http is doing "G53 G1 Y-415 F360 H1" in state(s) 0 8, running macro
              telnet is idle in state(s) 0
              file is idle in state(s) 0
              serial is idle in state(s) 0
              aux is idle in state(s) 0
              daemon is idle in state(s) 0
              queue is idle in state(s) 0
              Code queue is empty.
              === Network ===
              Slowest loop: 15.86ms; fastest: 0.00ms
              Responder states: HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0)
              HTTP sessions: 1 of 8
              - WiFi -
              Network state is running
              WiFi firmware version 1.23
              WiFi MAC address 60:01:94:34:3b:19
              WiFi Vcc 3.37, reset reason Turned on by main processor
              WiFi flash size 4194304, free heap 19376
              WiFi IP address 192.168.0.28
              WiFi signal strength -57dBm, reconnections 0, sleep mode modem
              21:58:58G28 Y
                Looks like it thinks it is executing the Y homing move and waiting for the endstop to trigger. Maybe the Y motor current or motor current percentage is set to zero? Or the Y motor mapped to the wrong driver?
                • nraynaudundefined
                  nraynaud
                  ; homey.g
                  ; called to home the Y axis
                  ; generated by RepRapFirmware Configuration Tool on Wed Nov 15 2017 23:36:04 GMT-0700 (MST)
                  ; Lift Z relative to current position
                  G91
                  G1 Z2 F6000
                  G90
                  ; M98 P"outdanger.g"
                  ; Move quickly to Y axis endstop and stop there (first pass)
                  G53 G1 Y-415 F10000 H1
                  ; Go back a few mm
                  G53 G1 Y3 F40000
                  ; Move slowly to Y axis endstop once more (second pass)
                  G53 G1 Y2 F10000
                  ; Lower Z again
                  G91
                  G1 Z-2 F6000
                  G90
                  it has moved and done the coarse homing right before that.
                  executing it line by line seems to work ok:
                  22:48:41G90
                  22:48:35G1 Z-2 F6000
                  22:48:28G91
                  22:48:22G53 G1 Y2 F10000
                  22:48:16G53 G1 Y-415 F360 H1
                  22:48:05G53 G1 Y3 F40000
                  22:47:56G53 G1 Y-415 F10000 H1
                  22:47:47G90
                  22:47:40G1 Z2 F6000
                  22:47:32G91
                  22:47:31Connection established!
                  I really don't know. running `M98 P"homey.g"' triggers the issue too.
                  edit: I get the bug both with and without the pullup, but I don't see any influence of this setting the web interface anyways (the switch works perfectly in my tests in the web interface)
                    You really ought to be using relative movement commands with G1 H1. Also, i still donm;'t understand why you think you need the G53 prefixes. What happens if you use relative movement and no G53 prefixes?
                    • nraynaudundefined
                      nraynaud
                      In my limited testing (the software side of this project feels like being a ball at a rugby game, everything is just hard, I don't know what conclusion actually hold), homing without G53 was placing the tool center at the switch trigger point instead of placing the machine zero there.
                      I will look into the relative movements, I need to find the original example files, thanks.
                      • nraynaudundefined
                        nraynaud
                        I found it! Thanks for your help.
                        I need more time or more distance to back out of the switches after the coarse homing (what's weird is that I had the same issue in X and Y). That's why I couldn't find the issue line by line.
                        have you de-bounced the switches or changed the execution order?
                          There has been a change in behaviour when you execute a homing move and the switch is already triggered. Previously, the move would be started and when the first microstep was due, at that point it would recognise that the switch was triggered. Now it checks the switches before starting the move. If they are triggered, it should cancel the move, unless there are other motors being homed using different switches. It sounds to me that it is behaving as if there is another switch waiting to be triggered.
                          • stewwyundefined
                            stewwy
                            Is manual bed probing working in 3.0RC2, (my IRprobe is not working,a different problem). I've changed the probe type to P0. This worked in 2.05 giving me the manual menu in DWC/Paneldue but not in 3.0RC2. Is there something else I need to do? I have noticed that the Z endstop is showing as constantly triggered.
                            EDIT: It gave me this error--
                            G28
                            Error: SetPositions called when DDA ring not empty
                            • blt3dpundefined
                              blt3dp
                              Is it up on the unstable package server?
                              My 3D Printing YouTube Channel
                              Better Living Through 3D Printing
                              Follow me on Instagram and Twitter
                              Instagram
                              Twitter
                              • chrishammundefined
                                chrishamm administrators
                                The latest version on the unstable package feed is now RC2+1 because I found another DSF-related issue involving macro files. If anyone wants to compile it, those changes are on my v3-chrishamm branch of RRF.
                                Duet software engineer
                                blt3dpundefined 1 Reply Last reply Reply Quote 0
                                • chas2706undefined
                                  chas2706
                                  @chrishamm
                                  Hi are you aware of M291 error "command not known" in DSF
                                    Yes, see https://github.com/chrishamm/DuetSoftwareFramework/tree/dev#known-issues
                                    • chas2706undefined
                                      chas2706
                                      Ok cheers!
                                      • blt3dpundefined
                                        blt3dp @chrishamm
                                        @chrishamm
                                        Doing sudo apt-get update and then apt-get upgrade gives this error on reprap firmware package.
                                        Setting up reprapfirmware (1.2.2.0-1) ...
                                        [error] Failed to connect to Duet
                                           System.IO.IOException: Error 16. Cannot put line into event mode.
                                           at LinuxDevices.InputGpioPin..ctor(String devNode, Int32 pin, String consumerLabel) in /home/christian/duet/DuetSoftwareFramework/src/LinuxDevices/InputGpioPin.cs:line 60
                                           at DuetControlServer.SPI.DataTransfer.Init() in /home/christian/duet/DuetSoftwareFramework/src/DuetControlServer/SPI/DataTransfer.cs:line 65
                                           at DuetControlServer.SPI.Interface.Init() in /home/christian/duet/DuetSoftwareFramework/src/DuetControlServer/SPI/Interface.cs:line 65
                                           at DuetControlServer.Program.Main(String[] args) in /home/christian/duet/DuetSoftwareFramework/src/DuetControlServer/Program.cs:line 92
                                        Everything else updated except for the firmware, still on 3.0RC1
                                        I noticed the Duet3Firmware_MB6HC.bin on the virtual SD card had today's timestamp so I ran M997 and it updated, now it shows 3.0RC2+1
                                        Instagram
                                        Twitter
                                          jay_s_uk @blt3dp
                                          @blt3dp
                                          I had that happened as well.
                                          If you run M997 S0, the firmware is still updated
                                          • blt3dpundefined
                                            blt3dp @jay_s_uk
                                            @jay_s_uk said in RepRapFirmware 3.0RC2 now available:
                                            @blt3dp
                                            Yep, I was just doing an edit. That's exactly what I did.
                                            Instagram
                                            Twitter
