RepRapFirmware 3.0RC2 now available
@nraynaud said in RepRapFirmware 3.0RC2 now available:
Web Interface Version: 1.22.6
Shouldn't this be 2.0.4?
@dc42 said in RepRapFirmware 3.0RC2 now available:
M122
I see the software got afraid of the boss, here is my log now (I don't think I changed anything, probably a race condition):
19:24:18M122 === Diagnostics === RepRapFirmware for Duet 2 WiFi/Ethernet version 3.0RC2 running on Duet WiFi 1.02 or later + DueX5 Board ID: 08DDM-9FAM2-LW4SD-6JKD4-3S46L-92X3W Used output buffers: 3 of 24 (16 max) === RTOS === Static ram: 30516 Dynamic ram: 93164 of which 44 recycled Exception stack ram used: 256 Never used ram: 7092 Tasks: NETWORK(ready,640) HEAT(blocked,1240) DUEX(suspended,160) MAIN(running,3668) IDLE(ready,156) Owned mutexes: === Platform === Last reset 00:08:29 ago, cause: software Last software reset at 2019-12-29 19:15, reason: User, spinning module GCodes, available RAM 7100 bytes (slot 1) Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0041f000 BFAR 0xe000ed38 SP 0xffffffff Task 0x4e49414d Error status: 0 Free file entries: 10 SD card 0 detected, interface speed: 20.0MBytes/sec SD card longest block write time: 0.0ms, max retries 0 MCU temperature: min 35.1, current 35.4, max 36.0 Supply voltage: min 24.0, current 24.1, max 24.3, under voltage events: 0, over voltage events: 0, power good: yes Driver 0: standstill, SG min/max not available Driver 1: standstill, SG min/max not available Driver 2: standstill, SG min/max not available Driver 3: standstill, SG min/max not available Driver 4: standstill, SG min/max not available Driver 5: standstill, SG min/max not available Driver 6: standstill, SG min/max not available Driver 7: standstill, SG min/max not available Driver 8: standstill, SG min/max not available Driver 9: standstill, SG min/max not available Date/time: 2019-12-29 19:24:16 Cache data hit count 1397321660 Slowest loop: 128.51ms; fastest: 0.10ms I2C nak errors 0, send timeouts 0, receive timeouts 0, finishTimeouts 0, resets 0 === Move === Hiccups: 0(0), FreeDm: 169, MinFreeDm: 169, MaxWait: 0ms Bed compensation in use: none, comp offset 0.000 === MainDDARing === Scheduled moves: 0, completed moves: 0, StepErrors: 0, LaErrors: 0, Underruns: 0, 0 === AuxDDARing === Scheduled moves: 0, completed moves: 0, StepErrors: 0, LaErrors: 0, Underruns: 0, 0 === Heat === Bed heaters = 0 -1 -1 -1, chamberHeaters = -1 -1 -1 -1 === GCodes === Segments left: 0 Stack records: 2 allocated, 0 in use Movement lock held by null http is idle in state(s) 0 telnet is idle in state(s) 0 file is idle in state(s) 0 serial is idle in state(s) 0 aux is idle in state(s) 0 daemon is idle in state(s) 0 queue is idle in state(s) 0 autopause is idle in state(s) 0 Code queue is empty. === Network === Slowest loop: 200.23ms; fastest: 0.00ms Responder states: HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0) HTTP sessions: 1 of 8 - WiFi - Network state is running WiFi module is connected to access point Failed messages: pending 0, notready 0, noresp 1 WiFi firmware version 1.23 WiFi MAC address 60:01:94:34:3b:19 WiFi Vcc 3.37, reset reason Turned on by main processor WiFi flash size 4194304, free heap 24312 WiFi IP address 192.168.0.28 WiFi signal strength -59dBm, reconnections 0, sleep mode modem Socket states: 0 0 0 0 0 0 0 0 19:22:24Connection established! 19:22:23Disconnected. 19:22:15M98 P"config.g" Error: M558: Missing Z probe pin name(s) Error: G31: Invalid Z probe index all of a sudden it spits the error message. I'll look at the documentation, the error was probably here before.
@Phaedrux I am using the old page at
/reprap.htm#
it's more confortable and shows more things for diagnostics.@dc42 actually after commenting M558 and G31 I still get the reboot:
19:32:11M122 === Diagnostics === RepRapFirmware for Duet 2 WiFi/Ethernet version 3.0RC2 running on Duet WiFi 1.02 or later + DueX5 Board ID: 08DDM-9FAM2-LW4SD-6JKD4-3S46L-92X3W Used output buffers: 1 of 24 (17 max) === RTOS === Static ram: 30516 Dynamic ram: 93164 of which 44 recycled Exception stack ram used: 256 Never used ram: 7092 Tasks: NETWORK(ready,640) HEAT(blocked,1240) DUEX(suspended,160) MAIN(running,3676) IDLE(ready,156) Owned mutexes: === Platform === Last reset 00:00:46 ago, cause: software Last software reset at 2019-12-29 19:31, reason: User, spinning module GCodes, available RAM 7432 bytes (slot 0) Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0441f000 BFAR 0xe000ed38 SP 0xffffffff Task 0x4e49414d Error status: 0 Free file entries: 10 SD card 0 detected, interface speed: 20.0MBytes/sec SD card longest block write time: 0.0ms, max retries 0 MCU temperature: min 34.3, current 35.7, max 36.2 Supply voltage: min 24.0, current 24.1, max 24.3, under voltage events: 0, over voltage events: 0, power good: yes Driver 0: standstill, SG min/max not available Driver 1: standstill, SG min/max not available Driver 2: standstill, SG min/max not available Driver 3: standstill, SG min/max not available Driver 4: standstill, SG min/max not available Driver 5: standstill, SG min/max not available Driver 6: standstill, SG min/max not available Driver 7: standstill, SG min/max not available Driver 8: standstill, SG min/max not available Driver 9: standstill, SG min/max not available Date/time: 2019-12-29 19:32:09 Cache data hit count 105424755 Slowest loop: 128.25ms; fastest: 0.09ms I2C nak errors 0, send timeouts 0, receive timeouts 0, finishTimeouts 0, resets 0 === Move === Hiccups: 0(0), FreeDm: 169, MinFreeDm: 169, MaxWait: 0ms Bed compensation in use: none, comp offset 0.000 === MainDDARing === Scheduled moves: 0, completed moves: 0, StepErrors: 0, LaErrors: 0, Underruns: 0, 0 === AuxDDARing === Scheduled moves: 0, completed moves: 0, StepErrors: 0, LaErrors: 0, Underruns: 0, 0 === Heat === Bed heaters = 0 -1 -1 -1, chamberHeaters = -1 -1 -1 -1 === GCodes === Segments left: 0 Stack records: 2 allocated, 0 in use Movement lock held by null http is idle in state(s) 0 telnet is idle in state(s) 0 file is idle in state(s) 0 serial is idle in state(s) 0 aux is idle in state(s) 0 daemon is idle in state(s) 0 queue is idle in state(s) 0 autopause is idle in state(s) 0 Code queue is empty. === Network === Slowest loop: 116.61ms; fastest: 0.00ms Responder states: HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0) HTTP sessions: 1 of 8 - WiFi - Network state is running WiFi module is connected to access point Failed messages: pending 0, notready 0, noresp 0 WiFi firmware version 1.23 WiFi MAC address 60:01:94:34:3b:19 WiFi Vcc 3.37, reset reason Turned on by main processor WiFi flash size 4194304, free heap 24608 WiFi IP address 192.168.0.28 WiFi signal strength -60dBm, reconnections 0, sleep mode modem Socket states: 0 0 0 0 0 0 0 0 19:32:06Connection established! 19:32:05Disconnected. 19:31:41Connection established! 19:31:41Page Load complete! I deny that this reboot was directly asked by me, I don't see any reboot command in my files, and it is the result of the M98 P"config.g"
It's not requested by you, the diagnostics make that clear. Can you pin down which line causes the reboot? For example, take a copy of config.g, and delete about 50% of the lines at the end of the copy. Then use M98 to run that copy. If it still crashes, delete 50% of the lines remaining at the end; otherwise reinstate some lines that you deleted. Then try again, and so on.
thanks for your help, I'll start right now.
I may have been chasing a red herring:
M552 S0 ; awaken wifi module and set to idle M587 S"NUMERICABLE-B290" P"PASS" ; send this line to be saved in wifi module M552 S1 ; connect the wifi module to the network of course, those lines looks like a reboot.
Not a reboot, just turning the network off and on again. The only one of those lines you need is M552 S1.
yes.
I don't have a reboot in my configuration, but I still have a weird hang during homing.
is there a way to dump the state of the machine? I feel like it's waiting for something.
here is a log during homing:
21:59:09M122 === Diagnostics === RepRapFirmware for Duet 2 WiFi/Ethernet version 3.0RC2 running on Duet WiFi 1.02 or later + DueX5 Board ID: 08DDM-9FAM2-LW4SD-6JKD4-3S46L-92X3W Used output buffers: 10 of 24 (16 max) === RTOS === Static ram: 30516 Dynamic ram: 93164 of which 12 recycled Exception stack ram used: 488 Never used ram: 6892 Tasks: NETWORK(ready,640) HEAT(blocked,1184) DUEX(suspended,160) MAIN(running,3676) IDLE(ready,156) Owned mutexes: === Platform === Last reset 00:27:43 ago, cause: software Last software reset at 2019-12-29 21:31, reason: User, spinning module GCodes, available RAM 6788 bytes (slot 0) Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0441f000 BFAR 0xe000ed38 SP 0xffffffff Task 0x4e49414d Error status: 0 Free file entries: 9 SD card 0 detected, interface speed: 20.0MBytes/sec SD card longest block write time: 0.0ms, max retries 0 MCU temperature: min 33.9, current 35.2, max 35.7 Supply voltage: min 24.0, current 24.1, max 24.3, under voltage events: 0, over voltage events: 0, power good: yes Driver 0: standstill, SG min/max 359/1023 Driver 1: standstill, SG min/max 344/1023 Driver 2: standstill, SG min/max not available Driver 3: standstill, SG min/max 56/1023 Driver 4: standstill, SG min/max 0/196 Driver 5: standstill, SG min/max not available Driver 6: standstill, SG min/max not available Driver 7: standstill, SG min/max not available Driver 8: standstill, SG min/max not available Driver 9: standstill, SG min/max not available Date/time: 2019-12-29 21:59:08 Cache data hit count 4294967295 Slowest loop: 8.01ms; fastest: 0.09ms I2C nak errors 0, send timeouts 0, receive timeouts 0, finishTimeouts 0, resets 0 === Move === Hiccups: 0(0), FreeDm: 169, MinFreeDm: 165, MaxWait: 1652015ms Bed compensation in use: none, comp offset 0.000 === MainDDARing === Scheduled moves: 8, completed moves: 3, StepErrors: 0, LaErrors: 0, Underruns: 0, 0 === AuxDDARing === Scheduled moves: 0, completed moves: 0, StepErrors: 0, LaErrors: 0, Underruns: 0, 0 === Heat === Bed heaters = 0 -1 -1 -1, chamberHeaters = -1 -1 -1 -1 === GCodes === Segments left: 1 Stack records: 2 allocated, 1 in use Movement lock held by http http is doing "G53 G1 Y-415 F360 H1" in state(s) 0 8, running macro telnet is idle in state(s) 0 file is idle in state(s) 0 serial is idle in state(s) 0 aux is idle in state(s) 0 daemon is idle in state(s) 0 queue is idle in state(s) 0 autopause is idle in state(s) 0 Code queue is empty. === Network === Slowest loop: 15.86ms; fastest: 0.00ms Responder states: HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0) HTTP sessions: 1 of 8 - WiFi - Network state is running WiFi module is connected to access point Failed messages: pending 0, notready 0, noresp 0 WiFi firmware version 1.23 WiFi MAC address 60:01:94:34:3b:19 WiFi Vcc 3.37, reset reason Turned on by main processor WiFi flash size 4194304, free heap 19376 WiFi IP address 192.168.0.28 WiFi signal strength -57dBm, reconnections 0, sleep mode modem Socket states: 0 0 0 0 0 0 0 0 21:58:58G28 Y -
Looks like it thinks it is executing the Y homing move and waiting for the endstop to trigger. Maybe the Y motor current or motor current percentage is set to zero? Or the Y motor mapped to the wrong driver?
; homey.g ; called to home the Y axis ; ; generated by RepRapFirmware Configuration Tool on Wed Nov 15 2017 23:36:04 GMT-0700 (MST) ; Lift Z relative to current position G91 G1 Z2 F6000 G90 ; M98 P"outdanger.g" ; Move quickly to Y axis endstop and stop there (first pass) G53 G1 Y-415 F10000 H1 ; Go back a few mm G53 G1 Y3 F40000 ; Move slowly to Y axis endstop once more (second pass) G53 G1 Y-415 F360 H1 G53 G1 Y2 F10000 ; Lower Z again G91 G1 Z-2 F6000 G90 it has moved and done the coarse homing right before that.
executing it line by line seems to work ok:
22:48:41G90 22:48:35G1 Z-2 F6000 22:48:28G91 22:48:22G53 G1 Y2 F10000 22:48:16G53 G1 Y-415 F360 H1 22:48:05G53 G1 Y3 F40000 22:47:56G53 G1 Y-415 F10000 H1 22:47:47G90 22:47:40G1 Z2 F6000 22:47:32G91 22:47:31Connection established! I really don't know. running `M98 P"homey.g"' triggers the issue too.
edit: I get the bug both with and without the pullup, but I don't see any influence of this setting the web interface anyways (the switch works perfectly in my tests in the web interface)
You really ought to be using relative movement commands with G1 H1. Also, i still donm;'t understand why you think you need the G53 prefixes. What happens if you use relative movement and no G53 prefixes?
In my limited testing (the software side of this project feels like being a ball at a rugby game, everything is just hard, I don't know what conclusion actually hold), homing without G53 was placing the tool center at the switch trigger point instead of placing the machine zero there.
I will look into the relative movements, I need to find the original example files, thanks.
I found it! Thanks for your help.
I need more time or more distance to back out of the switches after the coarse homing (what's weird is that I had the same issue in X and Y). That's why I couldn't find the issue line by line.
have you de-bounced the switches or changed the execution order?
There has been a change in behaviour when you execute a homing move and the switch is already triggered. Previously, the move would be started and when the first microstep was due, at that point it would recognise that the switch was triggered. Now it checks the switches before starting the move. If they are triggered, it should cancel the move, unless there are other motors being homed using different switches. It sounds to me that it is behaving as if there is another switch waiting to be triggered.
Is manual bed probing working in 3.0RC2, (my IRprobe is not working,a different problem). I've changed the probe type to P0. This worked in 2.05 giving me the manual menu in DWC/Paneldue but not in 3.0RC2. Is there something else I need to do? I have noticed that the Z endstop is showing as constantly triggered.
EDIT: It gave me this error--
G28
Error: SetPositions called when DDA ring not empty -
Is it up on the unstable package server?
The latest version on the unstable package feed is now RC2+1 because I found another DSF-related issue involving macro files. If anyone wants to compile it, those changes are on my v3-chrishamm branch of RRF.
@chrishamm
Hi are you aware of M291 error "command not known" in DSF -
Ok cheers!
