    12 V Fan Speed contol at 24 V input voltage
    535
    • timcurtis67undefined
      timcurtis67
      Try a buck converter to drop the 24V down to 12V for certain fans.
      • aidarundefined
        aidar
        Fan speed on Duet is controlled by PWM signal on negative (Ground) side. So whatever your positive voltage is (12v in your case after step down module) connect fan negative to fan connector negative of Duet and you can controll its speed. Read it again and do as instruction says. https://duet3d.dozuki.com/Wiki/Connecting_and_configuring_fans#Section_Using_12V_fans_when_VIN_is_24V
          Example use of buck converter. https://duet3d.dozuki.com/Guide/Ender+3+Pro+and+Duet+Maestro+Guide+Part+5:+Upgrades/54#s214
          rothundefined 1 Reply Last reply Reply Quote 0
          • rothundefined
            roth @Phaedrux
            But it is false. I want not all fans use with 12 V.
            Only one fan must have 12 V.
            @aidar said in 12 V Fan Speed contol at 24 V input voltage:
            M106 P0 S0.3 I0 F500 H-1 ; Set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned off
            M106 P1 S0.1 I0 F500 H-1 ; Set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned off
            M106 P2 S1 I0 F500 H0:1 T50 ; Set fan 2 value, PWM signal inversion and frequency. Thermostatic control is turned on
              A Former User @roth
              @roth said in 12 V Fan Speed contol at 24 V input voltage:
              That helps not. Well i have 12 V and 24 V fans.
              yes it will, read section 3 again. until you understand it.
              rothundefined 1 Reply Last reply Reply Quote 1
              • rothundefined
                roth @A Former User
                @bearer That Wiring Diagram is for a Duet Maestro.
                I have a Duet Wifi Board. The Problem is i have other Jumper and Pins. https://d17kynu4zpq5hy.cloudfront.net/igi/duet3d/4k56ZjaaAHrTJI6Z.huge
                • Vetiundefined
                  Veti @roth
                  @roth
                  as the other have suggested in this thread. there is nothing stopping you from just changing the voltage on one fan. convert any 24v line to 12v and connect the negative to the gnd pin on the fan connector.
                  • rothundefined
                    roth
                    Another problem is security because the stepdown module is then directly on the power supply. The power supply delivers 300 watts.
                    I definitely have to install a fuse.
                    • Vetiundefined
                      Veti @roth
                      if you want to be on the save side, why dont you just buy 5v fans and replace all of them.
                        A Former User
                        • rothundefined
                          roth @A Former User
                          @bearer Ok Now I understand it. The problem was that I didn't understand the jumper. What he does.
                          I just checked it. From factory it ist on the right Position.
                          And I had only read that first and at that time I didn't know that the speed on the duet board would be switched over - the pole. The principle was new for me.
                          Thank you for your help and patience me.
                            Phaedrux Moderator @roth
                            We're all here to help.
                            • rothundefined
                              roth
                              All works great. Post can be closed.
