heater fault when print starts
Just to verify can you post your config-override.g?
Is the part cooling fan running at all during that drop?
Did you run the tune with the part cooling fan on at normal print speeds?
What kind of hotend and thermistor are you using?
Have you physically checked the wiring? -
@Phaedrux the cooling fan was running full blast on the auto tune and i have a sock on and the fan was off when printing
; config-override.g file generated in response to M500 at 2019-12-31 16:54
; Heater model parameters
M307 H0 A90.0 C700.0 D10.0 S1.00 V0.0 B1
M307 H1 A340.0 C140.0 D5.5 S1.00 V0.0 B0
M307 H2 A363.5 C140.9 D4.4 S1.00 V12.1 B0
M307 H3 A340.0 C140.0 D5.5 S1.00 V0.0 B0
M307 H4 A340.0 C140.0 D5.5 S1.00 V0.0 B0
M307 H5 A340.0 C140.0 D5.5 S1.00 V0.0 B0
M307 H6 A340.0 C140.0 D5.5 S1.00 V0.0 B0
G10 L2 P1 X0.00 Y0.00 Z0.00
G10 L2 P2 X0.00 Y0.00 Z0.00
G10 L2 P3 X0.00 Y0.00 Z0.00
G10 L2 P4 X0.00 Y0.00 Z0.00
G10 L2 P5 X0.00 Y0.00 Z0.00
G10 L2 P6 X0.00 Y0.00 Z0.00
G10 L2 P7 X0.00 Y0.00 Z0.00
G10 L2 P8 X0.00 Y0.00 Z0.00
G10 L2 P9 X0.00 Y0.00 Z0.00 -
i am using the bond tech cr-10 direct drive it has a e3d v6 and i have checked the wiring and my heat bed is independent from the main board
@Government_Bacon said in heater fault when print starts:
what do you mean by independent of the main board?
@Veti it is its own system you plug it in to the wall and set it manual
What is the heater fault error message shown in the console?
it was printing fine and then just drop temp
e3d v6
Is the thermistor cartridge and heater cartridge secured firmly? Have you removed them to check them?
@Phaedrux yes the thermistor is brand new and the heater is good and both are mounted good
i am useing this settup -
whats the resistance of the heater cartrige?
@Veti 91.5 printer says its at 26 c
91.5
then there is a problem with your heater cartridge
see normal resistances
https://matterhackers.dozuki.com/Wiki/E3D_Heater_Cartridge_Resistance -
@Veti sorry i checked the thermistor not the heater cartage. i ended up taking it a part and found out the heater cartage lead broke so i replaced it and it still dose the same thing. i checked the new one and its is at 5.4 and i checked the wires. testing now. tested it and it still drops i also did a auto tune for the new cartage
ok i have found my problem. i went through checking all of my wires and found one that i was getting it and miss reading from the hot end and it has a part of the wire severed in side if the wire covering. so i got it fixed and now it is working good.
