    Email/notifications from Duet wifi
    Duet Web Control
    10
    21
    2.2k
    • Vetiundefined
      Veti
      see
      https://forum.duet3d.com/topic/169/notification-via-pushover-or-other-service
        Our latest thoughts about this are to embed a MQTT client in RRF that publishes messages about the current state of the printer e.g. printer powered up, print started, print completed, print paused by filament monitor.
        CNCModellerundefined Nightreaverundefined AS-3D Druckundefined 3 Replies Last reply Reply Quote 12
        • CNCModellerundefined
          CNCModeller @dc42
          @dc42 MQTT integration would be awesome... my home automation uses an mqtt broker and openhab so I could check print status securely anywhere via the openhab internet gateway and mobile app.
          Polar Duet3 Mini + 1HCL
          https://youtube.com/playlist?list=PLWjZVEdMv1BY82izahK45qKh-hp3NFkix
          Wanhao D4S: Duet2
          https://forum.duet3d.com/post/296755
          K40 Laser, Duet2
          https://forum.duet3d.com/post/312082
          Wanhao D5S
          https://www.youtube.com/CNCModellerUK
          • Nightreaverundefined
            Nightreaver @dc42
            @dc42 said in Email/notifications from Duet wifi:
            any ETA there?
            • AS-3D Druckundefined
              AS-3D Druck @dc42
              @dc42 So there will be a implematation for Google Home/Alexa with some commands like:
              ''How long does the Print take to finish?''
              Or:
              ''Pause print''
              Best regards
              AS-3D Druck / Andre
              Nightreaverundefined 1 Reply Last reply Reply Quote 0
                Nightreaver @AS-3D Druck
                @AS-3D-Druck thats should be doable with MQTT then.
                But @dc42 didnt mention anything about receiving commands via MQTT.
                So only getting status info for now?!
                • r123undefined
                  r123
                  Basically everyone wants to get a message on their phone saying either "print finished"; "change filament" or "heater problem"... Could be by e-mail, by SMS, by some more custom means..... We just want the notification so we can stop checking on our printer (s) and concentrate on doing other things (having dinner, chatting, sleeping....).
                  Is the MQTT option difficult to setup? How is it received on the phone?
                  This will be a big ease-of-use leap forward: let's not hang around! 😄
                  • Danalundefined
                    Danal
                    Having an MQTT push is easier.
                    However, right now, any RRF release short of 3 can be polled by HTTP. There are lots of examples, including things that run on tiny little IOT devices like ESP8266 or ESP32. Or a little script running somewhere could then connect to whatever push notification you want.
                    Or... on your local network, build one of these: https://github.com/DanalEstes/DuetMonitor
                    RR3 can be polled by websocket. Not as many examples, because it is newer.
                    r123undefined 1 Reply Last reply Reply Quote 0
                    • r123undefined
                      r123 @Danal
                      @Danal what would the MQTT push be read by on my phone? A Duet specialist app? Or...
                      • Danalundefined
                        Danal
                        MQTT is a defacto standard for IOT interaction. The most effective way to use it with a 3D printer that produced MQTT messages would be to configure (not code) a small MQTT broker on an always running machine at your house. PC, Mac, Pi, whatever. Probably mosquito.
                        That MQTT broker would receive the messages, and invoke whatever you want to push to your phone. SMS, Email, Pushover, Airship, whatever service you wish.
                        • Danalundefined
                          Danal
                          Why not just write a "send email" capability into the Printer? Because that would (more or less) require the printer to contact a web IP address. Bad, bad juju to have IOT devices like printers open anything to the internet.
                          Also lack of flexibility. There are dozens, if not hundreds, of notification services. The printer firmware would always be lacking some specific interface.
                          MQTT from printer to broker, broker is the one handling internet stuff, and can probably interface to almost anything, either built in, or via command line. Much better juju.
                          • r123undefined
                            r123
                            I thought ssl smtp access was just a single port?
                            An IOT gadget can’t be made “broadcast only” (thus safe) in its internet access?
                            • Danalundefined
                              Danal @r123
                              @r123 said in Email/notifications from Duet wifi:
                              Safe is relative. Better that a firmware based device have absolutely zero direct connectivity. In, out, whatever.
                              But really, the much bigger reason is... what list of things to support from the firmware? "Just" SMTP?? What about SMTP with authentication? (there are VERY few open mailservers around anymore). With TLS? or some other encryption? or MAPI (a much more secure mail protocol)? Or...
                              MQTT for IOT devices. MQTT broker to do anything you want.
                                Nightreaver
                                @dc42 Is there any update on the MQTT progress?
                                Will it be available with RRF 2 or only with the new RRF3 ?
                                Will it publish all information from the WebIF? Like temps, speed, job status etc?
                                  dc42 administrators @Nightreaver
                                  @Nightreaver said in Email/notifications from Duet wifi:
                                  Not yet.
                                  I will not be adding any new features to RRF2.
                                  No, just "major event" messages. Other devices can use HTTP requests rr_status and rr_model to get the data they want.
                                  • Lanovarundefined
                                    Lanovar
                                    Not yet.
                                    @dc42 Any news on that? 🙂
                                      Nightreaver
                                      For those who are interested...
                                      I took a similar solution for MQTT and adapted it to duet3d api endpoint.
                                      It works fine so far as im using it for myself, tho not all options for MQTT publishing are implemented yet.
                                      Feel free to try it and report bugs.
                                      https://github.com/Nightreaver/RRF_WebIF_MQTT
                                      • alankilianundefined
                                        alankilian
                                        I'll definitely try this mid-December after my current printing set is complete.
                                        One thing: In my MQTT experience, it's a good idea to have a topic like "State" where you set the last-will to publish with retain a payload of "Offline" and then in the connect routine, publish a payload of Online" with retain.
                                        That way, you can check the state easily without looking at any other topics.
                                        I see you have a last-will set, but I'm not familiar with those three systems, so I don't know if that's the by-the-book way to use last will. If so, ignore me.
                                        Also, it's also good to have a unique device ID in the topic so many devices can all publish to a broker and you can weed them out by which topics you subscribe to.
                                          Nightreaver
                                          I see, thats what LWT means! I will check up on that topic, thanks
                                            alankilian @Nightreaver
                                            @Nightreaver Cool.
                                            You can contact me anytime for MQTT-related discussions.
                                            I spent 4 years doing commercial MQTT implementations on tiny microcontrollers and have tens of thousands devices in the field talking all day long.
