    RepRapFirmware 3.0 is released!
    Firmware installation
    33
    131
    11.3k
    • matej1006undefined
      matej1006 @DIY-O-Sphere
      @DIY-O-Sphere Thanks
      • SIamundefined
        SIam
        i think there is a small bug in the Machinesettings E0 display the wrong settings:
        btw. I miss this feature in dwc2!
        Hypercube-Evolution-Hybrid, Piezo Orion, Orbiter
        Duet WiFi 1.02 or later + DueX5
        RepRapFirmware for Duet 2 WiFi/Ethernet 3.4.0beta4 (2021-09-27 11:30:36)
        Duet WiFi Server: 1.26
        Duet Web Control 3.4.0beta4 (2021-09-27)
          matej1006
          Can I control my water temperature (PWM noctua Fan's) with out selected heater in code, just with one sensor which measuring water temp.?
            dc42 administrators @matej1006
            @matej1006 said in RepRapFirmware 3.0 is released!:
            Yes, set up a sensor for the water temperature (M308), then set the fan to run thermostatically based on that sensor. In RRF3 the H parameter in the M106 command is the sensor number, not a heater number.
            matej1006undefined 1 Reply Last reply Reply Quote 1
              matej1006 @dc42
              Like that:
              ;Water temp
              M308 S5 P"e1temp" Y"thermistor" T100000 B4138                   ;configure sensor 5 as thermistor on pin e1temp
              M950 F0 C"!Fan0+exp.pb6" Q25000 				; fan 0 is a 4-wire PWM fan so invert it, use high PWM frequency, tacho connected to PB6 on expansion connector
              M106 H0 S1 T25
              and can i control 3 fan with one PWM output and one tacho input?
              • DIY-O-Sphereundefined
                DIY-O-Sphere @deckingman
                @deckingman
                Today I had to undo the change....👎
                (UTC+1)
                  Like that:
                  ;Water temp
                  M106 H0 S1 T25
                  You've created sensor 5 to read the water temperature and fan 0 to control the pump. So you need P0 H5 in the M106 command, not H0.
                  Yes you can parallel the wires of multiple 4-wire fans except for the tacho wires.
                  • DaBitundefined
                    DaBit
                    I just noticed that the PWM frequency for the heated bed seems a bit fast (I can see the LED dimming instead of flashing), especially for a 230VAC heater controlled by an SSR.
                    I see in the documentation that I can change the PWM frequency using the Q parameter in the M950 that creates the bead heater output, but what is the default frequency, and what is the minimum frequency? I would like to use a 2Hz or so, which is plenty in my case (10mm aluminium heated bed).
                    Maybe another thing for the RRF configurator, to add the Q parameter to the M950 that creates the bed heater?
                    • bulkaundefined
                      bulka
                      My questions are about z-probe and bed leveling.
                      I updated my Duet wifi 1.02 with these new firmware.
                      z-probe: if I understood correctly there are no g-code modification if I'm using Smart Effector ...it's true? ( I'm talking about gcode for zprobe)
                      bed leveling: the automatic leveling was removed? I tried to run the leveling from web interface and started with a manual leveling.
                      Thanks
                      Giulio
                      • Danalundefined
                        Danal @bulka
                        @bulka said in RepRapFirmware 3.0 is released!:
                        This indicates the firmware thinks that a probe is NOT defined. Which sort of answers your first question.
                        I believe you will, at minimum, need to add C"zstop" to your M558. That's assuming you have the smart effector plugged into the Z endstop pin.
                        Could you post your existing M558 please?
                        bulkaundefined 1 Reply Last reply Reply Quote 0
                          deckingman @DaBit
                          @DaBit I don't have that problem with my bed heater which is mains powered via SSR but I'm currently the other side of the world to my printer so can't say how it's configured. But IIRC, the default frequency for a bed heater is 10 Hz.
                          • Adamfilipundefined
                            Adamfilip
                            I keep running into error when homingall
                            G28 SetPosition called when DDA ring not empty
                              dc42 administrators @Adamfilip
                              @Adamfilip said in RepRapFirmware 3.0 is released!:
                              Please confirm that you are running version 3.0 (not beta or RC), and post your config.g file, homeall.g file, deployprobe.g and retractprobe.g files if you have them, and any other files that homeall.g calls.
                              Adamfilipundefined 1 Reply Last reply Reply Quote 0
                              • DaBitundefined
                                DaBit
                                @deckingman: I think RRF3 is a lot more generalised / has a lot less notion of specific pin functions than RRF2. It would not surprise me that a 'create heater output' M950 does not differentiate between different kind of heaters. Which is, IMHO, a good thing.
                                But the flipside is that the PWM frequency is also default, and probably quite high. Which does not work well for SSR's and especially the zero-crossing types; you can turn them on or off 100 times a second maximum (in the 50Hz EU). Thus, if one uses a 10Hz PWM frequency, the power can be regulated in 10% increments only, which is already not very high resolution. With a 500Hz PWM frequency the triggering of the SSR becomes a statistical function; a higher duty cycle makes it more likely that the SSR triggers at the zero crossing. It will regulate, but more in a bang-bang like fashion than a nicely controlled proportional fashion.
                                Since the thermal time constant of my heated bed is so large, I could easily get away with a 0.1Hz PWM frequency, but that increases thermal stress (wires in the heater heating up - cooling down - heating up - cooling down...), so 2-5Hz is a better option.
                                Which made me search for the limits on PWM frequency, which I did not find.
                                @Adamfilip : I got those 'G28 SetPosition called when DDA ring not empty' messages too after upgrading to RRF3, and in my case it had something to do with the endstop switches being setup in the wrong polarity. They were already triggered when the homing move started.
                                After fixing this, the message went away.
                                dc42undefined deckingmanundefined 2 Replies Last reply Reply Quote 0
                                  dc42 administrators @DaBit
                                  @DaBit said in RepRapFirmware 3.0 is released!:
                                  I still want to find out exactly what is causing this, so that I can fix it.
                                  • DaBitundefined
                                    DaBit
                                    In case it helps: here is my config bundle, or at least the latest backup: https://nextcloud.icecoldcomputing.com/s/YQo7Z7iEqfzDcXF
                                    When I invert the endstop polarity in de M574's at line 40-41 of config.g so that they are triggered when the printhead is nowhere near them, I also get this DDA ring error. It also shows up in the eventlog (also included in the ZIP), but no more information is logged there.
                                    RRF is the stable release ((2020-01-03b3), board is Duet2Wifi 1.02 or later, DWC is 2.0.4
                                    If you want access to the board to run tests or do some debugging, just ask and I will setup temporary SSH access that allows you to tunnel to the Duet.
                                      Adamfilip @dc42
                                      Yes running 3.0 not beta
                                      Here are config and homeall
                                      I dont have the others at the moment
                                      Config.------------------------------------------------------------
                                      ; generated by RepRapFirmware Configuration Tool v2.1.5 on Wed Jan 08 2020 19:38:55 GMT-0500 (Eastern Standard Time)
                                      G90                                              ; send absolute coordinates...
                                      M83                                              ; ...but relative extruder moves
                                      M550 P"TitanXY"                                  ; set printer name
                                      M667 S1                                          ; select CoreXY mode
                                      M552 S1                                          ; enable network
                                      M586 P0 S1                                       ; enable HTTP
                                      M586 P1 S0                                       ; disable FTP
                                      M586 P2 S0                                       ; disable Telnet
                                      M569 P0 S0                                      ; physical drive 0 goes backwards
                                      M569 P1 S0                                    ; physical drive 1 goes backwarsa
                                      M569 P2 S0                                       ; physical drive 2 goes backwards
                                      M569 P3 S0                                       ; physical drive 3 goes backwards
                                      M584 X0 Y1 Z2 E3                                 ; set drive mapping
                                      M350 X32 Y32 Z32 I0                              ; configure microstepping without interpolation
                                      M350 E16 I1                                      ; configure microstepping with interpolation
                                      M92 X400 Y400 Z1593 E409             ; set steps per mm
                                      M566 X600 Y600 Z20 E800 ; Set maximum instantaneous speed changes (mm/min)
                                      M203 X9000 Y9000 Z1500 E10000 ; Set maximum speeds (mm/min)
                                      M201 X1000 Y1000 Z250 E5000 ; Set accelerations (mm/s^2)
                                      M906 X1200 Y1200 Z1500 E1100 I30 ; Set motor currents (mA) and motor idle factor in per cent
                                      M84 S30 ; Set idle timeout
                                      M572 D0 S0.15 ; Pressure Advance                                        ; Set idle timeout
                                      M208 X0 Y0 Z0 S1                                 ; set axis minima
                                      M208 X270 Y270 Z300 S0                           ; set axis maxima
                                      M574 X1 S3                                    ; configure sensorless endstop for low end on X
                                      M574 Y1 S3                                    ; configure sensorless endstop for low end on Y
                                      ; BLTouch
                                      M950 H3 C"nil"                                 ; Disable heaters h7 to free up pins
                                      M950 S0 C"exp.heater3"                         ; create servo pin 0 for BLTouch
                                      M558 P9 C"^zprobe.in" H10 F800 T2000            ; set Z probe type to bltouch and the dive height + speeds
                                      G31 X20 Y0 Z3.3 P25 ; Z probe trigger value, offset in relation to nozzle. And trigger height adjustment
                                      M557 X15:215 Y15:195 S20                         ; define mesh grid
                                      M308 S0 P"bedtemp" Y"thermistor" T100000 B4138   ; configure sensor 0 as thermistor on pin bedtemp
                                      M950 H0 C"bedheat" T0                            ; create bed heater output on bedheat and map it to sensor 0
                                      M143 H0 S120                                     ; set temperature limit for heater 0 to 120C
                                      M307 H0 A61.9 C160.5 D1.3 B0 S0.5 v24.4          ; disable bang-bang mode for the nozzle heater and set PWM limit
                                      M308 S1 P"e0temp" Y"thermistor" T100000 B4725 C7.06e-8 ; configure sensor 1 as thermistor on pin e0temp
                                      M950 H1 C"e0heat" T1                             ; create nozzle heater output on e0heat and map it to sensor 1
                                      M143 H1 S285                                     ; set temperature limit for heater 1 to 280C
                                      M307 H1 A583.7 C261.1 D3.9 B0 S1.0 v24.3          ; disable bang-bang mode for the nozzle heater and set PWM limit
                                      M950 F0 C"fan0" Q500                             ; create fan 0 on pin fan0 and set its frequency
                                      M106 P0 S0 H-1                                   ; set fan 0 value. Thermostatic control is turned off
                                      M950 F1 C"fan1" Q500                             ; create fan 1 on pin fan1 and set its frequency
                                      M106 P1 S1 H1 T45                                ; set fan 1 value. Thermostatic control is turned on
                                      M950 F2 C"fan1" Q500                             ; create fan 2 on pin fan1 and set its frequency
                                      M106 P2 S1 H1 T45                                ; set fan 2 value. Thermostatic control is turned on
                                      M563 P0 D0 H1 F0                                 ; define tool 0
                                      G10 P0 X0 Y0 Z0                                  ; set tool 0 axis offsets
                                      G10 P0 R0 S0                                     ; set initial tool 0 active and standby temperatures to 0C
                                      Homeall ----------------------------------------------------------
                                      ; homeall.g
                                      ; called to home all axes
                                      M913 X75 Y75 Z100 ; reduce motor power
                                      M400 ; make sure everything has stopped before we make changes
                                      M915 H400 X Y S0 R0 F0 ; set X and Y to sensitivity 0, do nothing when stall, unfiltered
                                      M574 X1 Y1 S3 ; set endstops to use motor stall
                                      G91 ; use relative positioning
                                      G1 H2 Z5 F6000     ; lift Z relative to current position
                                      G4 P500 ; wait 500msec
                                      G1 H1 X-285 F2000 ; move quickly to X axis endstop and stop there (first pass)
                                      G1 X5 ; move away from home
                                      G1 H1 Y-285 F2000 ; move quickly to Y axis endstop and stop there (first pass)
                                      G1 Y5 ; move away from home
                                      G1 H2 Z10 F6000     ; lift Z relative to current position
                                      G1 X150 Y150 F1200 ; Centre Print head
                                      G1 H1 Z-305 F1800 ; move Z down until the endstop is triggered
                                      G92 Z0             ; set Z position to axis minimum (you may want to adjust this)
                                      M913 X100 Y100          ; XY motors to 100% current
                                      G90 ; back to absolute positioning
                                      • bulkaundefined
                                        bulka @Danal
                                        @Danal
                                        this is my M558
                                        M558 P5 R0.4 H1 F120 T6000
                                        thanks
                                        • bulkaundefined
                                          bulka
                                          This is the config;
                                          M574 X2 S1 P"xstop" ; Set active high endstops
                                          M574 Y2 S1 P"ystop"
                                          M574 Z2 S1 P"zstop"
                                          M558 P5 C"zstop" R0.4 H1 F120 T6000 ; Set Z probe type to effector and the dive height + speeds
                                          G31 P100 X0 Y0 Z-0.252 ; Set Z probe trigger value, offset and trigger height
                                          M557 R85 S20 ; Define mesh grid
                                          M308 S0 P"bed_temp" Y"thermistor" T100000 B4138 C0 R4700 ;
                                          M950 H0 C"bed_heat" T0 ; heater 0 uses the bed_heat pin, sensor 0
                                          M308 S1 P"spi.cs1" Y"rtd-max31865" ; define E0 temperature sensor
                                          M950 H1 C"e0_heat" T1 ; heater 1 uses the e0_heat pin and sensor 1
                                          M950 F0 C"fan0" ;
                                          M106 P0 S0 Q500 H-1 ;
                                          M950 F1 C"fan1" ;
                                          M106 P1 S1 Q500 H1 T45 ;
                                          M950 F2 C"fan2" ;
                                          M106 P2 S1 Q500 H1 ;
                                          added the bold part as you suggest but if try to run Delta calibration start on Manual calibration
                                          blt3dpundefined Dougal1957undefined 2 Replies Last reply Reply Quote 0
                                          • blt3dpundefined
                                            blt3dp @bulka
                                            This depends on where you have the probe plugged in, if it's the Smart Effector and plugged into the z endstop connector, that would be correct. But, usually it's plugged into the probe connector next to the expansion header. In that case what you put would be incorrect.
                                            If the probe connector, it should be
                                            M558 P5 R0.4 C"zprobe.in+zprobe.mod" H1 F120 T6000
                                            My 3D Printing YouTube Channel
                                            Better Living Through 3D Printing
                                            Follow me on Instagram and Twitter
                                            Instagram
                                            Twitter
