    RepRapFirmware 3.0 is released!
    Firmware installation
    33
    131
    12.4k
    • Danalundefined
      Danal @bulka
      @bulka said in RepRapFirmware 3.0 is released!:
      I tried to run the leveling from web interface and started with a manual leveling.
      This indicates the firmware thinks that a probe is NOT defined. Which sort of answers your first question.
      I believe you will, at minimum, need to add C"zstop" to your M558. That's assuming you have the smart effector plugged into the Z endstop pin.
      Could you post your existing M558 please?
      bulkaundefined 1 Reply Last reply Reply Quote 0
        deckingman @DaBit
        @DaBit I don't have that problem with my bed heater which is mains powered via SSR but I'm currently the other side of the world to my printer so can't say how it's configured. But IIRC, the default frequency for a bed heater is 10 Hz.
        • Adamfilipundefined
          Adamfilip
          I keep running into error when homingall
          G28 SetPosition called when DDA ring not empty
            dc42 administrators @Adamfilip
            @Adamfilip said in RepRapFirmware 3.0 is released!:
            Please confirm that you are running version 3.0 (not beta or RC), and post your config.g file, homeall.g file, deployprobe.g and retractprobe.g files if you have them, and any other files that homeall.g calls.
            Adamfilipundefined 1 Reply Last reply Reply Quote 0
            • DaBitundefined
              DaBit
              @deckingman: I think RRF3 is a lot more generalised / has a lot less notion of specific pin functions than RRF2. It would not surprise me that a 'create heater output' M950 does not differentiate between different kind of heaters. Which is, IMHO, a good thing.
              But the flipside is that the PWM frequency is also default, and probably quite high. Which does not work well for SSR's and especially the zero-crossing types; you can turn them on or off 100 times a second maximum (in the 50Hz EU). Thus, if one uses a 10Hz PWM frequency, the power can be regulated in 10% increments only, which is already not very high resolution. With a 500Hz PWM frequency the triggering of the SSR becomes a statistical function; a higher duty cycle makes it more likely that the SSR triggers at the zero crossing. It will regulate, but more in a bang-bang like fashion than a nicely controlled proportional fashion.
              Since the thermal time constant of my heated bed is so large, I could easily get away with a 0.1Hz PWM frequency, but that increases thermal stress (wires in the heater heating up - cooling down - heating up - cooling down...), so 2-5Hz is a better option.
              Which made me search for the limits on PWM frequency, which I did not find.
              @Adamfilip : I got those 'G28 SetPosition called when DDA ring not empty' messages too after upgrading to RRF3, and in my case it had something to do with the endstop switches being setup in the wrong polarity. They were already triggered when the homing move started.
              After fixing this, the message went away.
              dc42undefined deckingmanundefined 2 Replies Last reply Reply Quote 0
                dc42 administrators @DaBit
                @DaBit said in RepRapFirmware 3.0 is released!:
                I still want to find out exactly what is causing this, so that I can fix it.
                • DaBitundefined
                  DaBit
                  In case it helps: here is my config bundle, or at least the latest backup: https://nextcloud.icecoldcomputing.com/s/YQo7Z7iEqfzDcXF
                  When I invert the endstop polarity in de M574's at line 40-41 of config.g so that they are triggered when the printhead is nowhere near them, I also get this DDA ring error. It also shows up in the eventlog (also included in the ZIP), but no more information is logged there.
                  RRF is the stable release ((2020-01-03b3), board is Duet2Wifi 1.02 or later, DWC is 2.0.4
                  If you want access to the board to run tests or do some debugging, just ask and I will setup temporary SSH access that allows you to tunnel to the Duet.
                    Adamfilip @dc42
                    Yes running 3.0 not beta
                    Here are config and homeall
                    I dont have the others at the moment
                    Config.------------------------------------------------------------
                    ; generated by RepRapFirmware Configuration Tool v2.1.5 on Wed Jan 08 2020 19:38:55 GMT-0500 (Eastern Standard Time)
                    G90                                              ; send absolute coordinates...
                    M83                                              ; ...but relative extruder moves
                    M550 P"TitanXY"                                  ; set printer name
                    M667 S1                                          ; select CoreXY mode
                    M552 S1                                          ; enable network
                    M586 P0 S1                                       ; enable HTTP
                    M586 P1 S0                                       ; disable FTP
                    M586 P2 S0                                       ; disable Telnet
                    M569 P0 S0                                      ; physical drive 0 goes backwards
                    M569 P1 S0                                    ; physical drive 1 goes backwarsa
                    M569 P2 S0                                       ; physical drive 2 goes backwards
                    M569 P3 S0                                       ; physical drive 3 goes backwards
                    M584 X0 Y1 Z2 E3                                 ; set drive mapping
                    M350 X32 Y32 Z32 I0                              ; configure microstepping without interpolation
                    M350 E16 I1                                      ; configure microstepping with interpolation
                    M92 X400 Y400 Z1593 E409             ; set steps per mm
                    M566 X600 Y600 Z20 E800 ; Set maximum instantaneous speed changes (mm/min)
                    M203 X9000 Y9000 Z1500 E10000 ; Set maximum speeds (mm/min)
                    M201 X1000 Y1000 Z250 E5000 ; Set accelerations (mm/s^2)
                    M906 X1200 Y1200 Z1500 E1100 I30 ; Set motor currents (mA) and motor idle factor in per cent
                    M84 S30 ; Set idle timeout
                    M572 D0 S0.15 ; Pressure Advance                                        ; Set idle timeout
                    M208 X0 Y0 Z0 S1                                 ; set axis minima
                    M208 X270 Y270 Z300 S0                           ; set axis maxima
                    M574 X1 S3                                    ; configure sensorless endstop for low end on X
                    M574 Y1 S3                                    ; configure sensorless endstop for low end on Y
                    ; BLTouch
                    M950 H3 C"nil"                                 ; Disable heaters h7 to free up pins
                    M950 S0 C"exp.heater3"                         ; create servo pin 0 for BLTouch
                    M558 P9 C"^zprobe.in" H10 F800 T2000            ; set Z probe type to bltouch and the dive height + speeds
                    G31 X20 Y0 Z3.3 P25 ; Z probe trigger value, offset in relation to nozzle. And trigger height adjustment
                    M557 X15:215 Y15:195 S20                         ; define mesh grid
                    M308 S0 P"bedtemp" Y"thermistor" T100000 B4138   ; configure sensor 0 as thermistor on pin bedtemp
                    M950 H0 C"bedheat" T0                            ; create bed heater output on bedheat and map it to sensor 0
                    M143 H0 S120                                     ; set temperature limit for heater 0 to 120C
                    M307 H0 A61.9 C160.5 D1.3 B0 S0.5 v24.4          ; disable bang-bang mode for the nozzle heater and set PWM limit
                    M308 S1 P"e0temp" Y"thermistor" T100000 B4725 C7.06e-8 ; configure sensor 1 as thermistor on pin e0temp
                    M950 H1 C"e0heat" T1                             ; create nozzle heater output on e0heat and map it to sensor 1
                    M143 H1 S285                                     ; set temperature limit for heater 1 to 280C
                    M307 H1 A583.7 C261.1 D3.9 B0 S1.0 v24.3          ; disable bang-bang mode for the nozzle heater and set PWM limit
                    M950 F0 C"fan0" Q500                             ; create fan 0 on pin fan0 and set its frequency
                    M106 P0 S0 H-1                                   ; set fan 0 value. Thermostatic control is turned off
                    M950 F1 C"fan1" Q500                             ; create fan 1 on pin fan1 and set its frequency
                    M106 P1 S1 H1 T45                                ; set fan 1 value. Thermostatic control is turned on
                    M950 F2 C"fan1" Q500                             ; create fan 2 on pin fan1 and set its frequency
                    M106 P2 S1 H1 T45                                ; set fan 2 value. Thermostatic control is turned on
                    M563 P0 D0 H1 F0                                 ; define tool 0
                    G10 P0 X0 Y0 Z0                                  ; set tool 0 axis offsets
                    G10 P0 R0 S0                                     ; set initial tool 0 active and standby temperatures to 0C
                    Homeall ----------------------------------------------------------
                    ; homeall.g
                    ; called to home all axes
                    M913 X75 Y75 Z100 ; reduce motor power
                    M400 ; make sure everything has stopped before we make changes
                    M915 H400 X Y S0 R0 F0 ; set X and Y to sensitivity 0, do nothing when stall, unfiltered
                    M574 X1 Y1 S3 ; set endstops to use motor stall
                    G91 ; use relative positioning
                    G1 H2 Z5 F6000     ; lift Z relative to current position
                    G4 P500 ; wait 500msec
                    G1 H1 X-285 F2000 ; move quickly to X axis endstop and stop there (first pass)
                    G1 X5 ; move away from home
                    G1 H1 Y-285 F2000 ; move quickly to Y axis endstop and stop there (first pass)
                    G1 Y5 ; move away from home
                    G1 H2 Z10 F6000     ; lift Z relative to current position
                    G1 X150 Y150 F1200 ; Centre Print head
                    G1 H1 Z-305 F1800 ; move Z down until the endstop is triggered
                    G92 Z0             ; set Z position to axis minimum (you may want to adjust this)
                    M913 X100 Y100          ; XY motors to 100% current
                    G90 ; back to absolute positioning
                    • bulkaundefined
                      bulka @Danal
                      @Danal
                      this is my M558
                      M558 P5 R0.4 H1 F120 T6000
                      thanks
                      • bulkaundefined
                        bulka
                        This is the config;
                        M574 X2 S1 P"xstop" ; Set active high endstops
                        M574 Y2 S1 P"ystop"
                        M574 Z2 S1 P"zstop"
                        M558 P5 C"zstop" R0.4 H1 F120 T6000 ; Set Z probe type to effector and the dive height + speeds
                        G31 P100 X0 Y0 Z-0.252 ; Set Z probe trigger value, offset and trigger height
                        M557 R85 S20 ; Define mesh grid
                        M308 S0 P"bed_temp" Y"thermistor" T100000 B4138 C0 R4700 ;
                        M950 H0 C"bed_heat" T0 ; heater 0 uses the bed_heat pin, sensor 0
                        M308 S1 P"spi.cs1" Y"rtd-max31865" ; define E0 temperature sensor
                        M950 H1 C"e0_heat" T1 ; heater 1 uses the e0_heat pin and sensor 1
                        M950 F0 C"fan0" ;
                        M106 P0 S0 Q500 H-1 ;
                        M950 F1 C"fan1" ;
                        M106 P1 S1 Q500 H1 T45 ;
                        M950 F2 C"fan2" ;
                        M106 P2 S1 Q500 H1 ;
                        added the bold part as you suggest but if try to run Delta calibration start on Manual calibration
                        blt3dpundefined Dougal1957undefined 2 Replies Last reply Reply Quote 0
                        • blt3dpundefined
                          blt3dp @bulka
                          This depends on where you have the probe plugged in, if it's the Smart Effector and plugged into the z endstop connector, that would be correct. But, usually it's plugged into the probe connector next to the expansion header. In that case what you put would be incorrect.
                          If the probe connector, it should be
                          M558 P5 R0.4 C"zprobe.in+zprobe.mod" H1 F120 T6000
                          My 3D Printing YouTube Channel
                          Better Living Through 3D Printing
                          Follow me on Instagram and Twitter
                          Instagram
                          Twitter
                          • bulkaundefined
                            bulka @blt3dp
                            @blt3dp
                            tried with M558 P5 R0.4 C"zprobe.in+zprobe.mod" H1 F120 T6000 but nothing changed 😞
                            • Dougal1957undefined
                              Dougal1957 @bulka
                              @bulka is this a Duet Wifi or Duet3? and Am I right in thinking it is a smart effector?
                              • bulkaundefined
                                bulka @Dougal1957
                                @Dougal1957
                                I'm using this https://www.duet3d.com/DeltaSmartEffector
                                  Dougal1957 @bulka
                                  @bulka ok here is my config file using the same hardware.
                                  ; Configuration file for Duet WiFi (firmware version 1.17)
                                  ; generated by RepRapFirmware Configuration Tool on Fri Jul 07 2017 14:49:07 GMT+0100 (BST)
                                  M111 S0 ; Debugging off
                                  G21 ; Work in millimetres
                                  M555 P2 ; Set firmware compatibility to look like Marlin
                                  ;*** The homed height is deliberately set too high in the following - you will adjust it during calibration.
                                  M665 L450.570 R239.241 H400.083 B175.0 X0.081 Y0.091 Z0.000    ; Set delta radius, diagonal rod length, printable radius and homed height
                                  M666 X0.315 Y0.808 Z-1.123 A0.20 B0.02                         ; Put your endstop adjustments here, or let auto calibration find them
                                  ;M665 L450.570 R239.403 H400.898 B175.0 X0.191 Y0.213 Z0.000  ; Set delta radius, diagonal rod length, printable radius and homed height
                                  ;M666 X0.392 Y0.645 Z-1.037 A0.12 B-0.07  ; Put your endstop adjustments here, or let auto calibration find them
                                  M208 Z0 S1 ; Set minimum Z
                                  M574 X2 Y2 Z2 S1 ; Define active high microswitches
                                  M558 P5 C"^zprobe.in" X0 Y0 Z0 H5 R0.4 F1200 T6000 ; Set Z probe type to unmodulated, the axes for which it is used and the probe + travel speeds
                                  G31  P100 X0 Y0 Z-0.05; Set Z probe trigger value, offset and trigger height
                                  M557 R160 S20 ; Define mesh grid
                                  M569 P0 S0 ; Drive 0 goes forwards
                                  M569 P1 S0 ; Drive 1 goes forwards
                                  M569 P2 S0 ; Drive 2 goes forwards
                                  M92 X200 Y200 Z200 E1667 ; Set steps per mm
                                  M566 X900 Y900 Z900 E40 ; Set maximum instantaneous speed changes (mm/min)
                                  M203 X18000 Y18000 Z18000 E2400 ; Set maximum speeds (mm/min)
                                  M201 X1000 Y1000 Z1000 E120 ; Set accelerations (mm/s^2)
                                  M906 X1000 Y1000 Z1000 E500 I30 ; Set motor currents (mA) and motor idle factor in per cent
                                  M143 S300 ; Set maximum heater temperature to 300C
                                  ;M305 P0 X201 ; Set thermistor + ADC parameters for heater 0 and remap it to channel 201
                                  ;M305 P1 X200 ; Set thermistor + ADC parameters for heater 1 and remap it to channel 200
                                  M308 S0 P"spi.cs2" Y"rtd-max31865" F50
                                  M308 S1 P"spi.cs1" Y"rtd-max31865" F50
                                  ;M307 H0 A199.0 C962.6 D5 B0
                                  ;M307 H1 A409.7 C232.2 D4.5 B0
                                  ;M307 H0 A161.6 C1109.8 D5.8 S1.00 V24.4 B0
                                  M307 H0 A449.1 C783.3 D9.8 S1.00 V24.4 B0
                                  M307 H1 A544.9 C280.1 D4.2 S1.00 V24.4 B0
                                  M563 P0 D0 H1 F2; Define tool 0
                                  M550 PDelta ; Set machine name
                                  M552 S1 ; Enable network
                                  ; Access point is configured manually via M587 by the user
                                  M586 P0 S1 ; Enable HTTP
                                  M586 P1 S1 ; Enable FTP
                                  M586 P2 S0 ; Disable Telnet
                                  M106 P0 H-1 ; Set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned off
                                  ;M106 P1 S1 I0 F500 H1 T45 ; Set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned on
                                  ;M106 P2 S1 I0 F500 H-1 ; Set fan 2 value, PWM signal inversion and frequency. Thermostatic control is turned off
                                  M563 P0 D0 H1
                                  M564 H0
                                  T0
                                  G28
                                  ;G29 S1
                                  ;M572 D0 S0.05    ; set pressure advance
                                  M501
                                  This works I am on RRF 3.0 on my Wifi board
                                  Hopefully this will help you
                                  note the probe settings for the smart effector
                                    deckingman @DaBit
                                    @DaBit I'll check my settings when I get back home in 8 days or so. I suspect that I'm using 10Hz because that is what I've always used. IIRC that figure of 10Hz was chosen specifically to suit SSRs. However, do not confuse the PWM frequency with the mark-space ratio that is PWM itself. And also, don't forget that the thermal mass of the aluminium plate acts as a huge damper to the conduction of heat through the plate, which makes the PWM frequency largely irrelevant.
                                    • blt3dpundefined
                                      blt3dp
                                      @bulka
                                      You have a bed.g file?
                                      Instagram
                                      Twitter
                                      • bulkaundefined
                                        bulka @blt3dp
                                        @blt3dp
                                        yes 🙂
                                        @Dougal1957
                                        thank you, now it's working , ^zprobe.in was the right choice.
                                        Dougal1957undefined 1 Reply Last reply Reply Quote 1
                                          Dougal1957 @bulka
                                          @bulka Glad to be of help
                                          Doug
                                          • garyd9undefined
                                            garyd9
                                            The documentation for converting M558 to RRF3 is a bit confusing in regards to the "I" parameter. In particular, it doesn't say anything about it (in that section)
                                            https://duet3d.dozuki.com/Wiki/RepRapFirmware_3_overview#Section_M558
                                            As well, the gcode wiki page also seems to imply that "M558 I1" is valid (https://duet3d.dozuki.com/Wiki/Gcode#Section_M558_Set_Z_probe_type)
                                            "All of the above for RepRapFirmware 2.x relates to RepRapFirmware 3, except the following:" (and nothing that follows makes mention of the I param.)
                                            Yet, from reading this thread, I get the impression that RRF2:
                                            M558 P8 I1 R0.4 F300 H3
                                            does not work in RRF3 as:
                                            M558 P8 R0.4 I1 C"zprobe.in" H3 F300
                                            and instead should be written as:
                                            M558 P8 R0.4 C"!zprobe.in" H3 F300 ; I1 removed, ! prepended to zprobe.in
                                            Edit: I accidentally left the "I1" in my 558 after converting, and had the ! before the pin. The result apparently was a double inversion. Removing the I1 and leaving the "!" made everything seem to work.
                                            So ... which is the proper way?
