    BLtouch with Reprap Firmware 3.0
    27
    3.6k
    • CupaCabraundefined
      CupaCabra
      ; generated by RepRapFirmware Configuration Tool v2.1.5 on Thu Jan 09 2020 09:19:35 GMT+0100 (Mitteleuropäische Normalzeit)
      M550 P"My Printer" ; set printer name
      M667 S1 ; select CoreXY mode
      M551 P"123456" ; set password
      M552 S1 ; enable network
      M586 P0 S1 ; enable HTTP
      M586 P1 S0 ; disable FTP
      M586 P2 S0 ; disable Telnet
      M569 P4 S1 ; physical drive 4 goes forwards
      M584 X0 Y1 Z2 E3:4 ; set drive mapping
      M92 X80.00 Y80.00 Z4000.00 E415.00:415.00 ; set steps per mm
      M566 X900.00 Y900.00 Z12.00 E120.00:120.00 ; set maximum instantaneous speed changes (mm/min)
      M203 X6000.00 Y6000.00 Z180.00 E1200.00:1200.00 ; set maximum speeds (mm/min)
      M201 X500.00 Y500.00 Z20.00 E250.00:250.00 ; set accelerations (mm/s^2)
      M906 X1000 Y1000 Z1400 E1000:1000 I30 ; set motor currents (mA) and motor idle factor in per cent
      M84 S30 ; Set idle timeout
      M208 X400 Y400 Z500 S0 ; set axis maxima
      ;M574 Z1 S2
      ; BLTouch - Heaters
      ;M307 H3 A-1 C-1 D-1 ; Disable the 7th Heater to free up PWM channel 5 on the Duex board.
      M950 H3 C"nil"
      ;M950 H4 C"nil"
      ;M950 H5 C"nil"
      ;M950 H6 C"nil"
      ;M950 H7 C"nil" ; Disable heaters h7 to free up pins
      M950 S0 C"exp.heater3" ; create servo pin 0 for BLTouch
      M558 P9 C"^zprobe.in" H5 F100 T2000 ; set Z probe type to bltouch and the dive height + speeds
      G31 X20 Y0 Z3.3 P25 ; Z probe trigger value, offset in relation to nozzle. And trigger height adjustment
      M557 X50:350 Y50:350 S50 ; define mesh grid
      M307 H0 B0 S1.00 ; disable bang-bang mode for the nozzle heater and set PWM limit
      M307 H1 B0 S1.00 ; disable bang-bang mode for the nozzle heater and set PWM limit
      M308 S2 P"e1temp" Y"thermistor" T100000 B4138 ; configure sensor 2 as thermistor on pin e1temp
      M950 H2 C"e1heat" T2 ; create nozzle heater output on e1heat and map it to sensor 2
      M143 H2 S280 ; set temperature limit for heater 2 to 280C
      M307 H2 B0 S1.00 ; disable bang-bang mode for the nozzle heater and set PWM limit
      M106 P1 S1 H1:2 T45 ; set fan 1 value. Thermostatic control is turned on
      M950 F2 C"fan2" Q500 ; create fan 2 on pin fan2 and set its frequency
      M106 P2 S1 H1:2 T45 ; set fan 2 value. Thermostatic control is turned on
      M563 P1 H2 F0 ; define tool 1
      I have the BLTouch wired on Heater3 (PIN8) on the Duet Wifi Board.
      i take the G-Code to test M401 / M402
      or
      M280 P3 S10 I1
      M280 P3 S160 I1
      M280 P3 S120 I1
      nothing move it.
      With the old Firmeware 2.05 the Pin Move in and out.
      DIY-O-Sphereundefined 1 Reply Last reply Reply Quote 0
      • DIY-O-Sphereundefined
        DIY-O-Sphere
        @CupaCabra said in BLtouch with Reprap Firmware 3.0:
        Have you also adapted deployprobe.g and retractprobe.g?
        (UTC+1)
          DIY-O-Sphere @CupaCabra
          M280 P3 S10 I1
          M280 P3 S160 I1
          M280 P3 S120 I1
          Now you have to use
          M280 P0 S10
          M280 P0 S160
          M280 P0 S120
          (UTC+1)
          CupaCabraundefined 1 Reply Last reply Reply Quote 0
            CupaCabra
            yes i have but i don´t now is it right.
            deployprobe.g
            M280 P3 S10 I1
            and in retractprobe.g
            M280 P3 S90 I1
            i hope there are right
              DIY-O-Sphere
              change P3 to P0 and remove I1
              (UTC+1)
                CupaCabra @DIY-O-Sphere
                @DIY-O-Sphere
                i change the Code in the Config now an test it.
                  CupaCabra
                  It´works with
                  M280 P3 S10 ......
                  thx so lot 🙂
                    droftarts administrators @CupaCabra
                    @CupaCabra Great! Please post the 'Z-Probe' section of your config.g to show how you resolved this!
                    Also, you don't need to unassign the heater channels in RRF3 with M950 H3 C"nil", as they are not assigned by default. Only a few pins are assigned by default, and only need to be unassigned if you use them for something else; see https://duet3d.dozuki.com/Wiki/RepRapFirmware_3_overview#Section_Duet_2_WiFi_Ethernet_and_Duet_2_Maestro
                      DIY-O-Sphere
                      M280 P3 S10 ......
                      Now I am confused.
                      You will find exact your configuration in
                      https://duet3d.dozuki.com/Wiki/Gcode#Section_M280_Set_servo_position
                      And we have done it succesfully on a buddys wifi exact that way with heater7.
                      Are you shure you have update to the stable and not to a older beta.
                      I think there you had to trigger the heater instead of the servo channel.
                      (UTC+1)
                        DIY-O-Sphere
                        @droftarts said in BLtouch with Reprap Firmware 3.0:
                        The beta would explain that too.
                        (UTC+1)
                          CupaCabra
                          so i have change the
                          deployprobe.g
                          M280 P3 S10
                          retractprobe.g
                          M280 P3 S90
                          if i test with a Marco file
                          The pin go´s out with S10 und retract with S90
                          I think it´s right.
                            CupaCabra
                            ;M574 Z1 S2
                            ; BLTouch - Heaters
                              CupaCabra
                              the
                              Firmware : 3.0 (2020-01-03b3)
                              WiFi Server Version: 1.23
                              Web Interface: 1.22.6
                              • LowLanderundefined
                                LowLander
                                Thanks to this thread I've made progress getting my BLtouch to work. I do have a few questions still.
                                Basic info:
                                Duet WiFi 1.02 running RRF3
                                BLtouch V3.1
                                The BLtouch is wired as follows:
                                White Wire (Z signal) = Z Probe IN
                                Orange (Servo Sig) = Heater3
                                Red (5v) = +5V
                                Brown (GND) = GND
                                Questions (I have googled, but can't find clear answers anywhere):
                                • When I start the printer, the BLtouch performs a self test. This results in the pin being up, and the red led on the BLtouch being on. Is that correct?
                                • When I do a M280 P0 S10 the pin drops. The red led is off, but a blue led is on now. Is that correct?
                                • M280 P0 S10 I1 gives the same result. Is it supposed to work with and without the I1 parameter?
                                • M280 P0 S90 retracts the pin, the red led is on as well as the blue led. Is that correct?
                                Thanks in advance!
                                  DIY-O-Sphere
                                  @LowLander said in BLtouch with Reprap Firmware 3.0:
                                  M280 P0 S10 I1
                                  https://duet3d.dozuki.com/Wiki/RepRapFirmware_3_overview#Section_M280
                                  You can remove the I1
                                  I have the same optical signalling, so everything looks fine...
                                  (UTC+1)
                                  LowLanderundefined 1 Reply Last reply Reply Quote 0
                                  • Adamfilipundefined
                                    Adamfilip
                                    The line is there in config
                                      dc42 administrators @Adamfilip
                                      @Adamfilip said in BLtouch with Reprap Firmware 3.0:
                                      Thanks, somehow I missed that.
                                        LowLander @DIY-O-Sphere
                                        @DIY-O-Sphere thanks for confirming that.
                                        • radekzlundefined
                                          radekzl
                                          today I tried upgrade firmware on my Duet Wifi from 2.05.1 to 3.01RC6. Upgrade was successfull but unfortunately my BL Touch not work after upgrade.
                                          I connected BL TOUCH according to this manual:
                                          https://betrue3d.dk/bltouch-on-duet-wifi-configuratio-and-usage/
                                          With FW version 2.05.1 BL TOUCH worked OK. I understand that I must edit config.g, deployprobe.g, retractprobe.g and home files. I did it, but BL TOUCH not work. After power on BL TOUCH did self test, but thats all. Commands M401, M402 or M280 from console not work and homez and home all not work too.
                                          Here is my config.g:
                                          ; generated by RepRapFirmware Configuration Tool on Fri Feb 01 2019 23:24:57 GMT+0100 (Středoevropský standardní čas)
                                          M555 P1 ; Set firmware compatibility to look like RepRapFirmare
                                          M550 PZBox Mk. I ; Set machine name
                                          M552 S1 ; Enable network
                                          M587 S"kluci" P"" ; Configure access point. You can delete this line once connected
                                          M586 P0 S1 ; Enable HTTP
                                          M586 P1 S1 ; Enable FTP
                                          M586 P2 S0 ; Disable Telnet
                                          M584 X0 Y1:6 Z2 U5 E3:4 ; Create U axis for second X carriage before we try to configure it
                                          M569 P0 S1 D2 ; Drive 0 goes forwards
                                          M569 P1 S0 D2 ; Drive 1 goes forwards
                                          M569 P2 S0 D2 ; Drive 2 goes forwards
                                          M569 P3 S1 D2 ; Drive 3 goes forwards
                                          M569 P4 S0 D2 ; Drive 4 goes forwards
                                          M569 P5 S0 D2 ; Drive 5 goes forwards
                                          M569 P6 S1 D2 ; Drive 5 goes forwards
                                          ; Laser sensor
                                          M591 D0 P5 C"zstop" R5:130 E6.0 S1 ; Duet3D laser sensor for extruder drive 0 is connected to endstop input 3 (E0), tolerance 40 to 120%, 3mm comparison length
                                          M591 D0 ; display filament sensor parameters for extruder drive 0
                                          M591 D1 P5 C"e1stop" R15:250 E6.0 S1 ; Duet3D laser sensor for extruder drive 0 is connected to endstop input 3 (E0), tolerance 40 to 120%, 3mm comparison length
                                          M591 D1 ; display filament sensor parameters for extruder drive 0
                                          M350 X256 Y256:256 U256 Z256 E256:256 I0 ; Configure microstepping without interpolation
                                          M201 X700 Y700:700 U700 Z15 E800 ; Accelerations (mm/s^2)
                                          M203 X5000 Y5000 U5000 Z100 E3600 ; Maximum speeds (mm/min)
                                          M566 X450 Y450 U450 Z30 E20 ; Maximum jerk speeds mm/minute
                                          M208 X0:276 Y-75:200 U-59:208 Z-10:200 ; Set axis minima:maxima (adjust to suit your machine) x-60:216 u0:250
                                          M92 X2582.48954 Y2593.77082 U2579.6913 Z6546.644 ; Set axis steps/mm
                                          M92 E6592.55:6592.55 ; Set extruder steps per mm
                                          M906 X600 Y700:700 U600 Z500 E1000:1000 I20 ; Set motor currents (mA) and motor idle factor in per cent
                                          M574 X2 S1 P"xstop" ; Set active high endstops
                                          M574 Y2 S1 P"ystop" ; Set active high endstops
                                          M574 U1 S1 P"e0stop" ; Set active high endstops
                                          M574 Z1 S2 ; Z has no endstop
                                          ; Disable heaters H3-H7 to free up pins
                                          M950 H3 C"nil"
                                          M950 H4 C"nil"
                                          M950 H5 C"nil"
                                          M950 H6 C"nil"
                                          M950 H7 C"nil"
                                          ;M307 H7 A-1 C-1 D-1 ; Disable heater on PWM channel for BLTouch
                                          M950 S0 C"exp.heater7" ; create servo pin 0 for BLTouch
                                          M558 P9 C"^zprobe.in" H5 F800 T3000 ; Set Z probe type to bltouch and the dive height + speeds
                                          G31 P25 X1.0 Y-31.25 Z1 ; Set Z probe trigger value, offset and trigger height Z+ pousouva osu Z smerem dolu k podlozce (stará tisková hlava X7.9 Y58.8)
                                          M557 X15:195 Y5:175 S20 ; Define mesh grid
                                          ;M307 H7 A-1 C-1 D-1 ; Disable bang-bang mode for the bed heater and set PWM limit
                                          M308 S0 P"bedtemp" Y"thermistor" T100000 B4138 C0 R4700 ; Set thermistor + ADC parameters for heater 0
                                          ; Hot end - levý
                                          ;M305 P1 X200
                                          M308 S1 P"spi.cs1" Y"rtd-max31865" A"EXTRUDER LEVY" ; Configure thermocouple for heater 1
                                          M307 H1 A361.3, C127.9, D11.9 S1
                                          M143 H1 S400 ; Set temperature limit for heater 1 to 280C
                                          ; Hot end - pravý
                                          ;M305 P2 X201
                                          M308 S2 P"spi.cs2" Y"rtd-max31865" A"EXTRUDER PRAVY" ; Configure thermocouple for heater 2
                                          M307 H2 A364.1 C146.0 D4.5 S1.00 V23.8 B0
                                          M143 H2 S300 ; Set temperature limit for heater 2 to 280C
                                          M308 S3 Y"drivers" A"DRIVERS" ; configure sensor 2 as temperature warning and overheat flags on the TMC2660 on Duet
                                          M308 S4 Y"mcu-temp" A"MCU" ; configure sensor 3 as thermistor on pin e1temp for left stepper
                                          ;M305 P101 X1001 S"Drivers Duet" ; Temperature of drivers Duet
                                          ;M305 P102 x1002 S"Drivers Duex5" ; Temperature of drivers Duex5
                                          M950 F1 C"fan1"
                                          M106 P1 H1 T45 ; Set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned on
                                          M950 F0 C"fan0"
                                          M106 P0 H2 T45 ; Set fan 2 value, PWM signal inversion and frequency. Thermostatic control is turned on
                                          M950 F3 C"duex.fan3"
                                          M106 P3 H-1 C"Chlazeni levy"
                                          M950 F4 C"duex.fan4"
                                          M106 P4 H-1 C"Chlazeni pravy"
                                          M950 F5 C"duex.fan5"
                                          M106 P5 T32:40 H100:101:102 C"Duet Fan" ;cooling fan that starts to turn on when the MCU temperature (virtual heater 100) reaches 45C and reaches full speed when the MCU temperature reaches 65C or if any TMC2660 drivers (virtual heaters 101 and 102) report that they are over-temperature
                                          M563 P0 D0 H1 X3 F3 ; Define tool 0
                                          G10 P0 X0 Y0 U0 Z0 ; Set tool 0 axis offsets
                                          M563 P1 D1 H2 F4 ; Define tool 1
                                          G10 P1 X0 Y0.05 U9.6 Z0.4 ; Set tool 1 axis offsets
                                          G10 P1 R0 S0 ; Set initial tool 1 active and standby temperatures to 0C
                                          ;Pressure advance
                                          ;M572 D0:1 S0.05:0.05
                                          Here is my homeall.g:
                                          ; homeall.g
                                          ; called to home all axes
                                          G91 ; relative positioning
                                          G1 Z5 F6000 H2 ; lift Z relative to current position
                                          G1 H1 X515 Y515 U-515 F1800 ; move quickly to X and Y axis endstops and stop there (first pass)
                                          G1 X-5 Y-5 U5 F6000 ; go back a few mm
                                          G1 H1 X215 Y215 U-215 F360 ; move slowly to X and Y axis endstops once more (second pass)
                                          G90 ; absolute positioning
                                          G1 X100 Y100 F6000 ; go to first bed probe point and home Z
                                          Here is my homez.g:
                                          ; homez.g
                                          ; called to home the Z axis
                                          T1
                                          G1 X100 Y100 F6000 ; go to first probe point
                                          Here is my deployprobe.g:
                                          ; deployprobe.g
                                          ; called to deploy a physical Z probe
                                          M280 P0 S10
                                          Here is my retractprobe.g:
                                          ; retractprobe.g
                                          ; called to retract a physical Z probe
                                          M280 P0 S90
                                          I do not know, what is wrong. Can you help me please?
                                          Thank you very much.
                                            Phaedrux Moderator @radekzl
                                            @radekzl Please start a new thread for your issue.
