    RepRapFirmware 3.01beta1 released
    Beta Firmware
    16
    60
    3.4k
    • kraegarundefined
      kraegar
      Got a macro in testing for iterating on bed leveling, and it's pretty amazing!
      My initial round had two && in one line, which caused the duet to hard crash and reboot. I switched it to nested if statements, and that worked well. I want to tweak it a bit, but definitely working!
      ( was iterating until initialDeviation was < 0.01 AND deviation was within 0.002 of initialDeviation)
      • kraegarundefined
        kraegar
        Cleaned up the output to make it easier to follow. (also changed my leadscrew locations to make it take longer to converge for these tests, so I could troubleshoot easier)
          dc42 administrators @kraegar
          @kraegar said in RepRapFirmware 3.01beta1 released:
          Can you provide that version, so that I can fix it?
          • kraegarundefined
            kraegar
            This post is deleted!
            • kraegarundefined
              kraegar
              Here is the version that works well:
              M561                         ; clear any existing bed transform
              ; If the printer hasn't been homed, home it
              if !move.axes[0].homed || !move.axes[1].homed || !move.axes[2].homed
                G28
              G1 Z7.5
              ;Run initial 4 point leveling routine
              G30 P0 X15 Y45 Z-99999
              G30 P1 X15 Y227.5 Z-99999
              ;G30 P2 X235 Y125 Z-99999 S3
              G30 P2 X235 Y227.5 Z-99999
              G30 P3 X235 Y45 Z-99999 S3
              while true
                if iterations = 5
                  abort "Too many auto calibration attempts"
                if move.initialDeviation.deviation < 0.01
                  if move.calibrationDeviation.deviation < move.initialDeviation.deviation + 0.005
                    if move.calibrationDeviation.deviation > move.initialDeviation.deviation - 0.005
                      break
                echo "Repeating calibration because initial deviation (" ^ move.initialDeviation.deviation ^ "mm) must be < 0.01"
                echo "and (" ^ move.calibrationDeviation.deviation ^ "mm) must be within 0.005 of initialDeviation"
              echo "Auto calibration successful, deviation", move.calibrationDeviation.deviation ^ "mm"
              echo "Auto calibration successful, initialDeviation", move.initialDeviation.deviation ^ "mm"
              G28 Z
              G1 X0 Y0 F24000               ; move the head to the corner (optional)
              And removing the nested if's to replace with && crash it
                if move.initialDeviation.deviation < 0.01 && move.calibrationDeviation.deviation < move.initialDeviation.deviation + 0.005 && move.calibrationDeviation.deviation > move.initialDeviation.deviation - 0.005
                      break
              Edit: I realize I could just have some major syntax issues, still figuring this out. But that's a hard crash if you do that 🙂
              dc42undefined garyd9undefined 2 Replies Last reply Reply Quote 0
              • carlossprundefined
                carlosspr @carlosspr
                @carlosspr Solved. I was missing M584 drive mapping on config.g
                  Thanks, I've reproduced the crash by adding that line to my own script. I will look into it. Even if you do make a syntax error, you should get a helpful error message.
                  PS - now I know that the new crash handler I added for uncaught exceptions works!
                  Last software reset at 2020-01-15 16:35, reason: Terminate called, spinning module GCodes, available RAM 9464 bytes (slot 2)
                  • kraegarundefined
                    kraegar
                    Trying to test if move.initialDeviation.deviation is 0.000
                    if move.initialDeviation.deviation != 0
                      echo "one " ^ move.initialDeviation.deviation
                    I've tried using 0.000 as well, with the same result. == 0.000 or == 0 doesn't match, even though it is.
                    (I'm trying to determine if leveling has been run at all yet, my only clear method for now is to see if initial and calirbated deviation and mean are all 0.000)
                      Just done some tests. There is a problem with equality between floats.
                      The other problem you had is because the GCode line was too long. I changed it to throw an exception when that happens, but the exception isn't caught.
                      This is all very new code, so I was expecting some bugs.
                      • kraegarundefined
                        kraegar
                        Yep, I'm just playing, happy to just keep reporting. Variables will clean the code up a lot, but that's a big ask 🙂
                        • kraegarundefined
                          kraegar
                          Once variables are implemented, if they're "system wide" and not constrained to the macro they're called in, I would set a "is_level = false" in config.g, and set to true once leveling is run. Negating the need for this method of checking.
                          But I can't resist playing 🙂
                            Thanks for your reports. These two issues are now fixed in the latest builds at https://www.dropbox.com/sh/3azy1njy3ayjsbp/AACquxr2m00eV568RZg5QG5wa?dl=0.
                            • kraegarundefined
                              kraegar
                              Can I just say, HUGE thank you!
                              I've already made a script to tune PA, Temp, and Extrusion % (just call the macros via layer change) as well as the auto-leveling and a "pre-print" systems readiness check.
                              This is amazing!
                              • kraegarundefined
                                kraegar
                                Float comparisons are now working, and the other errors gracefully:
                                Error: in file macro, line 20 column 1: GCode command too long
                                Thanks!
                                  Thanks for confirming. FWIW, maximum GCode line length excluding leading white space, line number and checksum (if present) and comments is currently 160 characters.
                                  DIY-O-Sphereundefined gtj0undefined 2 Replies Last reply Reply Quote 1
                                  • kraegarundefined
                                    kraegar
                                    We're going to need line numbers in the file editor in DWC now 🙂
                                    • 4latheundefined
                                      4lathe
                                      Can I use that new duet2combinedfirmware.bin on my maestro? The 3.01 was duetmaestrofirmware.bin.
                                      DIY-O-Sphereundefined 1 Reply Last reply Reply Quote 0
                                      • DIY-O-Sphereundefined
                                        DIY-O-Sphere @4lathe
                                        @4lathe
                                        It's still DuetMaestroFirmware.bin
                                        (UTC+1)
                                          DIY-O-Sphere @dc42
                                          Hi David, maybe I have found a bug....
                                          For testing I was back on 2.05 on a Maestro (DWC 2.06) and I was not able to get back directly to 3.01b.
                                          Flashing 3.0 stable worked.
                                          (UTC+1)
                                            dc42 administrators @DIY-O-Sphere
                                            @DIY-O-Sphere said in RepRapFirmware 3.01beta1 released:
                                            Read the upgrade notes!
