    RepRapFirmware 3.01beta1 released
    Beta Firmware
    16
    60
    3.5k
      dc42 administrators @kraegar
      @kraegar said in RepRapFirmware 3.01beta1 released:
      And removing the nested if's to replace with && crash it
      Thanks, I've reproduced the crash by adding that line to my own script. I will look into it. Even if you do make a syntax error, you should get a helpful error message.
      PS - now I know that the new crash handler I added for uncaught exceptions works!
      Last software reset at 2020-01-15 16:35, reason: Terminate called, spinning module GCodes, available RAM 9464 bytes (slot 2)
      • kraegarundefined
        kraegar
        Trying to test if move.initialDeviation.deviation is 0.000
        if move.initialDeviation.deviation != 0
          echo "one " ^ move.initialDeviation.deviation
        I've tried using 0.000 as well, with the same result. == 0.000 or == 0 doesn't match, even though it is.
        (I'm trying to determine if leveling has been run at all yet, my only clear method for now is to see if initial and calirbated deviation and mean are all 0.000)
          Just done some tests. There is a problem with equality between floats.
          The other problem you had is because the GCode line was too long. I changed it to throw an exception when that happens, but the exception isn't caught.
          This is all very new code, so I was expecting some bugs.
          • kraegarundefined
            kraegar
            Yep, I'm just playing, happy to just keep reporting. Variables will clean the code up a lot, but that's a big ask 🙂
            • kraegarundefined
              kraegar
              Once variables are implemented, if they're "system wide" and not constrained to the macro they're called in, I would set a "is_level = false" in config.g, and set to true once leveling is run. Negating the need for this method of checking.
              But I can't resist playing 🙂
                Thanks for your reports. These two issues are now fixed in the latest builds at https://www.dropbox.com/sh/3azy1njy3ayjsbp/AACquxr2m00eV568RZg5QG5wa?dl=0.
                • kraegarundefined
                  kraegar
                  Can I just say, HUGE thank you!
                  I've already made a script to tune PA, Temp, and Extrusion % (just call the macros via layer change) as well as the auto-leveling and a "pre-print" systems readiness check.
                  This is amazing!
                  • kraegarundefined
                    kraegar
                    Float comparisons are now working, and the other errors gracefully:
                    Error: in file macro, line 20 column 1: GCode command too long
                    Thanks!
                      Thanks for confirming. FWIW, maximum GCode line length excluding leading white space, line number and checksum (if present) and comments is currently 160 characters.
                      DIY-O-Sphereundefined gtj0undefined 2 Replies Last reply Reply Quote 1
                      • kraegarundefined
                        kraegar
                        We're going to need line numbers in the file editor in DWC now 🙂
                        • 4latheundefined
                          4lathe
                          Can I use that new duet2combinedfirmware.bin on my maestro? The 3.01 was duetmaestrofirmware.bin.
                          DIY-O-Sphereundefined 1 Reply Last reply Reply Quote 0
                          • DIY-O-Sphereundefined
                            DIY-O-Sphere @4lathe
                            @4lathe
                            It's still DuetMaestroFirmware.bin
                            (UTC+1)
                              DIY-O-Sphere @dc42
                              Hi David, maybe I have found a bug....
                              For testing I was back on 2.05 on a Maestro (DWC 2.06) and I was not able to get back directly to 3.01b.
                              Flashing 3.0 stable worked.
                              (UTC+1)
                                dc42 administrators @DIY-O-Sphere
                                @DIY-O-Sphere said in RepRapFirmware 3.01beta1 released:
                                Read the upgrade notes!
                                • gtj0undefined
                                  gtj0 @dc42
                                  @dc42 said in RepRapFirmware 3.01beta1 released:
                                  Are you sending them via text message??? 🙂
                                    DIY-O-Sphere @dc42
                                    Sorry....The one who can read is in advantage
                                    (UTC+1)
                                      dc42 administrators @gtj0
                                      @gtj0 said in RepRapFirmware 3.01beta1 released:
                                      Hadn't you noticed your smartphone bills going up every time you print? 😉
                                      gtj0undefined 1 Reply Last reply Reply Quote 1
                                      • gtj0undefined
                                        gtj0 @dc42
                                        Ah that makes sense now. I though it was the cat texting his buddy across the street.
                                        • garyd9undefined
                                          garyd9 @kraegar
                                          Here is the version that works well:
                                          I like this, but it seems unnatural to have to repeat the same G30 commands twice in the same script. This is more significant with a delta printer (that often has many more probe points.)
                                          I'm wondering what alternatives might exist. I see there's no do/while (which would be my first thought), but I'm wondering if it would work to put the list of G30 gcodes in a different file (bed-probes.g)
                                          @dc42, do the variables from the object model available survive across different scripts? For example, if I had file called "bed-ProbePoints.g" that contained something like:
                                          G30 P0 Xn Yn
                                          G30 P18 X0 Y0 S6
                                          And then my bed.g contained:
                                          M561
                                          G28
                                          M98 P"bed-ProbePoints.g"
                                          while true
                                              if iterations > 5
                                                  abort "something needs tightening..."
                                              if abs(move.initialDeviation.deviation - move.calibrationDeviation.deviation) <= 0.01
                                                 break
                                          Would this work? Would the deviation values be updated across the scripts?
                                          Thank you
                                          Gary
                                          kraegarundefined 1 Reply Last reply Reply Quote 0
                                          • kraegarundefined
                                            kraegar @garyd9
                                            @garyd9 This was my very rough first iteration (and still is early, room for improvement, etc etc). Only posted in this thread due to the bugs I was noticing.
                                            Anyway, see my post here where I did split the G30 segment out into a macro:
                                            https://forum.duet3d.com/topic/13890/auto-tramming-a-railcore-using-conditional-gcode
                                            garyd9undefined 1 Reply Last reply Reply Quote 1
