    RepRapFirmware 3.01beta1 released
    Beta Firmware
    16
    60
    3.4k
      Just done some tests. There is a problem with equality between floats.
      The other problem you had is because the GCode line was too long. I changed it to throw an exception when that happens, but the exception isn't caught.
      This is all very new code, so I was expecting some bugs.
      • kraegarundefined
        kraegar
        Yep, I'm just playing, happy to just keep reporting. Variables will clean the code up a lot, but that's a big ask 🙂
        • kraegarundefined
          kraegar
          Once variables are implemented, if they're "system wide" and not constrained to the macro they're called in, I would set a "is_level = false" in config.g, and set to true once leveling is run. Negating the need for this method of checking.
          But I can't resist playing 🙂
            Thanks for your reports. These two issues are now fixed in the latest builds at https://www.dropbox.com/sh/3azy1njy3ayjsbp/AACquxr2m00eV568RZg5QG5wa?dl=0.
            • kraegarundefined
              kraegar
              Can I just say, HUGE thank you!
              I've already made a script to tune PA, Temp, and Extrusion % (just call the macros via layer change) as well as the auto-leveling and a "pre-print" systems readiness check.
              This is amazing!
              • kraegarundefined
                kraegar
                Float comparisons are now working, and the other errors gracefully:
                Error: in file macro, line 20 column 1: GCode command too long
                Thanks!
                  dc42 administrators @kraegar
                  Thanks for confirming. FWIW, maximum GCode line length excluding leading white space, line number and checksum (if present) and comments is currently 160 characters.
                  DIY-O-Sphereundefined gtj0undefined 2 Replies Last reply Reply Quote 1
                  • kraegarundefined
                    kraegar
                    We're going to need line numbers in the file editor in DWC now 🙂
                    • 4latheundefined
                      4lathe
                      Can I use that new duet2combinedfirmware.bin on my maestro? The 3.01 was duetmaestrofirmware.bin.
                      DIY-O-Sphereundefined 1 Reply Last reply Reply Quote 0
                      • DIY-O-Sphereundefined
                        DIY-O-Sphere @4lathe
                        @4lathe
                        It's still DuetMaestroFirmware.bin
                        (UTC+1)
                          DIY-O-Sphere @dc42
                          Hi David, maybe I have found a bug....
                          For testing I was back on 2.05 on a Maestro (DWC 2.06) and I was not able to get back directly to 3.01b.
                          Flashing 3.0 stable worked.
                          (UTC+1)
                            dc42 administrators @DIY-O-Sphere
                            @DIY-O-Sphere said in RepRapFirmware 3.01beta1 released:
                            Read the upgrade notes!
                            • gtj0undefined
                              gtj0 @dc42
                              @dc42 said in RepRapFirmware 3.01beta1 released:
                              Are you sending them via text message??? 🙂
                                DIY-O-Sphere @dc42
                                Sorry....The one who can read is in advantage
                                (UTC+1)
                                  dc42 administrators @gtj0
                                  @gtj0 said in RepRapFirmware 3.01beta1 released:
                                  Hadn't you noticed your smartphone bills going up every time you print? 😉
                                  gtj0undefined 1 Reply Last reply Reply Quote 1
                                  • gtj0undefined
                                    gtj0 @dc42
                                    Ah that makes sense now. I though it was the cat texting his buddy across the street.
                                    • garyd9undefined
                                      garyd9 @kraegar
                                      @kraegar said in RepRapFirmware 3.01beta1 released:
                                      Here is the version that works well:
                                      I like this, but it seems unnatural to have to repeat the same G30 commands twice in the same script. This is more significant with a delta printer (that often has many more probe points.)
                                      I'm wondering what alternatives might exist. I see there's no do/while (which would be my first thought), but I'm wondering if it would work to put the list of G30 gcodes in a different file (bed-probes.g)
                                      @dc42, do the variables from the object model available survive across different scripts? For example, if I had file called "bed-ProbePoints.g" that contained something like:
                                      G30 P0 Xn Yn
                                      G30 P18 X0 Y0 S6
                                      And then my bed.g contained:
                                      M561
                                      G28
                                      M98 P"bed-ProbePoints.g"
                                      while true
                                          if iterations > 5
                                              abort "something needs tightening..."
                                          if abs(move.initialDeviation.deviation - move.calibrationDeviation.deviation) <= 0.01
                                             break
                                      Would this work? Would the deviation values be updated across the scripts?
                                      Thank you
                                      Gary
                                      kraegarundefined 1 Reply Last reply Reply Quote 0
                                      • kraegarundefined
                                        kraegar @garyd9
                                        @garyd9 This was my very rough first iteration (and still is early, room for improvement, etc etc). Only posted in this thread due to the bugs I was noticing.
                                        Anyway, see my post here where I did split the G30 segment out into a macro:
                                        https://forum.duet3d.com/topic/13890/auto-tramming-a-railcore-using-conditional-gcode
                                        garyd9undefined 1 Reply Last reply Reply Quote 1
                                        • garyd9undefined
                                          garyd9 @kraegar
                                          @kraegar That is great (and answers my question.)
                                          thank you
                                          • insertnamehereundefined
                                            insertnamehere @dc42
                                            You've found a bug (the property table wasn't ordered alphabetically after I renamed a property, so the binary search failed). I've fixed it in the latest build at https://www.dropbox.com/sh/3azy1njy3ayjsbp/AACquxr2m00eV568RZg5QG5wa?dl=0. I also added a compile-time check to prevent this happening in future, and an extra property state.upTime.
                                            Firstly, thanks for the quick response. I've tried the fixed firmware and it works great.
                                            Another thing, I use an ATX type 24V supply controlled by the PS_ON pin.
                                            After all axis are homed, if I turn of the 24V supply, the axis remain homed "Blue" on the DWC. If I turn on the ATX supply again I can move all axis as if they are homed. Shouldn't turning of the 24V supply automatically mark all axis as homed : false?
                                            m409
                                            {"key":"","flags":"","result":{"boards":[{"firmwareFileName":"Duet2CombinedFirmware.bin","firmwareVersion":"3.01-beta1+1","iapFileNameSD":"Duet2CombinedIAP.bin","mcuTemp":{"current":39.6,"max":39.9,"min":38.0},"name":"Duet 2 WiFi","shortName":"2WiFi","vIn":{"current":0.7,"max":24.4,"min":0.4}}],"heat":{"coldExtrudeTemperature":160.0,"coldRetractTemperature":90.0,"heaters":[{"current":22.0,"sensor":0,"state":"Off"},{"current":23.2,"sensor":1,"state":"Active"}],"sensors":[{"lastReading":22.0,"name":"","type":"Thermistor"},{"lastReading":23.2,"name":"","type":"Thermistor"}]},"job":{"file":{"filament":[],"firstLayerHeight":0.0,"generatedBy":"","height":0.0,"lastModified":"28115-10-29T03:41:51","layerHeight":0.0,"numLayers":0,"printTime":0,"simulatedTime":0,"size":0},"lastFileName":"","layer":0,"timesLeft":{"filament":0.0,"file":0.0,"layer":0.0}},"move":{"axes":[{"homed":true,"letter":"X","max":300.0,"min":0.0,"userPosition":70.000,"visible":true},{"homed":true,"letter":"Y","max":300.0,"min":0.0,"userPosition":265.000,"visible":true},{"homed":true,"letter":"Z","max":350.0,"min":0.0,"userPosition":4.213,"visible":true}],"calibrationDeviation":{"deviation":0.000,"mean":0.000},"currentMove":{"requestedSpeed":0.0,"topSpeed":0.0},"daa":{"enabled":false,"minimumAcceleration":10.0,"period":0.0},"idle":{"factor":0.7,"timeout":30000},"initialDeviation":{"deviation":0.004,"mean":0.014},"meshDeviation":{"deviation":0.032,"mean":0.099},"printingAcceleration":10000.0,"speedFactor":100.0,"travelAcceleration":10000.0},"network":{"interfaces":[{"actualIP":"192.168.1.142","firmwareVersion":null,"gateway":"0.0.0.0","subnet":"0.255.255.255","type":"wifi"}]},"state":{"currentTool":0,"machineMode":"FFF","status":"Off","upTime":193}}}
