    CR-10S5 Firmware
    Firmware installation
    15
    145
    8.5k
    • Gost101undefined
      Gost101
      @Phaedrux Part of a print, no where near the time of completion it was supposed to be. Sure, here is the Print Settings. I don't have another slicer. Big Rips. Also my cura dosent seem to want to work anymore. It wont launch and I have to reinstall it everytime in order to launch it. I have done a complete un-install as well and this still persists. I keep my congfig files saved.
      • Vetiundefined
        Veti
        first of disable tree support. you dont need that for benchy
        your inner wall settings is 20mm/sec
        ;TYPE:WALL-INNER
        G1 F1200 X252.085 Y243.08 E0.9276
          Phaedrux Moderator @Gost101
          @Gost101 said in CR-10S5 Firmware:
          If you're on windows you will need to go to %appdata% and rename the cura folder there and then reinstall cura. You may need to re-create your printer and print settings, but it should work properly afterwards.
          Gost101undefined 1 Reply Last reply Reply Quote 0
          • Vetiundefined
            Veti
            ;SETTING_3 {"extruder_quality": ["[general]\nversion = 4\nname = Super Quality
            ;SETTING_3 #2\ndefinition = creality_cr10s5\n\n[metadata]\nquality_type = s
            ;SETTING_3 uper\ntype = quality_changes\nposition = 0\nintent_category = defa
            ;SETTING_3 ult\nsetting_version = 10\n\n[values]\nbuild_volume_temperature =
            ;SETTING_3 10\ncoasting_enable = True\ncoasting_volume = 0.4\ndefault_materi
            ;SETTING_3 al_print_temperature = 210\nfill_outline_gaps = True\ninfill_multip
            ;SETTING_3 lier = 1\ninfill_overlap = 0\ninfill_pattern = triangles\ninfill_s
            ;SETTING_3 parse_density = 5\nironing_enabled = True\nlimit_support_retraction
            ;SETTING_3 s = False\nmaterial_final_print_temperature = 210\nmaterial_initial
            ;SETTING_3 print_temperature = 210\noptimize_wall_printing_order = True\nretr
            ;SETTING_3 act_at_layer_change = True\nretraction_amount = 10\nretraction_coun
            ;SETTING_3 t_max = 0\nretraction_extra_prime_amount = 0\nretraction_extrusion
            ;SETTING_3 window = 3\nretraction_hop_enabled = True\nretraction_min_travel =
            ;SETTING_3 0.7\nretraction_prime_speed = 1\nroofing_layer_count = 3\nspeed_pr
            ;SETTING_3 int = 100\nsupport_angle = 80\nsupport_infill_rate = 5\nsupport_in
            ;SETTING_3 terface_density = 15\nsupport_interface_height = 1\nsupport_interfa
            ;SETTING_3 ce_pattern = zigzag\nsupport_interface_skip_height = 1\nsupport_lin
            ;SETTING_3 e_distance = 5\nsupport_use_towers = True\nswitch_extruder_retracti
            ;SETTING_3 on_amount = 0\nswitch_extruder_retraction_speeds = 40\ntop_bottom_t
            ;SETTING_3 hickness = 3\nz_seam_corner = z_seam_corner_inner\nz_seam_type = sh
            ;SETTING_3 arpest_corner\nzig_zaggify_infill = True\n\n"], "global_quality":
            ;SETTING_3 "[general]\nversion = 4\nname = Super Quality #2\ndefinition = cre
            ;SETTING_3 ality_cr10s5\n\n[metadata]\nquality_type = super\ntype = quality_
            ;SETTING_3 changes\nintent_category = default\nsetting_version = 10\n\n[valu
            ;SETTING_3 es]\nacceleration_enabled = False\nadhesion_type = raft\ndefault_m
            ;SETTING_3 aterial_bed_temperature = 50\nflow_rate_extrusion_offset_factor = 95
            ;SETTING_3 \nflow_rate_max_extrusion_offset = 5\nretraction_combing = off\nsu
            ;SETTING_3 pport_enable = True\nsupport_type = buildplate\n\n"}
            you might want to disable that.
            • Gost101undefined
              Gost101 @Phaedrux
              @Phaedrux Thanks, that just fixed cura not opening. Cool beans, @Veti don't know why I had tree support turned on. Lol.
              • Vetiundefined
                Veti
                while printing please post the output of the commands M201 till M205
                • Gost101undefined
                  Gost101
                  @Veti Ill try disabling z retraction.
                  • Gost101undefined
                    Gost101 @Veti
                    @Veti said in CR-10S5 Firmware:
                    How does one do that?
                    • Vetiundefined
                      Veti @Gost101
                      z retraction.
                      its called z hob wgeb retracted
                      • Vetiundefined
                        Veti @Gost101
                        @Gost101
                        in DWC go to console and issue the commands under send commands
                        • Gost101undefined
                          Gost101
                          M201
                          Cool beans, about to try new test.
                          • Vetiundefined
                            Veti
                            did you turn on adaptive layers?
                            • Gost101undefined
                              Gost101 @Veti
                              @Veti Should I? Also here is the M201 and M205 command posts: Status.PNG
                              Phaedruxundefined Vetiundefined 2 Replies Last reply Reply Quote 0
                                @Gost101 no don't turn on adaptive layers.
                                Your speeds are still being limited. Did you send these m201 etc commands after a reboot of the duet?
                                • Vetiundefined
                                  Veti @Gost101
                                  Should I?
                                  no but from the g code file it looks like you do.
                                  • Gost101undefined
                                    Gost101
                                    @Phaedrux @Veti Ill reboot it again. Currently the test print keeps pausing mid print. Weird???
                                      It probably just looks like pausing because the speeds are so low.
                                      If you run a gcode file that has the slow settings from Cura it will remain in effect until you restart the duet and the proper settings get loaded from config.g
                                      • Gost101undefined
                                        Gost101
                                        Now its printing fast, but its printing as if its on crack, so. Here is a video of it: Printer on Electric Crack
                                        • Gost101undefined
                                          Gost101
                                          @Phaedrux @Veti I'll post how the bench goes after some speed tweaks.
                                          • Gost101undefined
                                            Gost101
                                            Here is the benchy it took almost 5 hours. But the printer is almost perfect. I will upload all of my files after further testing. IMG_20200118_115347.jpg
