    CR-10S5 Firmware
    Firmware installation
    15
    145
    8.5k
    • Gost101undefined
      Gost101 @Veti
      @Veti I did reboot it. I did find that in cura and deleted it. lol
      • Gost101undefined
        Gost101
        @Phaedrux @PaulHew @Veti Great confusion this printer has caused me, yet more to learn I must. Sorry I have been watching to much star wars. lol.
        • Gost101undefined
          Gost101
          START
          M220 S100 ;Reset Feedrate
          M221 S100 ;Reset Flowrate
          G28 ;Home
          G92 E0 ;Reset Extruder
          G1 Z2.0 F3000 ;Move Z Axis up
          G1 X10.1 Y20 Z0.28 F5000.0 ;Move to start position
          G1 X10.1 Y200.0 Z0.28 F1500.0 E15 ;Draw the first line
          G1 X10.4 Y200.0 Z0.28 F5000.0 ;Move to side a little
          G1 X10.4 Y20 Z0.28 F1500.0 E30 ;Draw the second line
          STOP
          G91 ;Relative positioning
          G1 E-2 F2700 ;Retract a bit
          G1 E-2 Z0.2 F2400 ;Retract and raise Z
          G1 X5 Y5 F3000 ;Wipe out
          G1 Z10 ;Raise Z more
          G90 ;Absolute positionning
          G1 X0 Y{machine_depth} ;Present print
          M106 S0 ;Turn-off fan
          M104 S0 ;Turn-off hotend
          M140 S0 ;Turn-off bed
          M84 X Y E ;Disable all steppers but Z
            And what speeds are set in cura for printing moves?
            • Gost101undefined
              Gost101
              @Phaedrux For this profile it is:PrintSpeedCapture.PNG
              • Gost101undefined
                Gost101
                @Phaedrux Regardless of any adjustments to this, it still takes a long time to print. Even after the changes made.
                  Can you post a gcode file somewhere for us to see? And perhaps your current config.g file as it is right now?
                  • Gost101undefined
                    Gost101
                    Heres the benchy file: Benchy GCode
                    ;config.g
                    ; Created by Gost101 on Saturday, September 28th, 2019 at 18:00 (6:00PM for Civs).
                    ; This firmware discussion can be found on duet fourm: https://forum.duet3d.com/topic/11964/cr-10s5-firmware/37
                    ; Contact gost1017@gmail.com for more help.
                    G90                                        ; send absolute coordinates...
                    M83                                        ; ...but relative extruder moves
                    M550 P"A.C.E."                             ; set printer name
                    M669 K0                                    ; select Cartesian mode
                    M551 P"SpaceForceHu2020!!"                 ; set password
                    M552 S1                                    ; enable network
                    M586 P0 S1                                 ; enable HTTP
                    M586 P1 S0                                 ; disable FTP
                    M586 P2 S0                                 ; disable Telnet
                    M569 P0 S1                                 ; X physical drive 0 goes forwards
                    M569 P1 S1                                 ; Y physical drive 1 goes forwards
                    M569 P2 S0                                 ; Z physical drive 2 goes backwards
                    M569 P3 S0                                 ; E physical drive 3 goes forwards
                    M584 X0 Y1 Z2 E3                           ; set drive mapping
                    M350 X16 Y16 Z16 E16 I1                    ; configure microstepping with interpolation
                    M92 X80.00 Y80.00 Z400.00 E408.30          ; set steps per mm
                    M566 X500.00 Y500.00 Z30.00 E1500.00      ; set maximum instantaneous speed changes (mm/min)
                    M203 X10800.00 Y9000.00 Z300.00 E3000.00   ; set maximum speeds (mm/min)
                    M201 X1000.00 Y1000.00 Z500.00 E3000.00      ; set accelerations (mm/s^2)
                    M906 X950 Y950 Z850 E900 I30              ; set motor currents (mA) and motor idle factor in per cent
                    M84 S30                                    ; Set idle timeout
                    M208 X0:500 Y0:500 Z0:500                  ; set axis maxima
                    M574 X1 Y1 Z1 S1                           ; set active high endstops
                    M558 P0 H5 F120 T6000                      ; disable Z probe but set dive height, probe speed and travel speed
                    M557 X15:215 Y15:195 S20                   ; define mesh grid
                    M305 P0 T100000 B3950 R4700                ; set thermistor + ADC parameters for the heated bed
                    M143 H0 S120                               ; set temperature limit for heater 0 to 120C
                    M305 P1 T100000 B4725 C7.060000e-8 R4700   ; set thermistor + ADC parameters for heater 1
                    M143 H1 S550                               ; set temperature limit for heater 1 to 550C
                    M106 P0 S0 I0 F500 H-1                     ; set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned off
                    M106 P1 S1 I0 F500 H1 T45                  ; set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned on
                    M563 P0 D0 H1 F0                           ; define tool 0
                    G10 P0 X0 Y0 Z0                            ; set tool 0 axis offsets
                    G10 P0 R0 S40                              ; set initial tool 0 active and standby temperatures to 40C
                      Cura has the option for having the first couple layers after the first layer slowly ramping up to full speed. Have you done a full print yet to see if it speeds up? It also has a minimum layer time option which will slow down the print speed to allow for extra cooling time.
                      Would it be possible for you to export your cura print settings so we could see the full settings?
                      Do you have another slicer configured to test against? PrusaSlicer perhaps?
                      • Gost101undefined
                        Gost101
                        @Phaedrux Part of a print, no where near the time of completion it was supposed to be. Sure, here is the Print Settings. I don't have another slicer. Big Rips. Also my cura dosent seem to want to work anymore. It wont launch and I have to reinstall it everytime in order to launch it. I have done a complete un-install as well and this still persists. I keep my congfig files saved.
                        • Vetiundefined
                          Veti
                          first of disable tree support. you dont need that for benchy
                          your inner wall settings is 20mm/sec
                          ;TYPE:WALL-INNER
                          G1 F1200 X252.085 Y243.08 E0.9276
                            Phaedrux Moderator @Gost101
                            @Gost101 said in CR-10S5 Firmware:
                            If you're on windows you will need to go to %appdata% and rename the cura folder there and then reinstall cura. You may need to re-create your printer and print settings, but it should work properly afterwards.
                            Gost101undefined 1 Reply Last reply Reply Quote 0
                            • Vetiundefined
                              Veti
                              ;SETTING_3 {"extruder_quality": ["[general]\nversion = 4\nname = Super Quality
                              ;SETTING_3 #2\ndefinition = creality_cr10s5\n\n[metadata]\nquality_type = s
                              ;SETTING_3 uper\ntype = quality_changes\nposition = 0\nintent_category = defa
                              ;SETTING_3 ult\nsetting_version = 10\n\n[values]\nbuild_volume_temperature =
                              ;SETTING_3 10\ncoasting_enable = True\ncoasting_volume = 0.4\ndefault_materi
                              ;SETTING_3 al_print_temperature = 210\nfill_outline_gaps = True\ninfill_multip
                              ;SETTING_3 lier = 1\ninfill_overlap = 0\ninfill_pattern = triangles\ninfill_s
                              ;SETTING_3 parse_density = 5\nironing_enabled = True\nlimit_support_retraction
                              ;SETTING_3 s = False\nmaterial_final_print_temperature = 210\nmaterial_initial
                              ;SETTING_3 print_temperature = 210\noptimize_wall_printing_order = True\nretr
                              ;SETTING_3 act_at_layer_change = True\nretraction_amount = 10\nretraction_coun
                              ;SETTING_3 t_max = 0\nretraction_extra_prime_amount = 0\nretraction_extrusion
                              ;SETTING_3 window = 3\nretraction_hop_enabled = True\nretraction_min_travel =
                              ;SETTING_3 0.7\nretraction_prime_speed = 1\nroofing_layer_count = 3\nspeed_pr
                              ;SETTING_3 int = 100\nsupport_angle = 80\nsupport_infill_rate = 5\nsupport_in
                              ;SETTING_3 terface_density = 15\nsupport_interface_height = 1\nsupport_interfa
                              ;SETTING_3 ce_pattern = zigzag\nsupport_interface_skip_height = 1\nsupport_lin
                              ;SETTING_3 e_distance = 5\nsupport_use_towers = True\nswitch_extruder_retracti
                              ;SETTING_3 on_amount = 0\nswitch_extruder_retraction_speeds = 40\ntop_bottom_t
                              ;SETTING_3 hickness = 3\nz_seam_corner = z_seam_corner_inner\nz_seam_type = sh
                              ;SETTING_3 arpest_corner\nzig_zaggify_infill = True\n\n"], "global_quality":
                              ;SETTING_3 "[general]\nversion = 4\nname = Super Quality #2\ndefinition = cre
                              ;SETTING_3 ality_cr10s5\n\n[metadata]\nquality_type = super\ntype = quality_
                              ;SETTING_3 changes\nintent_category = default\nsetting_version = 10\n\n[valu
                              ;SETTING_3 es]\nacceleration_enabled = False\nadhesion_type = raft\ndefault_m
                              ;SETTING_3 aterial_bed_temperature = 50\nflow_rate_extrusion_offset_factor = 95
                              ;SETTING_3 \nflow_rate_max_extrusion_offset = 5\nretraction_combing = off\nsu
                              ;SETTING_3 pport_enable = True\nsupport_type = buildplate\n\n"}
                              you might want to disable that.
                              • Gost101undefined
                                Gost101 @Phaedrux
                                @Phaedrux Thanks, that just fixed cura not opening. Cool beans, @Veti don't know why I had tree support turned on. Lol.
                                • Vetiundefined
                                  Veti
                                  while printing please post the output of the commands M201 till M205
                                  • Gost101undefined
                                    Gost101
                                    @Veti Ill try disabling z retraction.
                                    • Gost101undefined
                                      Gost101 @Veti
                                      @Veti said in CR-10S5 Firmware:
                                      How does one do that?
                                      • Vetiundefined
                                        Veti @Gost101
                                        z retraction.
                                        its called z hob wgeb retracted
                                        • Vetiundefined
                                          Veti @Gost101
                                          @Gost101
                                          in DWC go to console and issue the commands under send commands
                                          • Gost101undefined
                                            Gost101
                                            M201
                                            Cool beans, about to try new test.
