    Duet3 and pi
    509
    • andornotundefined
      andornot
      I read somewhere that either the duet3 or pi will boot the other up on power up, but i cannot find where the instructions, can anybody help please?
      SpatialOne custom delta printer, upgrading to print PEEK, PEKK & Ultem
        droftarts administrators @andornot
        @andornot Most of the details are here: https://duet3d.dozuki.com/Wiki/Getting_Started_With_Duet_3
        Let me know if you have any other questions.
        andornotundefined 1 Reply Last reply Reply Quote 0
        • andornotundefined
          andornot @droftarts
          @droftarts i have read through the notes and it does not say how to choose the booting for duet3 or pi. I have a problem that if the pi is connected to the duet3 and duet3 is powered then the pi does not boot up. I have to disconnect the power to the duet3 and power up pi to get it working.
            A Former User @andornot
            @andornot said in Duet3 and pi:
            sounds like faulty wiring or faulty pi/duet, there is no interaction to control booting beyond sharing power.
              jay_s_uk
              Have you got the jumpers on the duet 3 set correctly for powering the SBC?
              • andornotundefined
                andornot @jay_s_uk
                @jay_s_uk which jumpers please, just followed the instructions on the wiki.
                  @andornot In the centre of the board:
                  https://d17kynu4zpq5hy.cloudfront.net/igi/duet3d/TF1FBCbopEsxvYAv.huge
                  How is yours set?
                  • andornotundefined
                    andornot @droftarts
                    @droftarts the top two, so internal 5v En and 5v->SBC
                      @andornot That's correct according to https://duet3d.dozuki.com/Wiki/Duet_3_Mainboard_6HC_Wiring_Diagram#Section_Important_notes
                      The default 5V power configuration is Internal 5V enable - jumpered, 5V->SBC jumpered (the Duet is powering the SBC) , SBC->5V* not jumpered. If you want the SBC to provide 5V to the Duet then remove the jumper from 5V->SBC and from Internal 5v En. Place a jumper on SBC-5V*. NOTE this bypasses the 5V protection and a fault on the SBC may damage the Duet.
                      Have you checked for 5V power on the appropriate header pin?
                      • andornotundefined
                        andornot @droftarts
                        @droftarts i have figured out the problem the 5v supply to pi is split one to the touch screen and the other the board, so if i disconnect the power to the pi and power the duet it works with top jumpers connected. Thanks for your help.
                        Andrew
