Duet 3 3 z motors config
566
    mattbaker
    Help needed.
    I am trying to set up a core xy with 3 z motors. And I think I have sent myself insane trying to set it up. Not much point posting my config files as I have edited it so many times, I go cross eyed trying to figure out what I have done. But nothing has worked so far.
    So if any of you kind people could share your config etc files, so I could compare to what I have, I would really appreciate it.
    TIA
    Matthew
      droftarts administrators
      @mattbaker Are you using a Duet 3 6HC with 3HC expansion board? What seems to be the problem?
      undefined 1 Reply Last reply 22 Jan 2020, 13:36 Reply Quote 0
        Veti
        @mattbaker said in Duet 3 3 z motors config:
        normally you do not need to do more than add the extra motors to the M584 line like
        M584 X0 Y1 Z2:4:5 E3
        current acceleration etc. is the same for all z motors
        see this article for more information and extra stuff
        https://duet3d.dozuki.com/Wiki/Bed_levelling_using_multiple_independent_Z_motors
        undefined 1 Reply Last reply 22 Jan 2020, 12:51 Reply Quote 0
          droftarts administrators @Veti
          @mattbaker One of the gotchas on Duet 3 wiring is that the motor driver layout:
          2 3
          1 4
          0 5
          not
          2 5
          1 4
          0 3
          See:
          Make sure the motors are plugged into the right headers!
            mattbaker
            Ive wired the steppers correctly, found that one out the hard way.
            I'm trying to get the 3 axis levelling working.
              mattbaker @droftarts
              @droftarts I'm trying to get the 3. axis levelling working. I'm using the Duet 3 6HC. without the expansion board at present.
              undefined 1 Reply Last reply 22 Jan 2020, 14:16 Reply Quote 0
                droftarts administrators @mattbaker
                @mattbaker Okay. See the link @Veti posted earlier. You need the following for bed levelling with 3 independent Z motors:
                • to know which motor driver links to which leadscrew, eg Z2 is front left, Z3 is back centre, Z4 is front right
                • Leadscrew position defined by M671, in the order the leadscrews are defined by M584!
                • Change bed.g to probe as near as possible to each leadscrew
                For details, see https://duet3d.dozuki.com/Wiki/Bed_levelling_using_multiple_independent_Z_motors#Section_Example_for_3_motors
                  mattbaker
                  Ive gone back through it and changed the config however I keep getting g30: some computed corrections exceed limit of 5.00.
                  Ive tried changing the limit, you see in some videos distances of 20+ mm, and it just seems to get ignored.
                  M671 X480:230.0:-30 s100 Y460.0:-40:460 S100
                  undefined 1 Reply Last reply 23 Jan 2020, 01:17 Reply Quote 0
                    Nuramori @mattbaker
                    @mattbaker your m671 doesn’t look right.
                    Here’s mine. For reference the order of the z axis motors are one on the left is motor one, motor on the back right is two, motor on the front right is the third. All commands are listed/referenced with that order. I also always include a pin map in the beginning of my config.g as an easy reference.
                    ; Configuration file for Duet3 (firmware version 3.0 RC2)
                    ; --------------- Pin/connection Mapping Legend -------------------
                    ; out0 - Bed heater
                    ; out1 - Extruder 1 heater
                    ; out2
                    ; out3
                    ; out4 - Radiator cooling fan - WC heatsink
                    ; out5
                    ; out6
                    ; out7
                    ; out8 - Parts cooler on printhead
                    ; out9 - Duet board cooling fan
                    ; out4.tach - Radiator cooling fan rpm wire - WC heatsink
                    ; out5.tach
                    ; out6.tach
                    ; io0.in
                    ; io1.in - X min active low endstop switch
                    ; io2.in - Y max active low endstop switch
                    ; io3.in - Z probe type to bltouch - DEPRECATED
                    ; io4.in - Z probe type to PIEZO
                    ; io5.in - Emergency stop switch
                    ; io6.in
                    ; io7.in
                    ; io8.in
                    ; io0.out
                    ; io1.out
                    ; io2.out
                    ; io3.out - GPIO port 0 on IO3, servo mode - BLTouch Z-Probe
                    ; io4.out
                    ; io5.out
                    ; io6.out
                    ; io7.out
                    ; io8.out
                    ; servo, out10 (only on v0.5, not on v0.6)
                    ; pson
                    ; spi.cs0
                    ; spi.cs1
                    ; spi.cs2
                    ; spi.cs3
                    ; temp0 - Bed Thermistor
                    ; temp1 - PT1000 for extruder 1
                    ; temp2 - PT1000 for pi4
                    ; temp3
                    ; mcu-temp - MCU sensor
                    G4 P2000 ; Hold your Horses.
                    G21 ; Set units to Millimeters
                    M550 P"DUET3" ; set printer name
                    M584 X0.3 Y0.2 Z0.0:0.1:0.4 E0.5 ; set drive mapping to each axis
                    M669 K1 ; Select CoreXY mode - New format
                    M552 S1 ; enable network
                    M552 P192.168.3.120 ; Static IP Address
                    M586 P0 S1 ; enable HTTP
                    M586 P1 S0 ; disable FTP
                    M586 P2 S0 ; disable Telnet
                    M569 P0.0 S0 ; physical drive 0 goes backwards - Z Axis Left (1)
                    M569 P0.1 S0 ; physical drive 1 goes backwards - Z Axis Right Back (2)
                    M569 P0.2 S0 ; physical drive 2 goes backwards - Y Axis
                    M569 P0.3 S0 ; physical drive 3 goes backwards - X Axis
                    M569 P0.4 S0 ; physical drive 4 goes backwards - Z Axis Right Front (3)
                    M569 P0.5 S1 ; pyhsical drive 5 goes forwards - Extruder 1
                    ; Set up three Z-axis location
                    M671 X-52.5:377.5:377.5 Y162.5:282.5:42.5 S5 ; leadscrews at 1 - left, 2 - rear right and 3 - front right
                    M92 X200.00 Y200.00 Z400.00 E1800 ; set steps per mm
                    M350 X16 Y16 Z16 E16 I1 ; configure micro-stepping with interpolation
                    M566 X1000.00 Y1000.00 Z400.00 E240.00 ; set maximum instantaneous speed changes (mm/min)
                    M203 X24000.00 Y24000.00 Z2000.00 E1200.00 ; set maximum speeds (mm/min)
                    M201 X10000.00 Y10000.00 Z400.00 E800.00 ; set accelerations (mm/s^2)
                    M906 X1000 Y1000 Z1000 E800 I30 ; set motor currents (mA) and motor idle factor in percent*100
                    M572 D0 S0.074 ; Set pressure advance
                    M84 S30 ; Set idle timeout
                    M208 X320 Y320 Z350 S0 ; set axis maxima
                    M574 X1 S1 P"io1.in" ; X min active high endstop switch
                    M574 Y2 S1 P"io2.in" ; Y max active high endstop switch
                    ; Z-Probe - BLTouch - DEPRECATED
                    ; M574 Z1 S2 ; set endstops controlled by probe
                    ; M558 P9 C"^io3.in" H3 F60000 T10000 ; set Z probe type to bltouch and the dive height + speeds (bltouch NEEDS pullup)
                    ; G31 P10 X28.5 Y-5 Z2.35 ; set Z probe trigger value, offset and trigger height
                    ; Z-Probe - PIEZO
                    M558 P8 C"io4.in" H5 F1000 T20000 ; set Z probe type to PIEZO and the dive height + speeds
                    G31 P10 X0 Y0 Z-0.1 ; set Z probe trigger value, offset and trigger height
                    G30 ; Probe Z
                    ; Configure Heaters and Sensors
                    M308 S0 P"temp0" Y"thermistor" A"Bed Temp" T100000 B3950 ; Configure bed temperature sensor
                    M308 S1 P"temp1" Y"pt1000" A"Extruder 1 Temp" ; Configure extruder 1 temperature sensor - PT1000 sensor
                    M308 S2 P"mcu-temp" Y"mcu-temp" A"Duet Board" ; Configure MCU sensor
                    ; M308 S4 P"temp2" Y"pt1000" A"RPI" R2200 ;Pt1000 temp sensor for the raspberry pi
                    ; Define Sensors and Fans
                    M950 H0 C"out0" T0 ; Define heater 0 (bed heater) - bed_heat pin and Temp Sensor 0
                    M950 H1 C"out1" T1 ; Define heater 1 (hot-end E0) to use the "e0_heat" pin and Temp Sensor 1
                    ;Set PID values
                    M307 H0 A253.9 C566.2 D1.0 V23.3 B0 ; disable bang-bang mode for the bed heater and set PWM limit
                    M307 H1 A855.8 C368.4 D5.7 V23.3 B0 ; disable bang-bang mode for the extruder heater and set PWM limit
                    M950 F0 C"out8" Q100 ; Define Fan_0 for use - Parts Cooler on Printhead - 4010 fan
                    M950 F1 C"!out4+^out4.tach" Q25000 ; Define Fan_1 for use - Radiator cooling - WC heatsink. - PWM fan
                    M950 F2 C"out9" Q25000 ; Define Fan_2 for use - Duet board cooling fan
                    ; M950 S0 C"io3.out" ; Define GPIO port 0 on IO3, servo mode - BLTouch Z-Probe - DEPRECATED
                    M106 P0 S0 ; set fan 0. Parts Cooler on Printhead
                    M106 P1 T25:40 H2 ; Set fan 1. Manages Radiator fan for water-cooled loop.
                    M106 P2 T35:50 H2 ; Set fan 2. Manages Duet board fan.
                    M563 P0 S"Extruder 1" D0 H1 F0 ; define tool 0. Fan 0 operates with an active hot-end
                    ; Emergency Stop
                    M574 S1 P"^!io5.in" ; Define Emergency endstop - emergency stop switch condition
                    M581 P"io5.in" T0 ; Define action to be taken with activation of emergency stop switch
                    T0 ; select first tool
                    M501 ; Store parameters
                    undefined 1 Reply Last reply 23 Jan 2020, 12:04 Reply Quote 0
                      mattbaker @Nuramori
                      @Nuramori Thanks for your help. I uploaded new files from the configurator, changed a few things, which I thought is what I had, and problem solved.
                      No idea what the problem was, looks the same to me, but I'm not going to look a gift horse in the mouth.
                      8 out of 10
