    Strange Mesh Grid Comp. results
    334
    • tripodDuetundefined
      tripodDuet
      I'm busy reviving my old Tripodmaker Delta Printer (300x400) with a DuetWifi Board. The motor and height settings (mm/step, home-height, z-max-travel) seem to be right now. The auto delta calibration to works without error messages now.
      I just ran the Mesh Grid Compensation and got these strange results (see attached image). Any idea what could be happening here?
      • Using a temporary setup for my Duet IR probe (glued, no shorts).
      • Standard speed settings from configtool.reprapfirmware.org
      • mesh probing looks normal, no hiccups visible
      • brown paper tape as bed cover
      Thanks,
        Have you gone through this?
        https://duet3d.dozuki.com/Wiki/Calibrating_a_delta_printer
          tripodDuet
          Mmh, it says one might as well use the reprap-cfg-tool, so I did. It seems to be the same questions that need to be answered in the process.
          As I said, the auto calibration seems flawless, only I haven't figure out how to verify that. Tried printing a sample, but it bumped into the bed, which might have been because I had a hominG28 in the start code. Trying with no homing now...
            tripodDuet
            Naa, even after calibrating it, the zero-point in the z-coordinate is about 6mm above the bed. Something is still very wrong somewhere.
            • Vetiundefined
              Veti
              post your config and config overwrite
              • tekkydaveundefined
                tekkydave
                Could there be movement/flex in the probe's position going on? Do you get the same heightmap image every time you probe?
                ~ tekkydave ~
                D-Bot: 300x300mm | Duet WiFi + Duex2 | 3 independent z motors | X,Y & Z linear rails | E3D Titan Aero + V6 | Precision Piezo z-probe
                FreeCAD, PrusaSlicer
                • crynoolundefined
                  crynool
                  This post is deleted!
                    tripodDuet
                    Ok so I just did the mesh grid compensation without my fancy LED-light strips and now the results looked much better. Also, the print startet fine, laying a good first layer. Interesting, huh...
                      Phaedrux Moderator @tripodDuet
                      @tripodDuet That is really interesting. I wonder how many of the issues seen by users of the IR Probe actually might be running into something similar.
                      What kind of LEDs are you using?
                        tripodDuet
                        @tekkydave , no, there is no movement in the probe.
                        @Phaedrux I just ran the Comp again with the lights no. Now the results are similar to the lights-off-situation. I'm a little puzzled, so that might not have been the thing.
                        I'll have to sherlock some more, but not tonight. Thanks for your questions.
                          tripodDuet
                          @Phaedrux using cheap china-led-strips from the hardware store. Something like this https://www.amazon.de/Lichterkette-Lichtleiste-Fernbedienung-Farbwechsel-selbstklebend/dp/B01I1HQ372/ref=sr_1_1?__mk_de_DE=ÅMÅŽÕÑ&crid=21K1FJT1T5A8X&keywords=led+streifen&qid=1580335271&sprefix=led+%2Caps%2C-1&sr=8-1
