    BLTouch working
    266
    80.2k
    • Fickertundefined
      Fickert
      @Sniffle:
      @Fickert:
      Thank you, I have been trying to dive through all the pages on the Wiki to gain some idea of what I am exactly doing.
      I used the RRF Config tool to create a set of config documents which is what I have linked here http://pastebin.com/XMvCwT6f
      According the diag and my board isn't p21 for E5? which is not heater 3 that we keep referencing to use a pwm servo pin. I guess I am confused on how this works or what I am missing.
      Also I think there is something up with this config as I cannot heat my hotend nor my bed. The thermsistors register fine but once a temp is set to active nothing happens. I know this is outside the purpose of this thread but if anything jumps out to you for this it would be great to note.
      As well when I heat the hotend I get the set of codes in the console:
      M120
      M83
      G1 E-10 F2400
      M121
      I am not sure why it is referencing E-10, shouldn't it be E1 (What my hotend is currently wired to)?
      You had a few duplicate lines in the config and a couple of things that needed to be changed, I edited it and re-pasted.
      The output and expected actions will should look correct since i changed it to act like marlin.
      as to your question about G1 E-10 F2400 that is saying to retract 10mm of filament, by changing the M555 to P2 it should change behave more how you expect
      I also removed duplicate gcodes and arranged them where they should make more sense and added comments to them so that they will hopefully make more sense.(i forgot to edit the comment on the M555 Gcode it should say marlin and not reprapfirmware)
      http://pastebin.com/K9C9yQrG
      Great Thank you,
      I will get this loaded up and see what I come up with.
      Update,
      Further to find, the bltouch pin still will not deploy. Do I need the deploy and retract codes in the config file? I have them in the macros but that is it. Also the hotend and bed still will not heat up. Auto tune does not complete either since it will not heat up 😞 Wiring is fine, not sure why its acting up. is it something to do with the tool? This tool change thing is very new to me.
      • Sniffleundefined
        Sniffle
        you should start a new thread for the heater issues,
        As to the bltouch, is it glowing with a red light? are you sure the wiring is correct? on the bltouch brown is ground, orange is 5v and yellow is signal. when it is powered on it should cycle the pin 2-3 times up and down then store itself up and glow red.
        • Fickertundefined
          Fickert
          I will get another thread started for the heaters.
          The bltouch is wired to 5v and ground for the servo power, the servo pin is wired to p21 labeled e5 dir. the signal and ground wires for the sensor are wired to the IN and ground pins on the PROBE headers on the duet wifi. Those two wires are also linked with the resistor included with my bltouch a 240 ohm i believe.
          Do I need another resistor in line with the 5v line like that diagram that was posted a while ago?
          Aside from the wiring yes the bltouch looks "ready" with it lit up red when retracted, and upon start up it does it deploy retract procedure.
          • Sniffleundefined
            Sniffle
            ok, so for Probe type 4 which is a switched probe the endstop(black/white wires) need to be plugged into the E0 endstop. Also to simplify wiring you can plug the 5v and ground into pins 1 and 2 of the expansion header. the bltouch doesnt care where it gets power and ground from but it simplifies wiring some.
            to quote the Gcode wiki for M558
            @http://reprap.org/wiki/G-code#M558:_Set_Z_probe_type:
            A Z probe may be a switch, an IR proximity sensor, or some other device. This selects which to use.
            P0 indicates that no Z probe is present. P1 gives an unmodulated IR probe, or any other probe type that emulates an unmodulated IR probe (probe output is an analog signal that rises with decreasing nozzle height above the bed).
            If there is a control signal to the probe, it is driven high when the probe type is P1.
            P2 specifies a modulated IR probe, where the modulation is commanded directly by the main board firmware using the control signal to the probe.
            P3 selects an alternative Z probe by driving the control signal to the probe low.
            P4 selects a switch for bed probing (on the Duet, this must be connected to the E0 endstop pins).
            P5 (from RepRapFirmware 1.14) selects a switch (normally closed) for bed probing between In and Gnd pins of the Z-probe connector (Duet 0.8.5 and Duet WiFi).
            P6 is as P4 but the switch is connected to and alternative connector (on the Duet series, the E1 endstop connector).
            currently though you seem to not be getting signal to the bltouch, doublecheck your connections, and try to isolate the signal wire for the bltouch away from the other wires in the wire bundle, especially the motor wires. you could be getting intereferance from an outside source.
              P5 is the correct type for a BLTouch. I'll add this to the wiki.
              • Sniffleundefined
                Sniffle
                @dc42:
                which endstop is expected then? I've been using the P4 option without issue and how W3DRK got it working initially
                Whats the main difference between them?
                • Fickertundefined
                  Fickert
                  @Sniffle:
                  Oh okay thank you for the clarification on the E0 pins not the probe pins.
                  I guess i am still confused as the pin will not react to pwm signals. This exact setup worked on my previous mks board so I have confidence there is no wire interference as the gantry hasn't even been moved since then. I will look again though and see if I see anything with it.
                  • Sniffleundefined
                    Sniffle
                    David, I tried to go make a few changes to the wiki to update the info you had ??'s at, but have been blocked. If for some reason i am not unblocked I'll just make a post here to clarify the info.
                    • Fickertundefined
                      Fickert
                      @3dprinting:
                      is it possible to test the bltouch without connecting to the power supply?
                      I mean, if I plug in usb, I can use web control, but is it enough power to activate servos and all that jazz?
                      I think It would work, but not sure. My boadr's sitting on the table and I'd rather get bltouch up and running before I disassemble my printer because my current z probe is not compatible.
                      Supplying external 12v to the board shouldn't be difficult. An external psu or even just long wires from your psu in the printer. More importantly this thing is awesome (Duet Wifi) for that fact you don't really ever have to plug into it again.
                      • Fickertundefined
                        Fickert
                        @Sniffle:
                        Not sure if you or David updated the Wiki but shouldn't the retract pin macro file be "M280 P3 S90 I1" ?
                        • Fickertundefined
                          Fickert
                          @3dprinting:
                          @Fickert:
                          @3dprinting:
                          Yea, but I was hoping to cheat a little because my printer has a metal cabinet base I have to flip the printer over to access power, all my connectors need to be replaced to connect to the wifi, and I have an incompatible z probe right now,so when I set up the BLtouch, i gotta test it before installing the board, it's a lot of work to roll it back to 8 bit, especially since nobody within 40 miles of me sells 240k resistors, and the new bltouch doesn't come with one.
                          But I'm 1 day in on the upgrade, and I alotted myself 3, so I'm not doing bad right now.
                          Ahh I see. Got extra wires to run temporarily to the duet from your psu? Only gotta flip it once then 🙂
                          Also the new bltouch doesn't need a 240ohm resistor. you just cut the jumper on the chip that says 3.3v logic.
                          • Sniffleundefined
                            Sniffle
                            @Fickert:
                            @Sniffle:
                            I regained access to the wiki, and updated some of the info, I need to go back through and edit some more but it's more accurate now.
                            • 3dprinting meatheadundefined
                              3dprinting meathead
                              @Sniffle:
                              @Fickert:
                              @Sniffle:
                              I have the new bltouch right here in my hand, and the color code for the probe output is
                              black= ground
                              white= signal out
                              not sure if it's the right way to word it, I'd call it z+ and z-, but that might confuse with minimum and maximum heights, but I think you get the idea for the purpose of updating the wiki
                              If I can learn it, than anyone can learn it.
                              • Sniffleundefined
                                Sniffle
                                @3dprinting:
                                @Sniffle:
                                @Fickert:
                                @Sniffle:
                                black= ground
                                white= signal out
                                I have 3 of them, my plan is to rewrite that section to have the 3 pin and the 2 pin separate
                                • Fickertundefined
                                  Fickert
                                  Okay so wonderful news, I can now deploy ad retract the pin! 🙂
                                  But checking endstops with m119, it shows I have a z stop at its min, when I do not even have one installed. I will have to double check my config for one. Using p5 and the probe pins I do not have to have a z end stop do I? Seems to be a bit more of an annoyance imo.
                                  Also with the pin up or down the m119 also stated the probe was not stopped. Shouldn't it be stopped when retracted?
                                    If your M558 command specifies that the Z probe is used for homing, then when the probe is triggered, M119 should show both probe triggered and Z at min stop.
                                    What the probe shows when retracted will depend on what the probe outputs. Deployable probes are usually designed to show that they are triggered when retracted, for safety.
                                    • Fickertundefined
                                      Fickert
                                      So I guess what exactly should my m558 command be exactly? It was "M558 P5 X0 Y0 Z1 H5 F120 T2000"
                                      Is this correct still?
                                        3dprinting meathead
                                        Ok, so I have the probe mounted, and it deplys, retracts, and when I run the self test macro, it goes up and down endlessly like a blinker. Here's a video I made of it.
                                        https://youtu.be/uu1BUnxgQMs
                                        Is this how it's supposed to work? Am I missing an important step on how to see if the z probe is reading triggered in real time?
                                        I don't know an easier way to do this, so here's my configuration.g, in it's entirety.
                                        ; Configuration file for Duet WiFi (firmware version 1.17)
                                        ; generated by RepRapFirmware Configuration Tool on Sat Feb 18 2017 23:41:13 GMT-0500 (Eastern Standard Time)
                                        M111 S0 ; Debugging off
                                        G21 ; Work in millimetres
                                        G90 ; Send absolute coordinates…
                                        M555 P2 ; Set firmware compatibility to look like Marlin
                                        M208 X200 Y200 Z260 S0 ; Set axis maxima
                                        M574 X1 Y1 Z0 S0 ; Define active low and unused microswitches
                                        M558 P5 X0 Y0 Z1 H5 F120 T6000 ; Set Z probe type to unmodulated, the axes for which it is used and the probe + travel speeds
                                        G31 P25 X0 Y0 Z2.5 ; Set Z probe trigger value, offset and trigger height
                                        M569 P0 S0 ; Drive 0 goes backwards
                                        M569 P1 S0 ; Drive 1 goes backwards
                                        M350 X16 Y16 Z16 E16 I1 ; Configure microstepping without interpolation
                                        M92 X100 Y100 Z4000 E98 ; Set steps per mm
                                        M566 X600 Y600 Z12 E120 ; Set maximum instantaneous speed changes (mm/min)
                                        M203 X6000 Y6000 Z180 E1200 ; Set maximum speeds (mm/min)
                                        M201 X500 Y20 Z250 E250 ; Set accelerations (mm/s^2)
                                        M906 X800 Y800 Z800 E1000 I30 ; Set motor currents (mA) and motor idle factor in per cent
                                        M84 S30 ; Set idle timeout
                                        M143 S275 ; Set maximum heater temperature to 275C
                                        M301 H0 S1.00 P10 I0.1 D200 T0.4 W180 B30 ; Use PID on bed heater (may require further tuning)
                                        M305 P0 T100000 B3988 C0 R4700 ; Set thermistor + ADC parameters for heater 0
                                        M305 P1 T100000 B-6788 C3.166739e-6 R4700 ; Set thermistor + ADC parameters for heater 1
                                        M563 P0 D0 H1 ; Define tool 0
                                        G10 P0 X0 Y0 ; Set tool 0 axis offsets
                                        M550 PDMSDP5 ; Set machine name
                                        M551
                                        M552 P0.0.0.0 S1 ; Enable network and acquire dynamic address via DHCP
                                        M106 P0 S0.3 I0 F500 H-1 ; Set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned off
                                        M106 P1 S1 I0 F500 H1 T45 ; Set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned on
                                        M106 P2 S1 I0 F500 H1 T45 ; Set fan 2 value, PWM signal inversion and frequency. Thermostatic control is turned on
                                        M307 H3 A-1 C-1 D-1
                                        T0 ; Select first tool
                                        thanks for the help!
                                        edit:shouldnt post my password, I'll change it now. Yea, I'm a meathead
                                        • Sniffleundefined
                                          Sniffle
                                          post the Macro,
                                          If you are using M280 P3 S120 I1 that's what it does it cycles continually until M280 P3 S160 I1 to reset the probe to it's normal operating procedure this is a built in bltouch feature and not part of reprap firmware.
                                          see my post on page 2 or 4 for testing the probing of a single point.
                                          • Fickertundefined
                                            Fickert
                                            I finally got my bltouch to be usable as a probe and endstop for the z axis. Wohooo! Thanks so much guys!
                                            I gotta ask too, I currently have the homing sequence to only probe once, unlike the normal endstop procedure (quickly enable endstop, back off and engage again slowly) procedure. What Homing code did you use to replicate this? Or are you using a simple one ouch method like I described?
