    BLTouch working
    266
    80.2k
    • Sniffleundefined
      Sniffle
      David, I tried to go make a few changes to the wiki to update the info you had ??'s at, but have been blocked. If for some reason i am not unblocked I'll just make a post here to clarify the info.
      • Fickertundefined
        Fickert
        @3dprinting:
        is it possible to test the bltouch without connecting to the power supply?
        I mean, if I plug in usb, I can use web control, but is it enough power to activate servos and all that jazz?
        I think It would work, but not sure. My boadr's sitting on the table and I'd rather get bltouch up and running before I disassemble my printer because my current z probe is not compatible.
        Supplying external 12v to the board shouldn't be difficult. An external psu or even just long wires from your psu in the printer. More importantly this thing is awesome (Duet Wifi) for that fact you don't really ever have to plug into it again.
        • Fickertundefined
          Fickert
          @Sniffle:
          Not sure if you or David updated the Wiki but shouldn't the retract pin macro file be "M280 P3 S90 I1" ?
          • Fickertundefined
            Fickert
            @3dprinting:
            @Fickert:
            @3dprinting:
            Yea, but I was hoping to cheat a little because my printer has a metal cabinet base I have to flip the printer over to access power, all my connectors need to be replaced to connect to the wifi, and I have an incompatible z probe right now,so when I set up the BLtouch, i gotta test it before installing the board, it's a lot of work to roll it back to 8 bit, especially since nobody within 40 miles of me sells 240k resistors, and the new bltouch doesn't come with one.
            But I'm 1 day in on the upgrade, and I alotted myself 3, so I'm not doing bad right now.
            Ahh I see. Got extra wires to run temporarily to the duet from your psu? Only gotta flip it once then ๐Ÿ™‚
            Also the new bltouch doesn't need a 240ohm resistor. you just cut the jumper on the chip that says 3.3v logic.
            • Sniffleundefined
              Sniffle
              @Fickert:
              @Sniffle:
              I regained access to the wiki, and updated some of the info, I need to go back through and edit some more but it's more accurate now.
              • 3dprinting meatheadundefined
                3dprinting meathead
                @Sniffle:
                @Fickert:
                @Sniffle:
                I have the new bltouch right here in my hand, and the color code for the probe output is
                black= ground
                white= signal out
                not sure if it's the right way to word it, I'd call it z+ and z-, but that might confuse with minimum and maximum heights, but I think you get the idea for the purpose of updating the wiki
                If I can learn it, than anyone can learn it.
                • Sniffleundefined
                  Sniffle
                  @3dprinting:
                  @Sniffle:
                  @Fickert:
                  @Sniffle:
                  black= ground
                  white= signal out
                  I have 3 of them, my plan is to rewrite that section to have the 3 pin and the 2 pin separate
                  • Fickertundefined
                    Fickert
                    Okay so wonderful news, I can now deploy ad retract the pin! ๐Ÿ™‚
                    But checking endstops with m119, it shows I have a z stop at its min, when I do not even have one installed. I will have to double check my config for one. Using p5 and the probe pins I do not have to have a z end stop do I? Seems to be a bit more of an annoyance imo.
                    Also with the pin up or down the m119 also stated the probe was not stopped. Shouldn't it be stopped when retracted?
                      If your M558 command specifies that the Z probe is used for homing, then when the probe is triggered, M119 should show both probe triggered and Z at min stop.
                      What the probe shows when retracted will depend on what the probe outputs. Deployable probes are usually designed to show that they are triggered when retracted, for safety.
                      • Fickertundefined
                        Fickert
                        So I guess what exactly should my m558 command be exactly? It was "M558 P5 X0 Y0 Z1 H5 F120 T2000"
                        Is this correct still?
                          3dprinting meathead
                          Ok, so I have the probe mounted, and it deplys, retracts, and when I run the self test macro, it goes up and down endlessly like a blinker. Here's a video I made of it.
                          https://youtu.be/uu1BUnxgQMs
                          Is this how it's supposed to work? Am I missing an important step on how to see if the z probe is reading triggered in real time?
                          I don't know an easier way to do this, so here's my configuration.g, in it's entirety.
                          ; Configuration file for Duet WiFi (firmware version 1.17)
                          ; generated by RepRapFirmware Configuration Tool on Sat Feb 18 2017 23:41:13 GMT-0500 (Eastern Standard Time)
                          M111 S0 ; Debugging off
                          G21 ; Work in millimetres
                          G90 ; Send absolute coordinatesโ€ฆ
                          M555 P2 ; Set firmware compatibility to look like Marlin
                          M208 X200 Y200 Z260 S0 ; Set axis maxima
                          M574 X1 Y1 Z0 S0 ; Define active low and unused microswitches
                          M558 P5 X0 Y0 Z1 H5 F120 T6000 ; Set Z probe type to unmodulated, the axes for which it is used and the probe + travel speeds
                          G31 P25 X0 Y0 Z2.5 ; Set Z probe trigger value, offset and trigger height
                          M569 P0 S0 ; Drive 0 goes backwards
                          M569 P1 S0 ; Drive 1 goes backwards
                          M350 X16 Y16 Z16 E16 I1 ; Configure microstepping without interpolation
                          M92 X100 Y100 Z4000 E98 ; Set steps per mm
                          M566 X600 Y600 Z12 E120 ; Set maximum instantaneous speed changes (mm/min)
                          M203 X6000 Y6000 Z180 E1200 ; Set maximum speeds (mm/min)
                          M201 X500 Y20 Z250 E250 ; Set accelerations (mm/s^2)
                          M906 X800 Y800 Z800 E1000 I30 ; Set motor currents (mA) and motor idle factor in per cent
                          M84 S30 ; Set idle timeout
                          M143 S275 ; Set maximum heater temperature to 275C
                          M301 H0 S1.00 P10 I0.1 D200 T0.4 W180 B30 ; Use PID on bed heater (may require further tuning)
                          M305 P0 T100000 B3988 C0 R4700 ; Set thermistor + ADC parameters for heater 0
                          M305 P1 T100000 B-6788 C3.166739e-6 R4700 ; Set thermistor + ADC parameters for heater 1
                          M563 P0 D0 H1 ; Define tool 0
                          G10 P0 X0 Y0 ; Set tool 0 axis offsets
                          M550 PDMSDP5 ; Set machine name
                          M551
                          M552 P0.0.0.0 S1 ; Enable network and acquire dynamic address via DHCP
                          M106 P0 S0.3 I0 F500 H-1 ; Set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned off
                          M106 P1 S1 I0 F500 H1 T45 ; Set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned on
                          M106 P2 S1 I0 F500 H1 T45 ; Set fan 2 value, PWM signal inversion and frequency. Thermostatic control is turned on
                          M307 H3 A-1 C-1 D-1
                          T0 ; Select first tool
                          thanks for the help!
                          edit:shouldnt post my password, I'll change it now. Yea, I'm a meathead
                          • Sniffleundefined
                            Sniffle
                            post the Macro,
                            If you are using M280 P3 S120 I1 that's what it does it cycles continually until M280 P3 S160 I1 to reset the probe to it's normal operating procedure this is a built in bltouch feature and not part of reprap firmware.
                            see my post on page 2 or 4 for testing the probing of a single point.
                            • Fickertundefined
                              Fickert
                              I finally got my bltouch to be usable as a probe and endstop for the z axis. Wohooo! Thanks so much guys!
                              I gotta ask too, I currently have the homing sequence to only probe once, unlike the normal endstop procedure (quickly enable endstop, back off and engage again slowly) procedure. What Homing code did you use to replicate this? Or are you using a simple one ouch method like I described?
                                3dprinting meathead
                                @Sniffle:
                                post the Macro,
                                Ok, I'm up and running! probe is working great! Now gotts tune my bed, the map looks like utah, align my z axies, set z offset and enjoy
                                Thank you and everyone else who had the patience to deal with my meathead questions! There's no way I could have figured this out on my own.
                                • Miasmictruthundefined
                                  Miasmictruth
                                  After much struggle I finally was able to get the touch to work. For some reason using M558 P5 did not work for me the Z probe would always sit a 1000, so I ended up using M558 P4 and it works like a charm. Do I have an old version of the probe or something maybe?
                                  ;Z Probe Setup in Config.g
                                  M307 H3 A-1 C-1 D-1 ;reserve pin 21 for servo use
                                  M558 P4 X0 Y0 Z1 H6 F450 T4000
                                  G31 X-17 Y7 Z2.3 P25 ; Set the probe height and threshold; increase Z to decrease bed probe distance X11.0 Y0.5
                                  ; Deploy Probe (having I1 at the end it did not work)
                                  M280 P3 S10
                                  ;Home Z
                                  T0 ; select first hot end
                                  G91 ; Relative coordinates
                                  G1 Z5 F200 ; Lower bed to avoid hotend dragging in bed.
                                  G90 ; Absoulte coordinates
                                  G1 X35 Y15 F3000 ; Go to first bed probe point and home the Z axis
                                  M401
                                  G30 ; Calibrate Z-axis
                                  M402
                                  G1 Z1 F200 ; Raise bed to 1mm.
                                  ;Mesh Level
                                  ;Setup
                                  ;Home X and Y
                                  G1 Z4 F720 ; Lower bed to avoid hotend dragging in bed.
                                  G1 X-350 Y-240 F3000 S1 ; move up to 240mm in the -X and -Y directions until the homing switches are triggered
                                  G1 X6 Y6 F600 ; move slowly 6mm in +X and +Y directions
                                  G1 X-10 Y-10 S1 ; move up to 10mm in the -X and -Y directions until the homing switches are triggered
                                  ;Home Z
                                  G1 X35 Y15 Z6 F3000 ; Go to first bed probe point and home the Z axis
                                  M401 ; Deploy Probe
                                  G30 ; Home Z-axis
                                  ;Preform Mesh level
                                  M557 X10:290 Y10:190 S20 ; Bed level from X30Y12 to X299Y188 in 20mm increments
                                  G29 S0 ; Auto Bed Level and create report (If I retacted probe first bad things happend)
                                  M374 ; Save calibration grid
                                  M402 ; Retract Probe
                                  G1 X70 Y200 F3000 ; Dock after bedlevel. Move first in front of docking notch
                                  G1 X70 Y235 F3000 ; Dock after bedlevel
                                    With P4 in your M558 command, you need to connect the sensor output to the E0 endstop connector. With P5 you connect it to the IN pin on the ZProbe connector. I added a wiring table at https://duet3d.com/wiki/Connecting_a_Z_probe#BLTouch last week and updated it today, using what little information I was able to find about BLTouch on the web.
                                      Miasmictruth
                                      Oooh dang, I wasted so much time, I mixed it up I guess with reading to put it on E0 and using P5, I read through this forum 3 or so times trying to get all the information scattered around and still screwed it up ๐Ÿ˜•
                                      I am working on a more complete walk-through integrating the Duet with the BigBox, I plan on a section detailing the BLTouch as well.
                                      • FrankNPrinterundefined
                                        FrankNPrinter
                                        @claustro:
                                        Are this connections right?
                                        Can someone make a step by step description of the firmware modifications required?
                                        http://i68.tinypic.com/rle5g1.jpg
                                        these are not quite right. black and white leads should go to other port and not panel due connector. reverse pins accordingly
                                          FrankNPrinter
                                          Duet Wifi BL touch is not working. It blinks red and shows z probe = 1000. i cant get probe to deploy manually either. Am i missing something or is it just plain wrong? pretty sure it is wired right.
                                          config.g = ; BLTouch
                                          M307 H3 A-1 C-1 D-1
                                          M558 P5 X0 Y0 Z1 H3 F200 T5000
                                          Bed.g = ; bed.g
                                          ; Clear any bed transform
                                          M561
                                          ; Home all axes
                                          G28
                                          ; Probe the bed at 5 points
                                          G30 P0 X15 Y15 H0 Z-99999
                                          G30 P1 X15 Y268 H0 Z-99999
                                          G30 P2 X255 Y268 H0 Z-99999
                                          G30 P3 X255 Y15 H0 Z-99999
                                          G30 P4 X128 Y138 H0 Z-99999 S
                                          Deployprobe.g
                                          M280 P3 S10 I1
                                          #Retractprobe.g
                                          M280 P3 S90 I1
                                          • Sniffleundefined
                                            Sniffle
                                            When the probe is blinking red it is in an error state and you need to use M280 P3 S160 I1 to reset the probe state
                                            You can use M280 P3 S120 I1 to run a self test, the S160 will be required to reset if from the self test
