    Failed to add SSID to remember list
    Firmware installation
    3.8k
    • hussainsail2002undefined
      hussainsail2002
      not able to get the firmware installed, any thing else I can do ??
        hussainsail2002 @dc42
        anything else that I can do ??
          It looks like you have the main firmware installed. Have you updated the wifi server firmware as well?
          hussainsail2002undefined 1 Reply Last reply Reply Quote 0
            hussainsail2002 @Phaedrux
            @phaedrux
            I downloaded the duetwifiserver.bin file and replaced it with the one in the sys folder
            Is there anything else that I have to do to install ?
              dc42 administrators @hussainsail2002
              @hussainsail2002 said in Failed to add SSID to remember list:
              The M115 command gives the following message:
              FIRMWARE_NAME: RepRapFirmware for Duet 2 WiFi/Ethernet FIRMWARE_VERSION: 2.03beta3 ELECTRONICS: Duet WiFi 1.02 or later FIRMWARE_DATE: 2019-03-25b6<LF>ok<LF>
              The M997 S1 gives following message:
              Trying to connect at 230400 baud: failed<LF>Trying to connect at 115200 baud: failed<LF>Trying to connect at 74880 baud: failed<LF>Trying to connect at 9600 baud: failed<LF>Error: Installation failed due to comm write error<LF>ok<LF>
              I checked the bits per second under the serial port section it is given as 9600 (in YAT) which I am assuming is the baud rate.
              Not sure why it dint connect with the 9600 baud rate ?
              Went ahead with the other commands anyways , but no luck.
              Looks like the WiFi module has failed. Please ask your supplier to replace your Duet.
                My supplier is e3d ,
                can I take a screen shot of this conversion ?
                  Yes, or if you are emailing them, include a link to this thread
                  • supermoto7undefined
                    supermoto7 @dc42
                    @dc42 I had the same problem as OP and this fixed it first try. Thank you, and please consider adding this to the getting connected guide. Cheers!
                    • FelixHundefined
                      FelixH
                      A friend of mine has the same problem and has some wifi modules lying around. Would it solve the problem replacing the module or it has nothing to do with it?
                        dc42 administrators @FelixH
                        @FelixH said in Failed to add SSID to remember list:
                        Probably nothing to do with it. Check that you are running recent main firmware (2.05 or 3.0 or 3.01beta) and WiFi module firmware (1.23).
                        • FelixHundefined
                          FelixH
                          well, apparently he solved it by resoldering the connections of the wifi module... I wouldn't have done it, bu he's braver... thanks
