    mellow nf crazy hotend
    Off Topic
    15
    53
    12.6k
    • wescundefined
      wesc
      The real Mosquito has all kinds of problems with jamming with pla, even with a fan. The forums and discordโ€™s are littered with people complaining about mosquito pla jams. Itโ€™s either heat creep or too small diam tube.
      Pla is a difficult case because its hdt is so low, but itโ€™s ironic that the most expensive hot end canโ€™t reliably print the most common cheapest filament
      CroXY - Crossed Gantry Printer, Ultibots D300VS+, Custom CoreXYU
        A Former User @jens55
        @jens55 said in mellow nf crazy hotend:
        The Mosquito costs more than some complete printers. Why would a sane person pay this much ? What do you get that you don't get with an E3D V6 for example ?
        This is not a poke but a serious question because I always wondered why anybody would buy a hot end THAT expensive (unless it's for bragging rights)
        'cause nothing on those printers is wort having... I tested how much I can put into one wanhao I3 and after 2000$ I stopped ... not even the cables on those printers are ok ๐Ÿ˜ž .. if you want that level of quality they are great but ..
        now, expensive is very subjective term .. V6 is $65 it's big, it's clunky and is not very good design imo ๐Ÿ˜ž .. try printing miniatures out of PLA with it and you'll know .. try printing slow PP with it and you'll know .. try printing anything very slow with it and you will know ๐Ÿ˜ž .. it's very log, it's not very cold and all in all it is decade old design ... what's good about e3d is nozzles, they are awesome, and that heatblocks thye have are decent (prc ones are otoh same quality 10% the cost) .. so the V6 is tbh outdated big time.. and why it gets you better quality then some shitty mk6/mk8/mk10/mk11 clone el-cleapo prc printers come with is usually not because you moved to V6 but because you moved to e3d nozzle.
        mosquito, as advertised (can't say, still have not tested original, friend got original he should be puting it on his D9 these days so we'll know), can do all that ... first it's small and light and short .. if you ever printed shitty materials like PP you know short is super important .. the heat creep does not exist so you can print slow ... you don't have creep issues if you add vulcano, 1mm nozzle and you push kilo of filament an hour, but print slow, 0.02mm layer, 0.2mm nozzle, 5mm/sec and you see how your V6 will block ... they say mosquito will not, dunno, we'll see .. the mellow blocks for sure .. price .. well it's price of 3 v6, that's not that much more expensive, and even if you pimp your v6 with better throat, better heat block .. you end up with $100 so mosquito is just 50% over .. for a lot more performance - as advertised!!!! before I try original it's all alleged for me ๐Ÿ™‚
          A Former User @grizewald
          @grizewald said in mellow nf crazy hotend:
          The ability to change nozzles without a complex procedure involving needing three hands and working with a fully heated hot end at over 200ยฐC.
          I know for them that's a big selling point, for me that's a load of... I never had an issue changing nozzle on any of my printers except on those where I made the hotend myself where nozzle is just integral part of everything and is not changeable... and like you change nozzles twice a day so that's a huge problem
            titanium heat break instead of the steel one I currently use.
            get the original from e3d (heat break), the prc ones are bad, they are not polished inside
              A Former User @wesc
              @wesc said in mellow nf crazy hotend:
              had no clue, good to know
              well I always suggest ppl wanting to upgrade hotend that if they are going to print mostly PLA their original "shitty" PTFE lined extruder will usually perform much better than fancy expensive all metal one.. I don't print with PLA much .. this extruder I tested first with ABS (did actually a 20+ hours single print with it without problem) but was not able to print a single line with PLA, jams immediately.. cooling, no cooling does not make a difference ๐Ÿ˜ž ... but the thing is I wanted this ender5 to be PLA printer, I have already 3 dedicated ABS printers, wanted E5 to be PLA printer and this new toolchanger from e3d to be the "universal/testing" platform .. so I'm going to dig out my original aero that's sitting somewhere in some box and use that on ender and I'll use the flex3drive on the toolchanger
                A Former User
                what's totally crazy here is that PETG is behaving like polimorf ๐Ÿ˜ž .. the mellow top is touching 8mm thick almost full infill (3mm+3mm solid and 2mm 80% infill with 6 perimeters 0.5mm) and two M2.5 screws that go trough it and reach embedded M2.5 nut.. mellow's heatsink managed to heat up screws so much that nuts sank into plastic more than .5mm (maybe even a whole mm) in "no time printing" .. and there are M2.5 washers, steel ones, under those nuts .. that tells me the top of the heatsink (30C on original images) is way over 90C
                  deckingman @A Former User
                  @smece Well it's called a "crazy" hot end - guess that's why โ˜บ
                  My best guess would be that the 4 "pillars" between the heater block and the (what should be ) cold part are made from solid rod, whereas on the genuine Mosquito, they are are the same 75 micron thin wall tubing. Are you able to take it apart to check?
                  • dragonnundefined
                    dragonn @A Former User
                    @smece I am cooling my Dragon Hotend with two 30mm fans in a push-pull configuration and I am cooling my V6 also in this way. The intake fan is a Sunon 30x10mm and the outtake is also a Sunon but 30x20mm. In this way I think my hotend cooling chamber is under lower pressure with sucks even more air.
                    A Former User? 1 Reply Last reply Reply Quote -1
                    • mrehorstdmdundefined
                      mrehorstdmd @jens55
                      @jens55 The E3D V6 isn't a particularly good design. It works, and thermal management is OK, but there are mechanical problems.
                      The mount is large and round, with no flats to prevent the heatsink from rotating in the extruder- you have to rely on clamping pressure to prevent the heatsink from turning. The heatbreak threads into the heatsink, but there is no way to twist it in securely. The result is that through temperature cycling and vibration, it eventually works loose during prints and allows the heater block and heatbreak to wobble, completely wrecking print quality. The heatsink fins are round and the fan mount is a piece of plastic that snaps on. There's nothing to stop the fan from rotating on the heatsink, and it does, whichever way the wires pull it. Sooner or later it contacts the heater block and melts. The heatbreak throat is very thin and can easily be broken if twisted too hard, and will readily bend if you crash the nozzle into the bed (and who has never done that?).
                      I've been using a $18 hotend from China on my printer for close to two years without problems. It uses the same round mount E3D uses, but makes several improvements over the E3D unit. The heatbreak is held in place with set screws, so it can't rotate. The heatbreak throat is thicker than E3D's and doesn't bend when you have a head crash. The supplied fan is junk (aren't they all?) but it mounts on a metal bracket that is screwed to the heatsink so it never loosens or rotates. Replacing the fan with a $7 Sunon unit solves the fan problem. It uses E3D type nozzles. I print ABS, TPU, PETG, and occasionally PLA without any issues.
                      • jens55undefined
                        jens55
                        I can see some issues with the V6 but if it is as bad as it sounds then why did Slice Engineering make the 'Copperhead' hot end which is a somewhat improved V6 ?
                        I don't actually use the V6 heat sink, I use the Chimera heat sink. So far I have only bent one heat break and it took considerable effort. It is still quite usable although when you use the bent heat break in a two material setup it gets to be a pain to keep track of the offsets between nozzles which keeps changing based on the rotational position of the heat break. There are set screws for the heat break and because the nozzle top tightens against the heat break bottom, I have never run into an issue with the nozzle loosening. I have run into the nozzle loosening issue in the common hot ends as used for example in the Creality CR10 as the nozzle never locks against the heat break.
                        mrehorstdmd, any chance of a URL to point to the hot end you are using ?
                        A Former User? mrehorstdmdundefined 2 Replies Last reply Reply Quote 0
                          A Former User @deckingman
                          @deckingman said in mellow nf crazy hotend:
                          It came disassembled ๐Ÿ˜„ .. yes they are tubing, I'd say regular stainless steel, they are very thin walled, easy to damage, tubes ... I didn't measure how thick they are, eyeballing them I'd say .1mm but I will check them under microscope to measure exact thickness
                            A Former User @dragonn
                            @dragonn said in mellow nf crazy hotend:
                            Dragon Hotend
                            Seen the dragon few weeks ago, looks like they copied the idea from mosquito but made it bigger and easier to manufacture maybe, dunno ..
                            I'm cooling the mosquito mellow crazy hotend with single 25x5mm fan (can't fit bigger fan there nor there will be point imo .. now 25x5mm fans are puny as you know and I have not seen 25x10 .. I have only one on mellow and in theory, I can add one on the back to have push-pull too but they are advertising that it can work without any fans ๐Ÿ˜„ so while it can maybe made to work acceptably, imo this is a total fail ๐Ÿ˜ž I'll rather go back to V6 or TitanAero as I don't see the benefit of mosquito this clone then... I wanted to use it to print PLA not PEEK ๐Ÿ˜ž
                            A Former User? deckingmanundefined 2 Replies Last reply Reply Quote 0
                              'cause they wanted to have cheaper hotend in their portfolio ?
                                A Former User
                                I used e3d X nozzle for this test, first time I tried X nozzle, they are support to have some polyfobic coating that makes plastic not stick to them ... well ..
                                (yes I already moved it to V6 ..) this green/blue thing is PLA, I cleaned the inside with nylon (not very good I might add will have to repeat that) but the outside won't clean easy .. will have to check it out later but it's hardly polyfobic
                                jens55undefined DaBitundefined 2 Replies Last reply Reply Quote 0
                                • jens55undefined
                                  jens55
                                  Well yes, that makes sense .... but if it was THAT bad, they wouldn't want to sully their brand name with it. It looks like it will only be marginally cheaper but could easily capture more market share from those of us who didn't win in the lottery.
                                  BTW, in Canadian currency the price for the Mosquito is as follows:
                                  Hot end $200
                                  heater $30
                                  temperature sensor $57
                                  fan not listed by vendor
                                  tip $56
                                  Thermal paste $16
                                  For a whopping total of $359 minus the fan
                                  The same supplier lists the E3D V6 full kit with fan for $79 (with heater, sensor, fan and small bit of thermal paste but only a regular nozzle)
                                  ... and then it has problems printing PLA .....
                                  • jens55undefined
                                    jens55 @A Former User
                                    @smece said in mellow nf crazy hotend:
                                    Thank you for posting that! I was pondering on trying that nozzle next at $43 * 2 .... so with freight you just saved me a cool $100 (yeah it's only Canadian dollars but it's still better than a poke in the eye with a sharp stick)
                                    Edit: if you read the details it says it will stick 'less' ... not that it won't stick ๐Ÿ˜ž
                                      A Former User @A Former User
                                      now 25x5mm
                                      I actually found I have 25x10mm 12V few pieces, I assume they will cool way better than these 25x5mm 5V so I'll give it a go with 2 fans push/pull with these bigger 25x10mm 12V ..
                                        everything else I can explain, the price, why ppl would buy it, everything ... but not this ๐Ÿ˜ž ... if it's not printing PLA there will be a hell to pay ๐Ÿ˜ž
                                        I don't see it stick less ... on another printer where I have same nozzle for ~3 years now, some microswiss hardened steel one (not black, shiny) where I printed a lot of ABS and PETG and it's still shiny .. the alu heatblock is black and disgusting but nozzle is shiny ... this "polyfobic" nozzle didn't print anything and it's already dirty ๐Ÿ˜ž ... just my ranting about e3d today nothing else .. nozzle probbly performs good have not yet done a proper test (got .2, .3 and .5 of those X ones, now I put regular brass one in the mellow as no point using X for any testing now, I doubt that printer will see much printing ๐Ÿ˜ž since if it does not become operational till monday it will go in the garage waiting next free time slot to be dedicated to it (and that's not slice nor e3d fault, only my missmanagement of time ๐Ÿ˜ž and stupid decisions)
                                          I'm cooling the mosquito with single 25x5mm fan (can't fit bigger fan there nor there will be point imo .. now 25x5mm fans are puny as you know and I have not seen 25x10 .. I have only one on mellow and in theory, I can add one on the back to have push-pull too but they are advertising that it can work without any fans ๐Ÿ˜„ so while it can maybe made to work acceptably, imo this is a total fail ๐Ÿ˜ž I'll rather go back to V6 or TitanAero as I don't see the benefit of mosquito then... I wanted to use it to print PLA not PEEK ๐Ÿ˜ž
                                          ..............and this is exactly what really hacks me of about people buying clones. Not only does it not work, but then the original gets the bad reputation for all the faults that the cheap, crap, clone has.
                                          You say you are quote "cooling the mosquito with single 25x5mm fan". But you are not ! You are cooling the cheap crap "mellow nf crazy" hot end with a single fan. Then you go on to say "I'll rather go back to V6 or TitanAero as I don't see the benefit of mosquito" but you haven't tried a Mosquito! Just a cheap crap clone that looks like one.
                                          It reminds me of a post I saw elsewhere some time back from someone who bought a cheap, crap, clone of a Diamond hot end that didn't work. It later transpired that the cheap crap clone was actually made from brass plated steel rather than solid brass. But rather than face up to the fact that the cheap clone was crap, the OP insisted that all Diamond hot ends were crap.
                                            deckingman @jens55
                                            Hot end $200
                                            heater $30
                                            tip $56
                                            Thermal paste $16
                                            You only need buy the hot end for 200 C$. You can use a cheapo heater and it'll likely work just as well but maybe not as reliably. You don't need buy the high temperature sensor, you can use any cheapo thermistor if all you want to print is "normal" filaments. You don't need buy the vanadium nozzle - you can use any M6 x 1 threaded nozzle. You don't need to buy the Boron Nitride paste, you could use something like Loctite 8065 (or nothing at all).
                                            As for problems printing PLA, are you sure or is that just hearsay? Do these problems exist with the genuine part of just the cheap clones (we can see above how problems with cheap clones tarnish the reputation of the genuine article). Are the "problems" down to user error? i.e. people turning the printer or fan off before the hot end has fully cooled.
