    Bench Testing Mixing Extruder with Pronterface
    1.2k
    • ractorIIIundefined
      ractorIII @Phaedrux
      @Phaedrux running 3.0 and I have also tried the web interface - more comfortable with printrun at the moment
      clay/ceramic slurry printing - experimental multi-material mixing for ceramics - shapeoko based carteisian - kossel based inverted delta -instagram @earlyamericanrobotpottery
        It would appear that you don't have any tools defined at all.
        ractorIIIundefined 1 Reply Last reply Reply Quote 0
          deckingman @ractorIII
          @ractorIII
          https://duet3d.dozuki.com/Wiki/Gcode#Section_M563_Define_or_remove_a_tool
          https://duet3d.dozuki.com/Wiki/Gcode#Section_M567_Set_tool_mix_ratios
            ractorIII @Phaedrux
            @Phaedrux - it does seem there are not tools. Hmm - I used the Web RRF Config Tool - I guess I'll go back and run that again. Thanks - just finding the config.g file was super helpful. I was confused why my config file was so hard to decipher.
              ractorIII @deckingman
              @deckingman Thanks for pointing me in the right dirrection - much appreciated.
                @ractorIII No worries. Come back if you need more help.
                  @deckingman - with that note - trouble - I was expecting to be able to designate a tool that utilized 5 extruders with a simple text command M563 P0 D0:1:2:3:4 with printrun it bounces back that there is an error with the drive numbers. Also - I have not been able to issue simple gcode commands via Duet Web Control - though I am able to connect...
                    What does the error say?
                    What happens when you try to send commands in the DWC console?
                      ractorIII @Phaedrux
                      @Phaedrux Nothing happens when I attempt to send gcode through the Duet Web Interface - though the log state that I am connected, the log does not indicate that any code was sent. Another issue that I am having with DWC is that if I attempt to upload the zipped reprap config file I get an AJAX error and it disconnects. If I remember right - I was having this issue before and had to disconnect my power supply from the board and run it strictly of usb to get the upload to work - very inconvenient. I guess I'll open my housing and pull the micro SD out to update reprap config files.
                      To the issue at hand, which is getting a tool designated for bench testing my extruder setup. The following is how print run responds when issued:
                      SENDING:M563 P0 D0:1:2:3:4
                      Error: Tool creation: bad drive number
                      [ERROR] Error: Tool creation: bad drive number
                      I'm using a duet wifi with x5 expansion - I have a total of 7 extruder steppers and for this tool I am trying to use the 2 that are on the Duet Wifi and the first 3 that are on the x5 expansion.
                        Sounds like you might have a mismatched DWC version? What versions are you running?
                          ractorIII @Phaedrux
                          @Phaedrux - you may be right - this is what is listed on DWC. Should the Web Interface Version be HTML: 3.0? I'm starting to get very confused...
                          Firmware Version: 3.0 (2020-01-03b3)
                          Web Interface Version: HTML: 1.11
                            https://github.com/chrishamm/DuetWebControl/releases
                            Try uploading this zip file https://github.com/chrishamm/DuetWebControl/releases/download/2.0.7/DuetWebControl-SD.zip
                            ractorIIIundefined 2 Replies Last reply Reply Quote 0
                              ractorIII @Phaedrux
                              @Phaedrux - not able to upload file with DWC - followed instructions here:
                              https://duet3d.dozuki.com/Wiki/Installing_and_Updating_Firmware#Section_Updating_WiFi_firmware_or_DuetWebControl_files
                              to unzip DuetWebControl-SD.zip onto SD card after deleting old file contents
                              issue remains - AJAX error when uploading files via DWC
                                Just to confirm, you've wiped out the /www folder and replaced it with the contents of the zip file and the DWC version now shows as 2.0.7?
                                What browser are you using?
                                  ractorIII @Phaedrux
                                  @Phaedrux -scratch that - installed and seems to be in sync now.
                                  still trouble defining tool head - same bounce back from DWC on issuing M563 P0 D0:1:2:3:4
                                  'tool creation:bad drive number
                                    @ractorIII said in Bench Testing Mixing Extruder with Pronterface:
                                    M584 X0 Y2 Z1 E3:4:5:6:7:8 ; set drive mapping
                                    How do you have your motors connected? The drive mappings don't match what you're trying to use for tool drives.
                                    https://duet3d.dozuki.com/Wiki/Gcode#Section_M584_Set_drive_mapping
                                      ractorIII @Phaedrux
                                      @Phaedrux
                                      ; generated by RepRapFirmware Configuration Tool v2.1.8 on Sat Feb 01 2020 21:20:25 GMT-0500 (Eastern Standard Time)
                                      M550 P"My Printer" ; set printer name
                                      M552 S1 ; enable network
                                      M586 P0 S1 ; enable HTTP
                                      M586 P1 S0 ; disable FTP
                                      M586 P2 S0 ; disable Telnet
                                      M569 P0 S0 ; physical drive 0 goes backwards
                                      M569 P2 S0 ; physical drive 2 goes backwards
                                      M569 P4 S1 ; physical drive 4 goes forwards
                                      M569 P5 S1 ; physical drive 5 goes forwards
                                      M569 P6 S1 ; physical drive 6 goes forwards
                                      M569 P7 S1 ; physical drive 7 goes forwards
                                      M569 P8 S1 ; physical drive 8 goes forwards
                                      M569 P9 S1 ; physical drive 9 goes forwards
                                      M584 X0 Y2 Z1 E3:4:5:6:7:8:9 ; set drive mapping
                                      M350 X16 Y16 Z16 E16:16:16:16:16:16:16 I1 ; configure microstepping with interpolation
                                      M92 X87.58 Y87.58 Z1511.57 E3200.00:3200.00:3200.00:3200.00:3200.00:3200.00:3200.00 ; set steps per mm
                                      M566 X900.00 Y900.00 Z12.00 E120.00:120.00:120.00:120.00:120.00:120.00:120.00 ; set maximum instantaneous speed changes (mm/min)
                                      M203 X6000.00 Y6000.00 Z180.00 E1200.00:1200.00:1200.00:1200.00:1200.00:1200.00:1200.00 ; set maximum speeds (mm/min)
                                      M201 X500.00 Y500.00 Z20.00 E250.00:250.00:250.00:250.00:250.00:250.00:250.00 ; set accelerations (mm/s^2)
                                      M906 X800 Y800 Z800 E800:800:800:800:800:800:800 I30 ; set motor currents (mA) and motor idle factor in per cent
                                      M84 S30 ; Set idle timeout
                                      M208 X-315 Y-650 Z-50 S1 ; set axis minima
                                      M208 X315 Y650 Z300 S0 ; set axis maxima
                                      M574 X0 Y0 Z0 S0 ; set active low and disabled endstops
                                      M558 P0 H5 F120 T6000 ; disable Z probe but set dive height, probe speed and travel speed
                                      M557 X-300:215 Y-635:195 S20 ; define mesh grid
                                      M140 H-1 ; disable heated bed
                                      M106 P0 C"FAN3" S1 I0 F500 H-1 ; set fan 0 name, value, PWM signal inversion and frequency. Thermostatic control is turned off
                                      M106 P1 C"FAN4" S1 I0 F500 H-1 ; set fan 1 name, value, PWM signal inversion and frequency. Thermostatic control is turned off
                                      M106 P2 C"FAN5" S1 I0 F500 H-1 ; set fan 2 name, value, PWM signal inversion and frequency. Thermostatic control is turned off
                                      M563 P0 S"V" D0:1:2:3:4 F-1 ; define tool 0
                                      M568 P0 S1 ; enable mixing for tool 0
                                      M567 P0 E0.2:0.2:0.2:0.2:0.2 ; set mixing ratios for tool 0
                                      T0 ; select first tool
                                        ractorIII @Phaedrux
                                        @Phaedrux - yeah - I wasn't sure if the drive should match the extruder number or the drive number, so I tried both M563 P0 D0:1:2:3:4 and M563 P0 D3:4:5:6:7 am getting the same 'tool creation: bad drive number. I read the sections on drive mapping and tool defining and everything seems to be in order. Unless I missed something. Dumbfounded at the moment.
                                          @ractorIII The drive numbers used when you define a tool refer to the extruder drives in the order that they are created. So if you have physical drives assigned to extruders 3 to 7 in M584 then the extruder drive numbers when you define a tool are 0 to 4. Which looks like that's how you have done it.
                                            dc42 administrators @ractorIII
                                            Perhaps the M584 command to set up the extruder drives failed. If you send M584 without parameters, what does it report?
                                            EDIT: maximum number of extruders supported by RRF3 on Duet 2 is 6. So your command:
                                            is failing because you are trying to create 7 extruders. If you really need 7 then I can increase the limit.
