Heater failures, only upon restart.
auto-tuning auto tuning heater fault heater failure
469
    CCS
    Railcore II ZLT
    Firmware Electronics: Duet WiFi 1.02 or later + DueX5
    Firmware Version: 2.03 (2019-06-13b2)
    WiFi Server Version: 1.23
    Web Interface Version: 1.22.6
    I am getting an issue where when I turn the machine on, there is always a heater fault on the hotend. I run the autotuning (M303 H1 S245), then save with m500 after it completes without error. The printer will then print without issue.... Until I turn it off. Then, I restart the machine, and the hotend faults again in the exact same way... WTF am I missing here?
    I do not know if it is related as I haven't had time to track it down... but I am also having an issue with layer adhesion, despite the PLA becoming nice and gooey when i ramp up the temps.
    Thanks for your assistance in advance.
    config-override.txt config-user.txt config.txt Bed-Prep PLA.txt
      jens55
      I don't know if it is related but I have experienced (and mentioned) something similar. It appears that a flag is set for some errors and not cleared properly. If I recall correctly, the only way it is cleared is to power cycle the printer. I have gotten used to just dismissing the error and it will just happily carry on.
      You use the words 'turn the machine on' .... if this is from a power off state then the issue I am encountering is likely different.
        CCS
        Yes, it is from a power off state or an M999 command. I use m562 to clear the fault and run the auto-tune feature. It just fails every time i turn the machine on until i run auto-tune.
          SIam
          i hope i have nothing overseen but i miss in your config M501 (which will load the config override file with your pid data)
          Hypercube-Evolution-Hybrid, Piezo Orion, Orbiter
          RepRapFirmware for Duet 2 WiFi/Ethernet 3.4.0beta4 (2021-09-27 11:30:36)
          Duet WiFi Server: 1.26
          Duet Web Control 3.4.0beta4 (2021-09-27)
          undefined 2 Replies Last reply 2 Feb 2020, 20:42 Reply Quote 1
            CCS @SIam
            @SIam M501 is in my config.g. Is this the proper file? Now that you say that, it IS NOT at the bottom of the page, it's somewhere halfway up.
            I moved it to the bottom of config.g and I am not going to test it to see if it works.
              CCS @SIam
              @SIam Looks like that did it. Moving the m501 command to the bottom of the page worked. Order of operations matters! 😜
              Thanks! 😄
              undefined 1 Reply Last reply 2 Feb 2020, 23:20 Reply Quote 0
                Phaedrux Moderator @CCS
                @CCS did it happen to be above the default heater values?
                undefined 1 Reply Last reply 3 Feb 2020, 04:28 Reply Quote 0
                  CCS @Phaedrux
                  @Phaedrux No. well below thresholds. The issue has been solved and noted in my above statement. Thanks
                  8 out of 8
