    Duet Wifi Hangs up after booting about 1 out of 5 times
    42
    2.0k
      Please post a full M122 report.
      • Dougal1957undefined
        Dougal1957 @Danal
        This post is deleted!
        • gta18undefined
          gta18
          Sorry for the late reply. But here's the m122 report screenshot.
          thanks
          https://www.amazon.com/photos/shared/lXQNAkoJSMO044FHVWApOw.PGAgU00Nab0LtoQoQrNJba
            A Former User
            You'll need to use a usb cable and a terminal to capture the full output.
            • gta18undefined
              gta18
              I thought I was missing something just seeing it so short. Thanks for the advise. Here's the report on v3
              Attempting connection at \\.\COM5...
                Testing plaintext communication protocol...
              READ: ok
                Connected to machine!
              SENT: T0
              READ: ok
              SENT: M105
              READ: ok T:2000.0 /120.0 T0:2000.0 /120.0 B:25.5 /0.0
              READ: Error: Temperature reading fault on heater 1: unknown sensor
              SENT: m122
              READ: === Diagnostics ===
              READ: RepRapFirmware for Duet 2 WiFi/Ethernet version 3.0 running on Duet WiFi 1.02 or later
              READ: Board ID: 08DJM-9178L-L2MSD-6J9DL-3SD6T-KVDYP
              READ: Used output buffers: 1 of 24 (6 max)
              READ: === RTOS ===
              READ: Static ram: 30516
              READ: Dynamic ram: 91592 of which 28 recycled
              READ: Exception stack ram used: 256
              READ: Never used ram: 8680
              READ: Tasks: NETWORK(ready,1676) HEAT(blocked,920) MAIN(running,4124) IDLE(ready,156)
              READ: Owned mutexes:
              READ: === Platform ===
              READ: Last reset 00:00:13 ago, cause: power up
              READ: Last software reset at 2020-02-07 17:53, reason: User, spinning module GCodes, available RAM 8180 bytes (slot 2)
              READ: Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0041f000 BFAR 0xe000ed38 SP 0xffffffff Task 0x4e49414d
              READ: Error status: 0
              READ: Free file entries: 10
              READ: SD card 0 detected, interface speed: 20.0MBytes/sec
              READ: SD card longest block write time: 0.0ms, max retries 0
              READ: MCU temperature: min 30.7, current 34.0, max 34.1
              READ: Supply voltage: min 1.2, current 1.6, max 1.6, under voltage events: 0, over voltage events: 0, power good: no
              READ: Driver 0: ok, SG min/max not available
              READ: Driver 1: ok, SG min/max not available
              READ: Driver 2: ok, SG min/max not available
              READ: Driver 3: ok, SG min/max not available
              READ: Driver 4: ok, SG min/max not available
              READ: Date/time: 1970-01-01 00:00:00
              READ: Cache data hit count 17245507
              READ: Slowest loop: 1.67ms; fastest: 0.07ms
              READ: I2C nak errors 0, send timeouts 0, receive timeouts 0, finishTimeouts 0, resets 0
              READ: === Move ===
              READ: Hiccups: 0(0), FreeDm: 169, MinFreeDm: 169, MaxWait: 0ms
              READ: Bed compensation in use: none, comp offset 0.000
              READ: === MainDDARing ===
              READ: Scheduled moves: 0, completed moves: 0, StepErrors: 0, LaErrors: 0, Underruns: 0, 0
              READ: === AuxDDARing ===
              READ: === Heat ===
              READ: Bed heaters = 0 -1 -1 -1, chamberHeaters = -1 -1 -1 -1
              READ: === GCodes ===
              READ: Segments left: 0
              READ: Stack records: 1 allocated, 0 in use
              READ: Movement lock held by null
              READ: http is idle in state(s) 0
              READ: telnet is idle in state(s) 0
              READ: file is idle in state(s) 0
              READ: serial is ready with "m122" in state(s) 0
              READ: aux is idle in state(s) 0
              READ: daemon is idle in state(s) 0
              READ: queue is idle in state(s) 0
              READ: autopause is idle in state(s) 0
              READ: Code queue is empty.
              READ: === Network ===
              READ: Slowest loop: 1.26ms; fastest: 0.00ms
              READ: Responder states: HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0)
              READ: HTTP sessions: 0 of 8
              READ: - WiFi -
              READ: Network state is changing mode
              READ: WiFi module is trying to connect
              READ: Failed messages: pending 0, notready 0, noresp 0
              READ: WiFi firmware version 1.23
              READ: WiFi MAC address bc:dd:c2:57:ad:41
              READ: WiFi Vcc 3.47, reset reason Turned on by main processor
              READ: WiFi flash size 4194304, free heap 28104
              READ: Socket states: 0 0 0 0 0 0 0 0
              READ: ok
              SENT: M105
              READ: ok T:2000.0 /0.0 T0:2000.0 /0.0 B:25.5 /0.0
              SENT: M105
              • gta18undefined
                gta18
                Flashed it to v2.05 with the same issues. Here's the report when on v2.05.
                READ: RepRapFirmware for Duet 2 WiFi/Ethernet version 2.05 running on Duet WiFi 1.02 or later
                READ: Used output buffers: 1 of 24 (3 max)
                READ: === RTOS ===
                READ: Static ram: 25712
                READ: Dynamic ram: 93116 of which 0 recycled
                READ: Exception stack ram used: 264
                READ: Never used ram: 11980
                READ: Tasks: NETWORK(ready,1664) HEAT(blocked,1324) MAIN(running,3824) IDLE(ready,160)
                READ: Last reset 00:00:14 ago, cause: power up
                READ: Last software reset at 2020-02-07 18:14, reason: User, spinning module GCodes, available RAM 11716 bytes (slot 3)
                READ: Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0441f000 BFAR 0xe000ed38 SP 0xffffffff Task 0x4e49414d
                READ: MCU temperature: min 33.5, current 34.2, max 34.2
                READ: Supply voltage: min 1.2, current 1.2, max 1.6, under voltage events: 0, over voltage events: 0, power good: no
                READ: Cache data hit count 55012547
                READ: Slowest loop: 3.77ms; fastest: 0.05ms
                READ: === Move ===
                READ: Hiccups: 0, FreeDm: 160, MinFreeDm: 160, MaxWait: 0ms
                READ: === DDARing ===
                READ: === Heat ===
                READ: Heater 1 is on, I-accum = 0.0
                READ: Responder states: HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0) Telnet(0)
                READ: - WiFi -
                READ: WiFi flash size 4194304, free heap 28176
                READ: ok
                READ: aux: M408 S0 R4
                SENT: M105
                READ: serial: M105
                READ: ok T:33.0 /0.0 T0:33.0 /0.0 B:27.1 /0.0
                SENT: M105
                READ: serial: M105
                READ: ok T:32.9 /0.0 T0:32.9 /0.0 B:27.1 /0.0
                SENT: M105
                READ: serial: M105
                READ: ok T:32.9 /0.0 T0:32.9 /0.0 B:27.0 /0.0
                READ: WiFi module is connected to access point BBB1, IP address 192.168.2.135
                READ: aux: M408 S1
                SENT: M105
                READ: serial: M105
                READ: ok T:32.8 /0.0 T0:32.8 /0.0 B:27.0 /0.0
                Disconnected.
                • gta18undefined
                  gta18
                  My config.g on v3, e0temp pin stopped working. Temperature reads 2000. I flashed v2.05 back and e0temp works.
                  ; generated by RepRapFirmware Configuration Tool v2.1.8 on Fri Feb 07 2020 13:37:35 GMT-0800 (Pacific Standard Time)
                  G90                                                ; send absolute coordinates...
                  M83                                                ; ...but relative extruder moves
                  M550 P"NogMM3"                                     ; set printer name
                  M552 S1                                            ; enable network
                  M586 P0 S1                                         ; enable HTTP
                  M586 P1 S1                                         ; enable FTP
                  M586 P2 S0                                         ; disable Telnet
                  M569 P0 S1                                         ; physical drive 0 goes forwards
                  M569 P1 S1                                         ; physical drive 1 goes forwards
                  M569 P2 S1                                         ; physical drive 2 goes forwards
                  M569 P3 S0                                         ; physical drive 3 goes backwards
                  M584 X0 Y1 Z2 E3                                   ; set drive mapping
                  M350 X256 Y256 Z256 E256 I0                        ; configure microstepping without interpolation
                  M92 X1280.00 Y1280.00 Z6800.00 E420.00             ; set steps per mm
                  M566 X900.00 Y900.00 Z12.00 E120.00                ; set maximum instantaneous speed changes (mm/min)
                  M203 X6000.00 Y6000.00 Z180.00 E1200.00            ; set maximum speeds (mm/min)
                  M201 X500.00 Y500.00 Z20.00 E250.00                ; set accelerations (mm/s^2)
                  M906 X800 Y800 Z800 E800 I30                       ; set motor currents (mA) and motor idle factor in per cent
                  M84 S30                                            ; Set idle timeout
                  M208 X0 Y0 Z0 S1                                   ; set axis minima
                  M208 X230 Y260 Z200 S0                             ; set axis maxima
                  M574 X1 S1 P"xstop"                                ; configure active-high endstop for low end on X via pin xstop
                  M574 Y2 S1 P"ystop"                                ; configure active-high endstop for high end on Y via pin ystop
                  M574 Z1 S2                                         ; configure Z-probe endstop for low end on Z
                  M950 S0 C"exp.heater3"                             ; create servo pin 0 for BLTouch
                  M558 P9 C"zprobe.in+zprobe.mod" H5 F120 T6000      ; set Z probe type to bltouch and the dive height + speeds
                  M558 H30                                           ;*** Remove this line after delta calibration has been done and new delta parameters have been saved
                  G31 P500 X-32 Y-26 Z3.3                            ; set Z probe trigger value, offset and trigger height
                  M557 X15:230 Y15:260 S15                           ; define mesh grid
                  M308 S0 P"bedtemp" Y"thermistor" T100000 B4092     ; configure sensor 0 as thermistor on pin bedtemp
                  M950 H0 C"bedheat" T0                              ; create bed heater output on bedheat and map it to sensor 0
                  M143 H0 S120                                       ; set temperature limit for heater 0 to 120C
                  M307 H0 B1 S1.00                                   ; enable bang-bang mode for the bed heater and set PWM limit
                  M140 H0                                            ; map heated bed to heater 0
                  M308 S1 P"e0temp" Y"pt1000" R4700                  ; configure sensor 1 as PT1000 on pin e0temp
                  M950 H1 C"e0heat" T1                               ; create nozzle heater output on e0heat and map it to sensor 1
                  M143 H1 S325                                       ; set temperature limit for heater 1 to 325C
                  M307 H1 B0 S1.00                                   ; disable bang-bang mode for heater  and set PWM limit
                  M950 F0 C"fan0" Q500                               ; create fan 0 on pin fan0 and set its frequency
                  M106 P0 S0 H-1                                     ; set fan 0 value. Thermostatic control is turned off
                  M950 F1 C"fan1" Q500                               ; create fan 1 on pin fan1 and set its frequency
                  M106 P1 S1 H1 T45                                  ; set fan 1 value. Thermostatic control is turned on
                  M563 P0 D0 H1 F0                                   ; define tool 0
                  G10 P0 X0 Y0 Z0                                    ; set tool 0 axis offsets
                  G10 P0 R0 S0                                       ; set initial tool 0 active and standby temperatures to 0C
                  M501                                               ; load saved parameters from non-volatile memory
                  • gta18undefined
                    gta18
                    my Config.g on v2.05 where e0temp works for my extruder. Hopefully some simple fix to get v3 working.
                    ; Configuration file for Duet WiFi (firmware version 2.00)
                    ; generated by RepRapFirmware Configuration Tool v2.1.8 on Sun Jan 26 2020 07:53:26 GMT-0800 (Pacific Standard Time)
                    M550 P"MendelMax3Nog"                    ; set printer name
                    m111 p3 s1
                    M586 P1 S0                               ; disable FTP
                    M569 P4 S1                               ; physical drive 4 goes forwards
                    M584 X0 Y1 Z2 E4                         ; set drive mapping
                    M350 X64 Y64 Z64 E64 I0                  ; configure microstepping without interpolation
                    M92 X320.00 Y320.00 Z1600.00 E1636     ; set steps per mm
                    M208 X230 Y260 Z220 S0                   ; set axis maxima
                    M574 X1 Y2 S1                            ; set active high endstops
                    M574 Z1 S2                               ; set endstops controlled by probe
                    M307 H3 A-1 C-1 D-1                      ; disable heater on PWM channel for BLTouch
                    M558 P9 H5 F120 T6000                    ; set Z probe type to bltouch and the dive height + speeds
                    G31 P500 X-33 Y-26 Z3.4              ; set Z probe trigger value, offset and trigger height
                    M557 X15:270 Y15:260 S15                 ; defin0 mesh grid
                    M305 P0 T100000 B4800 R4700              ; set thermistor + ADC parameters for heater 0
                    M305 P1 T100000 B4725 C7.060000e-8 R4700 ; set thermistor + ADC parameters for heater 1
                    M106 P0 S0 I0 F500 H-1                   ; set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned off
                    M106 P1 S1 I0 F500 H1 T45                ; set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned on
                    M563 P0 S"Volcano 0.8" D0 H1 F0          ; define tool 0
                    • gta18undefined
                      gta18
                      here's another m122 on v3
                      M122
                      Used output buffers: 3 of 24 (9 max)
                      Static ram: 30516
                      Dynamic ram: 91832 of which 0 recycled
                      Exception stack ram used: 496
                      Never used ram: 8228
                      Tasks: NETWORK(ready,640) HEAT(blocked,816) MAIN(running,4100) IDLE(ready,156)
                      Owned mutexes:
                      Last reset 00:03:34 ago, cause: power up
                      Last software reset time unknown, reason: User, spinning module GCodes, available RAM 8512 bytes (slot 0)
                      Error status: 0
                      SD card longest block write time: 20.7ms, max retries 0
                      MCU temperature: min 31.9, current 33.5, max 33.9
                      Supply voltage: min 23.3, current 24.8, max 25.2, under voltage events: 0, over voltage events: 0, power good: yes
                      Driver 0: standstill, SG min/max 58/138
                      Driver 1: standstill, SG min/max 0/237
                      Date/time: 2020-02-08 12:48:53
                      Cache data hit count 567632536
                      Slowest loop: 37.47ms; fastest: 0.09ms
                      Hiccups: 274(0), FreeDm: 169, MinFreeDm: 163, MaxWait: 10023ms
                      Bed compensation in use: mesh, comp offset 0.020
                      === MainDDARing ===
                      Scheduled moves: 25, completed moves: 25, StepErrors: 0, LaErrors: 0, Underruns: 0, 0
                      === AuxDDARing ===
                      Heater 0 is on, I-accum = 0.1
                      Heater 1 is on, I-accum = 0.5
                      Segments left: 0
                      serial is idle in state(s) 0
                      === Network ===
                      Slowest loop: 73.70ms; fastest: 0.00ms
                      HTTP sessions: 1 of 8
                      - WiFi -
                      Network state is running
                      WiFi flash size 4194304, free heap 21656
                      WiFi IP address 192.168.2.135
                      WiFi signal strength -57dBm, reconnections 0, sleep mode modem
                        dc42 administrators @gta18
                        @gta18 said in Duet Wifi Hangs up after booting about 1 out of 5 times:
                        Quite a lot of changes to config are needed when changing from RRF2 to RRF3. If your machine has no unusual features, It is simplest to use the online configurator to generate new files. Otherwise, see https://duet3d.dozuki.com/Wiki/RepRapFirmware_3_overview#Section_Summary_of_what_you_need_to_do_to_convert_your_configuration_and_other_files.
                        gta18undefined 1 Reply Last reply Reply Quote 0
                        • gta18undefined
                          gta18 @dc42
                          So I have got the v3 running successfully but still suffering from the random bootup hanging up as before in any version. Is there anything wrong with my config?
                          Everything works now except random bootup issues.
                          Were u able to see any problems with the m122 report I posted?
                          Thanks
                          @dc42 said in Duet Wifi Hangs up after booting about 1 out of 5 times:
                            Phaedrux Moderator @gta18
                            I would check things like the power supply and the SD card. As in, perhaps you have flaky PSU, or the SD card is dying.
                            • gta18undefined
                              gta18 @Phaedrux
                              @Phaedrux I have used 3 sd cards and all have failures.
                              Ill check power supply make sure my input voltage is stable at 24v during startup.
                              • gta18undefined
                                gta18
                                I checked power supply during bootup and its rock solid at 24.13 to 24.15v all the way according to my Fluke 789.
                                Still experiencing bootup hang ups. 😞
                                  droftarts administrators @gta18
                                  @gta18 After reading through this thread, it seems likely this is a hardware issue. To confirm, the main issue is now that the board fails to boot reliably every time? The problem of external comms stopping has been solved with firmware updates? Also, how is the board mounted? Is there any possibility of short circuiting the board to it's mounting location (metal enclosure/loose wiring)? Is the board clean, ie no metal filings that could cause shorts on the board (I'd give it a vacuum clean with a soft brush to make sure)? I couldn't see any obvious problems in the M122 reports you posted.
                                  Assuming the above is all fine, I'd guess there is a floating (ie unsoldered or poorly soldered) pin or faulty component somewhere on the board, and could be almost anything connected to the processor. Can you post clear pictures of top and bottom of the board, and particular around this area?
                                  Did any of the M111 reports happen during a freeze? Actually, I'd set M111 S1 to capture all debug info (P3 is just the webserver), though don't leave this on all the time as it can affect printing because of the volume of data sent to USB. Connect USB, and connect to the Duet as quickly as possible after power up, to see if you can catch it when it hangs. This may be able to determine what's causing the hang, and indicate where to look on the board, eg gets stuck waiting for SD card, or initialising Wifi module.
                                  • gta18undefined
                                    gta18 @droftarts
                                    @droftarts Ill check/do what u suggested when I get home tonight.
                                    This is the 2nd board from amazon and did the exact same hanging up.
                                    My board right now just sits on top of an MDF board with nothing below it.
                                    One sign that I see on the paneldue when it is about to hang is that the wifi connection pop up does not show up.
                                    100% of the time I'm able to hit home and the machine finishes the homing though, but one indication that it won't respond to any more commands is that after the homing procedure it does not update where the nozzle final location is (x45 y25,z7.8) for me.
                                    But when I get a successful bootup, I'm able to print for 10hours without any snag and print again and again, just don't reboot it.
                                    It seems like to me, that some part of the external comms of the board quits working or doesn't initialize properly, both wifi and serial.
                                      To eliminate issues with the config, try an SD card with a very simple config.g on it, for example M552 S1 to turn on the network and nothing else. Then see whether that boots up reliably. If it doesn't, try without even the M552 S1 and see whether you can connect via USB after each reboot.
                                        So they are clone boards?
                                        • gta18undefined
                                          gta18
                                          not sure if they're clones. I just needed to get it same day when I bought it.
                                          • gta18undefined
                                            gta18 @dc42
                                            @dc42 I tried the M552 S1 only on the config, I got successful boot 10 out of 10.
                                            Should I just add the config line by line? Or is there an option to step it out?
                                            Thanks!
