    Trying to set up a custon CNC with duet2 wifi.
    CNC
    336
      A Former User
      Hi, I am in the process of setting up a custom made CNC. Its 4'x8' with a 2.2kw spindle and vfd. I am also using 1 Nema23 High Torque motor on the Z, 1 standard Nema23 on the X carriage and 2 standard Nema23 motors on the Y carriage. I also have a 450W 24V power supply. Will I need any other electronics and how do I configure the duet. I do have a 3D printer with a duet2 wifi. Is the programming roughly the same? Also would I need High-Power Stepper Motor Driver to run the motors. The High Torque Nema23 has a Rated current 4.2A & resistance 0.9ohms and the other Nema23's are Rated current 2.8A & resistance 1.13ohms. If someone can point me in the right direction I would appreciate it. Thank you Rich
        droftarts administrators @A Former User
        @chichirod start with the rather brief https://duet3d.dozuki.com/Wiki/Configuring_RepRapFirmware_for_a_CNC_machine
        I think you’ll need to use an external driver on the 4.2A motor if you want performance out of it. The other two should be okay, but see https://duet3d.dozuki.com/Wiki/Choosing_and_connecting_stepper_motors
        • 3DPMicroundefined
          3DPMicro
          You will need an external driver for your 4.2 amp stepper. If your Z is lead or ball screw driven consider that there is a lot of force multiplication with that arrangement. Using a 10mm lead, ball screw and 60oz/in nema 17 I get around 50lbs of force. About double that for a 5mm lead so one of the 2.8 amp, 23's may be more than adequate.
          I used the firmware for the Workbee CNC and tweaked the settings for my mill. It includes touch probe and work offset macros
          You didn't mention endstops and you may need a signal converter and some configuring for the VFD. What input does it require?
          Duet controlled Lathe, micro mill, 3d printer and 1992 Haas VF2 VMC
            jay_s_uk
            @chichirod
            Have you already purchased the duet 2?
              Duet 3 can drive that high torque Nema 23 motor directly. It also has a 5V PWM output suitable for direct connection to a PWM-to-VFD converter.
              As has already been said, Duet WiFi/Ethernet can drive the 2.8A motors directly, but not the 4.2A one, so you would need to use an external driver for that one.
                A Former User @dc42
                @dc42 if I read this correctly then the duet3 should be able to handle everything but with the duet 2 I would need external drivers.
                  A Former User @jay_s_uk
                  @jay_s_uk no not yet.
                    A Former User @3DPMicro
                    @3DPMicro ok thank you. I’ve already purchased the motors so I would rather not buy others as far as the input for the vfd I’ll have to get back to you on that one. Thank you for your help.
                      A Former User @droftarts
                      @droftarts ok thank you. I’ll read those articles.
                        jay_s_uk @A Former User
                        @chichirod I would go for the duet 3 if it's within your budget
                          @jay_s_uk yes I think that’s the way I’m definitely leaning
