    Wifi not connecting
    893
    • SIamundefined
      SIam
      Have you tried to re add your network M587 ?
      have you tried to reset your wlan router? and last change the W-lan Channel in your router
      Hypercube-Evolution-Hybrid, Piezo Orion, Orbiter
      Duet WiFi 1.02 or later + DueX5
      RepRapFirmware for Duet 2 WiFi/Ethernet 3.4.0beta4 (2021-09-27 11:30:36)
      Duet WiFi Server: 1.26
      Duet Web Control 3.4.0beta4 (2021-09-27)
      • Paddyundefined
        Paddy
        Thanks for the replies.
        @Phaedrux - Sorry I should have said that I had tried forgetting the save networks and then putting it back in. No joy.
        @SIam - I did reboot my AP and firewall but this didn't help. I've just created a new ssid for testing but got the same results. Also no other devices are having problems.
        As a test I set my mobile to be an AP and the duet wifi wouldn't connect to that either.
        I was thinking it might be hardware as I was seeing
        Error retrieving WiFi status message: bad reply format version
        but as a final test I put the card into AP mode and this worked fine - I could connect and then reach the DWC.
        Putting it back to client mode and it won't connect.
          Try reflashing the wifi server?
          Paddyundefined 1 Reply Last reply Reply Quote 0
          • Paddyundefined
            Paddy @Phaedrux
            @Phaedrux said in Wifi not connecting:
            I have reflashed the WiFi server. Didn't help
            • SIamundefined
              SIam
              have you tried to flash the latest stable rrf version 3.0?
                When connected to a USB terminal, send M98 Pconfig.g and see if you're getting any errors on execution.
                • Paddyundefined
                  Paddy
                  I really want to thanks both of you guys for taking the time to help.
                  @Phaedrux M98 Pconfig.g returned no errors.
                  @SIam I flashed fw 3.0 but still got the error. I reflashed wifiserver 1.23 but still couldn't connect. Finally I deleted my known network and reapplied it and this time it connected no problem.
                  It's a strange one as it was connecting fine with 3.0-beta3 until it stopped for seemingly no reason.
                  I think I'll stay with 3.0-release for the time being.
                    A Former User
                    This thread deals with something similar, suggested bad wifi module. But maybe you can verify you've tried the suggestions there
                    https://forum.duet3d.com/topic/10139/failed-to-add-ssid-to-remembered-list-duet-2-wifi
                    • Paddyundefined
                      Paddy @A Former User
                      @bearer said in Wifi not connecting:
                      I was thinking that was the problem, but then it worked in AP mode so that cast some doubt in my mind.
                      Anyway after multiple re-flashes and networks deleted and added it has started to work again.
                        Maybe the firmware is revolted by being on a clone. 😰
                        • Paddyundefined
                          Paddy @Phaedrux
                          @Phaedrux Possibly 🤣
                          I was upfront about using a clone and therefore appreciate the help given.
                            A Former User
                            The majority doesn't care one way or the other, but it's nice to know as component quality can be a factor.
                            I haven't studied the protocol between the esp and the duet, but I imagine AP mode is simpler than returning a list of networks so wouldn't be surprised if it worked despite failing at STA mode.
                            Silly question, but are you sure the wifi firmware upload was a success? If you have serial access maybe worth downgrading and upgrading to be relatively sure it works?
                            • Paddyundefined
                              Yeah I'm sure. I was actually running the previous version when the problem first appeared. I found a post that said it could be caused by the fw versions getting out of step - so upgrading to 1.23 was one of the first things I tried.
                                It might be worth measuring the voltage on the +3.3V rail, to see if it is within tolerance. The WiFi modules are fussier than other chips on the Duet WiFi about the supply voltage they get.
                                Is it the same ESP-12S module that we use on genuine Duets, or is it one of the older ESP-12 series modules?
                                • Paddyundefined
                                  Paddy @dc42
                                  @dc42 said in Wifi not connecting:
                                  It's the ESP-8266MOD.
                                  It's been rock solid for a year before it played up. Now that it's working again and has been stable for the last couple of days, I'm reluctant to start poking around with a probe. It would be just like me to short it out.
                                  If it plays up again I'll bear it in mind to check.
