    Firmware wishlist and priorities for Duet WiFi and Duet Ethernet
    Firmware wishlist
    113
    236
    50.8k
    • roboduetundefined
      roboduet
      1. WiFi server, specially FTP support. I'm missing it after moving from Duet 0.6
      3. Logging.
      7. Dynamic microstepping to switch from x16 interpolated mode.
      15. Support for 12864 displays.
      16. Better temperature control
      XX. Automatic firmware update from web interface (download firmware directly from internet, check md5 or sha hash and update if hashsum is ok). Plus check for updates button in DWC.
      • tomasfundefined
        tomasf
        19
        20
        16
        • 3dprinting meatheadundefined
          3dprinting meathead
          14
          8
          in no particular order
          If I can learn it, than anyone can learn it.
          • hairy_kiwiundefined
            hairy_kiwi
            3. Logging… of Temperature values also?
            15. Support for PanelOne 20x4 text displays, or possibly 12864 mono graphics displays. Especially if useful/required for controlling a machine away from its usual WiFi network?
            5. True bed levelling... The 2 z-motor solution would be sufficient for my current setup.
            1. Reworked WiFi server code... Not sure I understand the limitations of the current code base well enough, but anyway.
            17. Filament and printing time odometers.
            • Huguesundefined
              Hugues
              …And a filament monitor support based from rotary encoder
              • caphectorundefined
                caphector
                I'd love to see support for the Prometheus-style multi-filament hot ends as well. Both Prometheus and Prusa have made them. They retract filament when it's not in use and then advance the alternate filament. I think the only big change would be to filament movement distances.
                • demonio669undefined
                  demonio669
                  • Allow M117 to send message via email
                  • start and stop printing macros (o allow to send email when the print begins and ends)
                  • tomwang256undefined
                    tomwang256
                    18 - i accidently broke off my usb connector on the paneldue 😞
                    • windieselundefined
                      windiesel
                      19
                        T3P3Tony administrators
                        @caphector:
                        13, 1, 7, 2, 15
                        These are already supported. The retraction length can be set either in the slicing software or the tool change gcode.
                        • pjr3Dundefined
                          pjr3D
                          My vote(s):
                          1 - There is a need to be more tenacious about finding and then keeping a connection where there are many competing wifi routers. It is the most frustrating aspect at the moment especially in the evening when everyone in the area is going online!
                          7 - Dynamic stepping for my delta …
                          16 - Better temp control is always good.
                          18 - This is mostly a convenience but would be handy.
                          17 - Helps to keep track of usage for maintenance etc.
                          • larsundefined
                            lars
                            My vote:
                            • appjawsundefined
                              appjaws
                              I have been trying to implement a fail safe switch which will stop Z homing and move the bed down 5mm.
                              I am using your mini probe but want to test a piezo version I have constructed but I am worried that if it fails, nothing will stop the bed moving and damaging the hotend or bed surface.
                              I originally tried "M581 Z S1 T2 C0 ; Set Z stop as fail safe for Z zeroing and run /sys/trigger2.g"
                              and a /sys/trigger2.g file with the following entries G91, G1 Z5 F200
                              This works when moving the bed manually but has no effect when homing Z.
                              Deckingman suggested using the spare E0 connection "M581 E0 S1 T2 C0" this did not solve the issue and performed the same as the Z connection.
                              Does the firmware lock the system until homing has completed?
                              If so would it be possible to change that so the process can be interrupted in the way shown above or is their another way to protect the hotend and bed from probe failure?
                              appjaws - Core XYUV Duet Ethernet Duex5
                              firmware 3.5.0-rc.4 Web Interface 3.5.0-rc.4
                              Ormerod 1-converted to laser engraver, Duet wifi
                              OpenSCAD version 2024.03.18
                              Simplify3D 5.1.2
                              • lolorcundefined
                                lolorc
                                my vote is : 1, 6, 7, 8, 14
                                • jacksatundefined
                                  jacksat
                                  16
                                  14
                                  • Ntesla66undefined
                                    Ntesla66
                                    Hello, Love what you've done already! Just amazing.
                                    Cast vote as : 1, 3, 6, 8, 16.
                                    Best Regards.
                                    • Merlinundefined
                                      Merlin
                                      Vote of a 'simple' user
                                      14,
                                      13,
                                      16,
                                      17
                                      • jmjcoke2undefined
                                        jmjcoke2
                                        11
                                        14
                                        12
                                        • Loffy770undefined
                                          Loffy770
                                          4..being able to utilize 5v switches on Duex for XYZ
                                          • Reanimator2kundefined
                                            Reanimator2k
                                            19
