    Duet 3 5V issue
    504
      A Former User
      Just for clarity the default settings did not give you 5V LED when you apply Vin? (if so then, yes, sounds like its faulty)
      From the wiki:
      The default 5V power configuration is Internal 5V enable - jumpered, 5V->SBC jumpered (the Duet is powering the SBC) , SBC->5V* not jumpered. If you want the SBC to provide 5V to the Duet then remove the jumper from 5V->SBC and from Internal 5v En. Place a jumper on SBC-5V*. NOTE this bypasses the 5V protection and a fault on the SBC may damage the Duet.
      OscarGMundefined 1 Reply Last reply Reply Quote 0
        Is the 5V_IN jumper definitely in place?
        Is the 12V supply working? If so then the amber LED should be lit. If not, check the VIN fuse.
        • OscarGMundefined
          OscarGM @A Former User
          @bearer yes the 5V Led is off
          • OscarGMundefined
            OscarGM @dc42
            @dc42 yes the jumper is in place and 24V PSU is supplying the board but the 5V led is off.
              A Former User
              And the other LEDs (with Vin connected)? d6de8419-9023-4ab6-8a4b-9e2979a0c329-image.png
              • OscarGMundefined
                @bearer 24V only
                V_Fused and 12V Leds on
                24V+USB
                4 Leds on
                droftartsundefined 2 Replies Last reply Reply Quote 0
                  A Former User
                  Its over to @dc42 at this time i think
                    droftarts administrators @OscarGM
                    @OscarGM From those pictures, with 24V input there's no 5V or 3.3V LEDs, they only light up with USB power. It also looks like jumpers are on 'Internal 5V enable' and '5V->SBC' correctly. I can only assume the 5V regulator is dead, but can't see any damage to it. @dc42 to confirm?
                      @OscarGM The 5V regulator is the 8-pin chip by the corner of the inductor marked 6R8. Yours (bottom right):
                      I can't see anything obviously wrong. @dc42 ?
                        A Former User
                        Looking closer the part to the left of it isn't level, but are you sure about that being the 5V regulator? (Schematic says U5 and tiny 16 pin QFN chip) (Wrong board)
                        • OscarGMundefined
                          OscarGM @droftarts
                          @droftarts I don't know if this can clarify something https://www.dropbox.com/s/cxmiagz20t1ytjx/5V%20Regulator%20Duet%203.jpg?dl=0)
                            @OscarGM, thanks for your patience. I approve a warranty replacement for your Duet 3 main board,
                            • OscarGMundefined
                              OscarGM @dc42
                              @dc42 thank you.
                              Do I have to do something about the process?
                                @OscarGM I think you've already emailed us, I'll sort it out.
                                  droftarts administrators @A Former User
                                  @bearer said in Duet 3 5V issue:
                                  I did that too! I looked at the 3HC schematic by mistake. It made me doubt @dc42 ... but only for a minute or two!
