    Can I bypass fan VIN?
    • underpkundefined
      underpk
      Hi, recently my fans are not working on my Duet2 wifi board. I check the continuity between VIN and VIN on the jumper selection under fans connectors and they are not connect to each other.
      Can I solder a wire between this 2 points? And Am I still be able to control the fan speed?
      Thank you.
      droftartsundefined A Former User? dc42undefined 3 Replies Last reply Reply Quote 0
        droftarts administrators @underpk
        @underpk Have you checked the fan fuse? It’s the one closest to the VIN terminals, if you have a Duet WiFi 1.03 or newer.
        underpkundefined 1 Reply Last reply Reply Quote 0
        • underpkundefined
          underpk @droftarts
          @droftarts hi, I have already check and it work properly (check from VIN to both fuse leg)
          • jens55undefined
            jens55
            May I suggest that you PULL the fuse and measure it instead of trying to measure in circuit ?
              A Former User @underpk
              @underpk said in Can I bypass fan VIN?:
              you can, and if nothing else is damaged you'll be able to control the speed as the speed control is done one the negative side - but it'd be far more advisable to find out what went wrong to avoid any more damage potentially.
                dc42 administrators @underpk
                If your Duet is recent enough to have a fan fuse, that's unusual, because the fuse should protect the PCB traces.
                I suggest you use your multimeter to trace between +VIN and the fan fuse, and between the fan fuse and the VNINpin on the fan voltage select jumper; then bypass whichever of those traces has failed.
