    No output from G32 on DSF 1.2.4 / DWC 2.07
    Duet Web Control
    14
    64
    3.3k
    • mvieleersundefined
      mvieleers
      I am the aforementioned user. Physically it is working, just the output to the console is missing. It is not only the G32. I also noticed a G30 S-1 does not report to console
        mvieleers
        Tried to find out where it goes wrong...
        Started with a fresh install of Duetpi (with GUI) from here: https://duet3d.dozuki.com/Wiki/Getting_Started_With_Duet_3
        Version info:
        Board: Duet 3 MB6HC (MB6HC)
        DSF Version: 1.1.0.5
        Firmware: RepRapFirmware for Duet 3 MB6HC v0.6 or 1.0 3.01-RC1 (2020-02-08b3)
        Duet Web Control 2.0.7
        Restored my own config files.
        POSITIVE RESULT: G32 produces output in the console.
        Next steps:
        sudo apt-get update
        sudo apt-get upgrade
        Version info:
        DSF Version: 1.2.4.0
        NEGATIVE RESULT: G32 does not produce output anymore.
        This confirms that the root cause lies within the DSF version (As kraeger also produced output with DSF 1.2.3.0, we can narrow it down to changes made between 1.2.3.0 and 1.2.4.0.) or with a conflicting update in any of the other 146 updates available since this version of Duetpi.
        • Danalundefined
          Danal
          I'll do an upgrade and report back.
          • Luke'sLaboratoryundefined
            Luke'sLaboratory
            Actually, I'll pile in here -
            I went and checked mine and yep, I'm not getting console readouts for G32 NOR something like a G30 S-1. Anything that's supposed to use the built-in echo just doesn't work. I didn't notice because it physically works, which is all I noticed.
            RC1 with DSF1.2.4 and DWC2.0.7, Duet 3 with PI.
            Luke
            http://lukeslab.online
            • blt3dpundefined
              blt3dp
              I wanna say that I first installed my Duet 3, upgraded to RRF 3 stable and all the packages that go with it that I didn’t see the G32 response. There was an update somewhere in between there and now that I was getting it but when DWC 2.0.7 came out and I upgraded all packages, the G32 responses stopped.
              My 3D Printing YouTube Channel
              Better Living Through 3D Printing
              Follow me on Instagram and Twitter
              Instagram
              Twitter
              • Danalundefined
                Danal
                After an apt-get sequence, I still get it just fine.
                Firmware: RepRapFirmware for Duet 3 MB6HC v0.6 or 1.0 3.0 (2020-01-03b3)
                Chrome browser, if that makes any difference.
                2/15/2020, 7:14:53 PM G32
                Leadscrew adjustments made: 0.118 0.120 0.109, points used 3, deviation before 0.115 after 0.000
                • kraegarundefined
                  kraegar
                  Tried in chrome just to verify (I usually use Firefox)
                  • Danalundefined
                    Danal
                    What is in your bed.g?
                    mvieleersundefined 1 Reply Last reply Reply Quote 0
                      mvieleers @Danal
                      @Danal
                      ; bed.g
                      ; generated by RepRapFirmware Configuration Tool v2.1.8 on Thu Jan 23 2020 14:06:49 GMT+0100 (Midden-Europese standaardtijd)
                      M561 ; clear any existing bed transform
                      G1 Z5 H2 ; move nozzle up
                      ;4-point bed levelling
                      G30 P0 X15 Y45 Z-99999
                      G30 P1 X15 Y275 Z-99999
                      G30 P2 X275 Y275 Z-99999
                      G30 P3 X275 Y45 Z-99999 S3
                      G1 X0 Y0 F5000 ; move the head to the corner (optional)
                      • Danalundefined
                        Danal
                        Hmmm... I'm really stumped. I don't see any differences that would make a difference, and I'm getting it consistently.
                        • Danalundefined
                          Danal
                          SSH into your Pi, and try the following (while you run a G32):
                          • sudo journalctl -fu duetcontrolserver
                          If that doesn't show anything relevant, then:
                          • sudo journalctl -fu duetwebserver
                          There will (should) be a lot more output on the webserver, and again, it is up to our eyeballs to see if anything is relevant.
                          • chas2706undefined
                            chas2706
                            Hi, I mentioned in another post that since upgrading to RRF3.01_RC1 I too do not get any output from G32. I have Duet3 with raspberry pi.
                            • chas2706undefined
                              chas2706
                              @Danal said in No output from G32 on DSF 1.2.4 / DWC 2.07:
                              This is my output from the above command:
                              Feb 17 10:50:26 Duet3 DuetControlServer[345]: [info] Executing nested macro file Leadscrew_Levelling.g on channel HTTP
                              Feb 17 10:50:26 Duet3 DuetControlServer[345]: [info] Executing nested macro file bed.g on channel HTTP
                              Feb 17 10:50:26 Duet3 DuetControlServer[345]: [info] Executing nested macro file homeall.g on channel HTTP
                              Feb 17 10:50:35 Duet3 DuetControlServer[345]: [info] HTTP: Optional macro file deployprobe.g not found
                              Feb 17 10:50:52 Duet3 DuetControlServer[345]: [info] HTTP: Optional macro file retractprobe.g not found
                              Feb 17 10:50:52 Duet3 DuetControlServer[345]: [info] HTTP: Optional macro file deployprobe.g not found
                              Feb 17 10:51:02 Duet3 DuetControlServer[345]: [info] HTTP: Optional macro file retractprobe.g not found
                              Feb 17 10:51:02 Duet3 DuetControlServer[345]: [info] HTTP: Finished macro file homeall.g
                              Feb 17 10:51:02 Duet3 DuetControlServer[345]: [info] HTTP: Optional macro file deployprobe.g not found
                              Feb 17 10:51:13 Duet3 DuetControlServer[345]: [info] HTTP: Optional macro file retractprobe.g not found
                              Feb 17 10:51:13 Duet3 DuetControlServer[345]: [info] HTTP: Optional macro file deployprobe.g not found
                              Feb 17 10:51:26 Duet3 DuetControlServer[345]: [info] HTTP: Optional macro file retractprobe.g not found
                              Feb 17 10:51:30 Duet3 DuetControlServer[345]: [info] HTTP: Optional macro file deployprobe.g not found
                              Feb 17 10:51:38 Duet3 DuetControlServer[345]: [info] HTTP: Optional macro file retractprobe.g not found
                              Feb 17 10:51:38 Duet3 DuetControlServer[345]: [info] HTTP: Finished macro file bed.g
                              Feb 17 10:51:39 Duet3 DuetControlServer[345]: [info] HTTP: Finished macro file Leadscrew_Levelling.g
                              and with sudo lournalctl -fu duetwebserver I get:
                              Feb 17 10:54:24 Duet3 DuetWebServer[463]: [DoCode] Executing code 'M98 P"0:/macros/Bed Levelling/Leadscrew_Levelling.g"'
                              Feb 17 10:55:33 Duet3 DuetWebServer[463]: info: Microsoft.AspNetCore.Mvc.Infrastructure.ContentResultExecutor[1]
                              Feb 17 10:55:33 Duet3 DuetWebServer[463]: Executing ContentResult with HTTP Response ContentType of text/plain; charset=utf-8
                              Feb 17 10:55:33 Duet3 DuetWebServer[463]: info: Microsoft.AspNetCore.Mvc.Infrastructure.ControllerActionInvoker[2]
                              Feb 17 10:55:33 Duet3 DuetWebServer[463]: Executed action DuetWebServer.Controllers.MachineController.DoCode (DuetWebServer) in 69796.3473ms
                              Feb 17 10:55:33 Duet3 DuetWebServer[463]: info: Microsoft.AspNetCore.Routing.EndpointMiddleware[1]
                              Feb 17 10:55:33 Duet3 DuetWebServer[463]: Executed endpoint 'DuetWebServer.Controllers.MachineController.DoCode (DuetWebServer)'
                              Feb 17 10:55:33 Duet3 DuetWebServer[463]: info: Microsoft.AspNetCore.Hosting.Diagnostics[2]
                              Feb 17 10:55:33 Duet3 DuetWebServer[463]: Request finished in 69805.2756ms 200 text/plain; charset=utf-8
                              With both examples I notice the Pi does not return to "pi@Duet3:~ $ " is this something to do with the problem?
                              • oliofundefined
                                oliof
                                @chas2706 said in No output from G32 on DSF 1.2.4 / DWC 2.07:
                                That is due to the -f switch which means follow and waits for new stuff to be written to the journal. Not returning to the command prompt without hitting Ctrl-C is normal in this case.
                                • chas2706undefined
                                  chas2706
                                  @oliof said in No output from G32 on DSF 1.2.4 / DWC 2.07:
                                  Ok thanks I see.
                                  I don't know what the problem is then. I just get no output from the console at all.
                                  • chas2706undefined
                                    chas2706
                                    @dc42 Do you have any suggestions.
                                    Also I noticed that when I enter any command in the console it does not work first time I have to enter twice! I am running RRF3.0.2_RC1 DWC2.0.7 DSF1.2.4.0 on Duet 3 board with SBC.
                                    • Danalundefined
                                      Danal
                                      Yeah, I don't see anything in those logs that looks wrong.
                                      I am well and truly stumped. The "must send twice" is equally weird.
                                      • chas2706undefined
                                        chas2706
                                        Yes it is both weird and annoying.
                                        The bed levelling must be working because my prints are still good but its not right that you get no feedback.
                                        Do you think that the two issues may be linked?
                                        i.e. there's no bed deviation result because it was only reported once?
                                          dc42 administrators @chas2706
                                          One for @chrishamm I think, because in standalone mode I don't see any of these issues, and neither have I seen any reports of them. So I suspect it is a DSF issue, or a DSF/RRF interaction.
                                          • chas2706undefined
                                            chas2706
                                            @dc42 said in No output from G32 on DSF 1.2.4 / DWC 2.07:
                                            dc42 How do I roll back to Duet Software Framework 1.2.3.0 so I can go back to RRF3.0.1_beta2 and DWC2.06 because it was definitely working on that firmware setup.
