    No output from G32 on DSF 1.2.4 / DWC 2.07
    Duet Web Control
    14
    64
    3.3k
    • mvieleersundefined
      mvieleers @Danal
      @Danal
      ; bed.g
      ; generated by RepRapFirmware Configuration Tool v2.1.8 on Thu Jan 23 2020 14:06:49 GMT+0100 (Midden-Europese standaardtijd)
      M561 ; clear any existing bed transform
      G1 Z5 H2 ; move nozzle up
      ;4-point bed levelling
      G30 P0 X15 Y45 Z-99999
      G30 P1 X15 Y275 Z-99999
      G30 P2 X275 Y275 Z-99999
      G30 P3 X275 Y45 Z-99999 S3
      G1 X0 Y0 F5000 ; move the head to the corner (optional)
      • Danalundefined
        Danal
        Hmmm... I'm really stumped. I don't see any differences that would make a difference, and I'm getting it consistently.
        • Danalundefined
          Danal
          SSH into your Pi, and try the following (while you run a G32):
          • sudo journalctl -fu duetcontrolserver
          If that doesn't show anything relevant, then:
          • sudo journalctl -fu duetwebserver
          There will (should) be a lot more output on the webserver, and again, it is up to our eyeballs to see if anything is relevant.
          mvieleersundefined 1 Reply Last reply Reply Quote 0
          • chas2706undefined
            chas2706
            Hi, I mentioned in another post that since upgrading to RRF3.01_RC1 I too do not get any output from G32. I have Duet3 with raspberry pi.
            • chas2706undefined
              chas2706
              @Danal said in No output from G32 on DSF 1.2.4 / DWC 2.07:
              This is my output from the above command:
              Feb 17 10:50:26 Duet3 DuetControlServer[345]: [info] Executing nested macro file Leadscrew_Levelling.g on channel HTTP
              Feb 17 10:50:26 Duet3 DuetControlServer[345]: [info] Executing nested macro file bed.g on channel HTTP
              Feb 17 10:50:26 Duet3 DuetControlServer[345]: [info] Executing nested macro file homeall.g on channel HTTP
              Feb 17 10:50:35 Duet3 DuetControlServer[345]: [info] HTTP: Optional macro file deployprobe.g not found
              Feb 17 10:50:52 Duet3 DuetControlServer[345]: [info] HTTP: Optional macro file retractprobe.g not found
              Feb 17 10:50:52 Duet3 DuetControlServer[345]: [info] HTTP: Optional macro file deployprobe.g not found
              Feb 17 10:51:02 Duet3 DuetControlServer[345]: [info] HTTP: Optional macro file retractprobe.g not found
              Feb 17 10:51:02 Duet3 DuetControlServer[345]: [info] HTTP: Finished macro file homeall.g
              Feb 17 10:51:02 Duet3 DuetControlServer[345]: [info] HTTP: Optional macro file deployprobe.g not found
              Feb 17 10:51:13 Duet3 DuetControlServer[345]: [info] HTTP: Optional macro file retractprobe.g not found
              Feb 17 10:51:13 Duet3 DuetControlServer[345]: [info] HTTP: Optional macro file deployprobe.g not found
              Feb 17 10:51:26 Duet3 DuetControlServer[345]: [info] HTTP: Optional macro file retractprobe.g not found
              Feb 17 10:51:30 Duet3 DuetControlServer[345]: [info] HTTP: Optional macro file deployprobe.g not found
              Feb 17 10:51:38 Duet3 DuetControlServer[345]: [info] HTTP: Optional macro file retractprobe.g not found
              Feb 17 10:51:38 Duet3 DuetControlServer[345]: [info] HTTP: Finished macro file bed.g
              Feb 17 10:51:39 Duet3 DuetControlServer[345]: [info] HTTP: Finished macro file Leadscrew_Levelling.g
              and with sudo lournalctl -fu duetwebserver I get:
              Feb 17 10:54:24 Duet3 DuetWebServer[463]: [DoCode] Executing code 'M98 P"0:/macros/Bed Levelling/Leadscrew_Levelling.g"'
              Feb 17 10:55:33 Duet3 DuetWebServer[463]: info: Microsoft.AspNetCore.Mvc.Infrastructure.ContentResultExecutor[1]
              Feb 17 10:55:33 Duet3 DuetWebServer[463]: Executing ContentResult with HTTP Response ContentType of text/plain; charset=utf-8
              Feb 17 10:55:33 Duet3 DuetWebServer[463]: info: Microsoft.AspNetCore.Mvc.Infrastructure.ControllerActionInvoker[2]
              Feb 17 10:55:33 Duet3 DuetWebServer[463]: Executed action DuetWebServer.Controllers.MachineController.DoCode (DuetWebServer) in 69796.3473ms
              Feb 17 10:55:33 Duet3 DuetWebServer[463]: info: Microsoft.AspNetCore.Routing.EndpointMiddleware[1]
              Feb 17 10:55:33 Duet3 DuetWebServer[463]: Executed endpoint 'DuetWebServer.Controllers.MachineController.DoCode (DuetWebServer)'
              Feb 17 10:55:33 Duet3 DuetWebServer[463]: info: Microsoft.AspNetCore.Hosting.Diagnostics[2]
              Feb 17 10:55:33 Duet3 DuetWebServer[463]: Request finished in 69805.2756ms 200 text/plain; charset=utf-8
              With both examples I notice the Pi does not return to "pi@Duet3:~ $ " is this something to do with the problem?
              • oliofundefined
                oliof
                @chas2706 said in No output from G32 on DSF 1.2.4 / DWC 2.07:
                That is due to the -f switch which means follow and waits for new stuff to be written to the journal. Not returning to the command prompt without hitting Ctrl-C is normal in this case.
                • chas2706undefined
                  chas2706
                  @oliof said in No output from G32 on DSF 1.2.4 / DWC 2.07:
                  Ok thanks I see.
                  I don't know what the problem is then. I just get no output from the console at all.
                  • chas2706undefined
                    chas2706
                    @dc42 Do you have any suggestions.
                    Also I noticed that when I enter any command in the console it does not work first time I have to enter twice! I am running RRF3.0.2_RC1 DWC2.0.7 DSF1.2.4.0 on Duet 3 board with SBC.
                    • Danalundefined
                      Danal
                      Yeah, I don't see anything in those logs that looks wrong.
                      I am well and truly stumped. The "must send twice" is equally weird.
                      • chas2706undefined
                        chas2706
                        Yes it is both weird and annoying.
                        The bed levelling must be working because my prints are still good but its not right that you get no feedback.
                        Do you think that the two issues may be linked?
                        i.e. there's no bed deviation result because it was only reported once?
                          dc42 administrators @chas2706
                          One for @chrishamm I think, because in standalone mode I don't see any of these issues, and neither have I seen any reports of them. So I suspect it is a DSF issue, or a DSF/RRF interaction.
                          • chas2706undefined
                            chas2706
                            @dc42 said in No output from G32 on DSF 1.2.4 / DWC 2.07:
                            dc42 How do I roll back to Duet Software Framework 1.2.3.0 so I can go back to RRF3.0.1_beta2 and DWC2.06 because it was definitely working on that firmware setup.
                            • richardmckennaundefined
                              richardmckenna
                              I’m not seeing any output from G32 either.
                              Duet3+Pi 3B+
                              Duet Web Control: 2.0.7
                              Board: Duet 3 MB6HC (MB6HC)
                              DSF Version: 1.2.4.0
                              Firmware: RepRapFirmware for Duet 3 MB6HC v0.6 or 1.0 3.0 (2020-01-03b3)
                              • Danalundefined
                                Danal @chas2706
                                sudo apt-get install duetsoftwareframework=1.2.3.0
                                • chas2706undefined
                                  chas2706
                                  Thanks for that.
                                    mvieleers @Danal
                                    @Danal Just to be sure: this is my bed.g logs for completeness. Don't believe there's much to go on in there. (by the way, I had upgraded to 3.01-RC2 before.)
                                    duetcontrolserver:
                                    Feb 18 20:30:45 duet3 DuetControlServer[352]: [info] Executing nested macro file bed.g on channel HTTP
                                    Feb 18 20:30:46 duet3 DuetControlServer[352]: [info] Executing nested macro file deployprobe.g on channel HTTP
                                    Feb 18 20:30:53 duet3 DuetControlServer[352]: [info] HTTP: Finished intermediate macro file deployprobe.g
                                    Feb 18 20:30:53 duet3 DuetControlServer[352]: [info] Executing nested macro file retractprobe.g on channel HTTP
                                    Feb 18 20:30:54 duet3 DuetControlServer[352]: [info] HTTP: Finished intermediate macro file retractprobe.g
                                    Feb 18 20:30:54 duet3 DuetControlServer[352]: [info] Executing nested macro file deployprobe.g on channel HTTP
                                    Feb 18 20:31:01 duet3 DuetControlServer[352]: [info] HTTP: Finished intermediate macro file deployprobe.g
                                    Feb 18 20:31:01 duet3 DuetControlServer[352]: [info] Executing nested macro file retractprobe.g on channel HTTP
                                    Feb 18 20:31:02 duet3 DuetControlServer[352]: [info] HTTP: Finished intermediate macro file retractprobe.g
                                    Feb 18 20:31:02 duet3 DuetControlServer[352]: [info] Executing nested macro file retractprobe.g on channel HTTP
                                    Feb 18 20:31:02 duet3 DuetControlServer[352]: [info] HTTP: Finished macro file retractprobe.g
                                    Feb 18 20:31:04 duet3 DuetControlServer[352]: [info] Executing nested macro file deployprobe.g on channel HTTP
                                    Feb 18 20:31:11 duet3 DuetControlServer[352]: [info] HTTP: Finished intermediate macro file deployprobe.g
                                    Feb 18 20:31:11 duet3 DuetControlServer[352]: [info] Executing nested macro file retractprobe.g on channel HTTP
                                    Feb 18 20:31:12 duet3 DuetControlServer[352]: [info] HTTP: Finished intermediate macro file retractprobe.g
                                    Feb 18 20:31:12 duet3 DuetControlServer[352]: [info] Executing nested macro file deployprobe.g on channel HTTP
                                    Feb 18 20:31:19 duet3 DuetControlServer[352]: [info] HTTP: Finished intermediate macro file deployprobe.g
                                    Feb 18 20:31:19 duet3 DuetControlServer[352]: [info] Executing nested macro file retractprobe.g on channel HTTP
                                    Feb 18 20:31:20 duet3 DuetControlServer[352]: [info] HTTP: Finished intermediate macro file retractprobe.g
                                    Feb 18 20:31:20 duet3 DuetControlServer[352]: [info] Executing nested macro file retractprobe.g on channel HTTP
                                    Feb 18 20:31:20 duet3 DuetControlServer[352]: [info] HTTP: Finished macro file retractprobe.g
                                    Feb 18 20:31:23 duet3 DuetControlServer[352]: [info] Executing nested macro file deployprobe.g on channel HTTP
                                    Feb 18 20:31:30 duet3 DuetControlServer[352]: [info] HTTP: Finished intermediate macro file deployprobe.g
                                    Feb 18 20:31:30 duet3 DuetControlServer[352]: [info] Executing nested macro file retractprobe.g on channel HTTP
                                    Feb 18 20:31:31 duet3 DuetControlServer[352]: [info] HTTP: Finished intermediate macro file retractprobe.g
                                    Feb 18 20:31:31 duet3 DuetControlServer[352]: [info] Executing nested macro file deployprobe.g on channel HTTP
                                    Feb 18 20:31:38 duet3 DuetControlServer[352]: [info] HTTP: Finished intermediate macro file deployprobe.g
                                    Feb 18 20:31:38 duet3 DuetControlServer[352]: [info] Executing nested macro file retractprobe.g on channel HTTP
                                    Feb 18 20:31:39 duet3 DuetControlServer[352]: [info] HTTP: Finished intermediate macro file retractprobe.g
                                    Feb 18 20:31:39 duet3 DuetControlServer[352]: [info] Executing nested macro file retractprobe.g on channel HTTP
                                    Feb 18 20:31:39 duet3 DuetControlServer[352]: [info] HTTP: Finished macro file retractprobe.g
                                    Feb 18 20:31:42 duet3 DuetControlServer[352]: [info] Executing nested macro file deployprobe.g on channel HTTP
                                    Feb 18 20:31:49 duet3 DuetControlServer[352]: [info] HTTP: Finished intermediate macro file deployprobe.g
                                    Feb 18 20:31:49 duet3 DuetControlServer[352]: [info] Executing nested macro file retractprobe.g on channel HTTP
                                    Feb 18 20:31:50 duet3 DuetControlServer[352]: [info] HTTP: Finished intermediate macro file retractprobe.g
                                    Feb 18 20:31:50 duet3 DuetControlServer[352]: [info] Executing nested macro file deployprobe.g on channel HTTP
                                    Feb 18 20:31:57 duet3 DuetControlServer[352]: [info] HTTP: Finished intermediate macro file deployprobe.g
                                    Feb 18 20:31:57 duet3 DuetControlServer[352]: [info] Executing nested macro file retractprobe.g on channel HTTP
                                    Feb 18 20:31:58 duet3 DuetControlServer[352]: [info] HTTP: Finished intermediate macro file retractprobe.g
                                    Feb 18 20:31:58 duet3 DuetControlServer[352]: [info] Executing nested macro file retractprobe.g on channel HTTP
                                    Feb 18 20:31:58 duet3 DuetControlServer[352]: [info] HTTP: Finished macro file retractprobe.g
                                    Feb 18 20:31:58 duet3 DuetControlServer[352]: [info] HTTP: Finished macro file bed.g
                                    duetwebserver:
                                    Feb 18 20:30:44 duet3 DuetWebServer[463]: info: DuetWebServer.Controllers.MachineController[0]
                                    Feb 18 20:30:44 duet3 DuetWebServer[463]: [DoCode] Executing code 'G32'
                                    Feb 18 20:31:58 duet3 DuetWebServer[463]: info: Microsoft.AspNetCore.Mvc.Infrastructure.ContentResultExecutor[1]
                                    Feb 18 20:31:58 duet3 DuetWebServer[463]: Executing ContentResult with HTTP Response ContentType of text/plain; charset=utf-8
                                    Feb 18 20:31:58 duet3 DuetWebServer[463]: info: Microsoft.AspNetCore.Mvc.Infrastructure.ControllerActionInvoker[2]
                                    Feb 18 20:31:58 duet3 DuetWebServer[463]: Executed action DuetWebServer.Controllers.MachineController.DoCode (DuetWebServer) in 73655.5472ms
                                    Feb 18 20:31:58 duet3 DuetWebServer[463]: info: Microsoft.AspNetCore.Routing.EndpointMiddleware[1]
                                    Feb 18 20:31:58 duet3 DuetWebServer[463]: Executed endpoint 'DuetWebServer.Controllers.MachineController.DoCode (DuetWebServer)'
                                    Feb 18 20:31:58 duet3 DuetWebServer[463]: info: Microsoft.AspNetCore.Hosting.Diagnostics[2]
                                    Feb 18 20:31:58 duet3 DuetWebServer[463]: Request finished in 73656.4125ms 200 text/plain; charset=utf-8
                                    Feb 18 20:33:05 duet3 DuetWebServer[463]: info: Microsoft.AspNetCore.Hosting.Diagnostics[1]
                                    Feb 18 20:33:05 duet3 DuetWebServer[463]: Request starting HTTP/1.1 POST http://duet3.local/machine/code text/plain;charset=UTF-8 3
                                    Feb 18 20:33:05 duet3 DuetWebServer[463]: info: Microsoft.AspNetCore.Cors.Infrastructure.CorsService[4]
                                    Feb 18 20:33:05 duet3 DuetWebServer[463]: CORS policy execution successful.
                                    Feb 18 20:33:05 duet3 DuetWebServer[463]: info: Microsoft.AspNetCore.Routing.EndpointMiddleware[0]
                                    Feb 18 20:33:05 duet3 DuetWebServer[463]: Executing endpoint 'DuetWebServer.Controllers.MachineController.DoCode (DuetWebServer)'
                                    Feb 18 20:33:05 duet3 DuetWebServer[463]: info: Microsoft.AspNetCore.Mvc.Infrastructure.ControllerActionInvoker[3]
                                    Feb 18 20:33:05 duet3 DuetWebServer[463]: Route matched with {action = "DoCode", controller = "Machine"}. Executing controller action with signature System.Threading.Tasks.Task`1[Microsoft.AspNetCore.Mvc.IActionResult] DoCode() on controller DuetWebServer.Controllers.MachineController (DuetWebServer).
                                    Feb 18 20:33:05 duet3 DuetWebServer[463]: info: DuetWebServer.Controllers.MachineController[0]
                                    Feb 18 20:33:05 duet3 DuetWebServer[463]: [DoCode] Executing code 'G32'
                                    Feb 18 20:34:19 duet3 DuetWebServer[463]: info: Microsoft.AspNetCore.Mvc.Infrastructure.ContentResultExecutor[1]
                                    Feb 18 20:34:19 duet3 DuetWebServer[463]: Executing ContentResult with HTTP Response ContentType of text/plain; charset=utf-8
                                    Feb 18 20:34:19 duet3 DuetWebServer[463]: info: Microsoft.AspNetCore.Mvc.Infrastructure.ControllerActionInvoker[2]
                                    Feb 18 20:34:19 duet3 DuetWebServer[463]: Executed action DuetWebServer.Controllers.MachineController.DoCode (DuetWebServer) in 73870.6134ms
                                    Feb 18 20:34:19 duet3 DuetWebServer[463]: info: Microsoft.AspNetCore.Routing.EndpointMiddleware[1]
                                    Feb 18 20:34:19 duet3 DuetWebServer[463]: Executed endpoint 'DuetWebServer.Controllers.MachineController.DoCode (DuetWebServer)'
                                    Feb 18 20:34:19 duet3 DuetWebServer[463]: info: Microsoft.AspNetCore.Hosting.Diagnostics[2]
                                    Feb 18 20:34:19 duet3 DuetWebServer[463]: Request finished in 73872.5775ms 200 text/plain; charset=utf-8
                                      mvieleers @chas2706
                                      @chas2706 Please note, to make this work, you cannot be on a release of Reprapfirmware that requires DSF 1.2.4.
                                      • gtj0undefined
                                        gtj0
                                        There are issues with the latest DSF and getting responses sent to the correct (or any) location. For instance, if I run G32 in one instance of the UI the response used to show up on all instances connected but now it seems to show up only on the one that issued the command (but not always even there).
                                        I started looking in the source for the issue to see if I can fix it myself but haven't really had time to dig into it as deep seems to be needed.
                                        • Danalundefined
                                          Danal @Danal
                                          After an apt-get sequence, I still get it just fine.
                                          Duet Web Control 2.0.7
                                          Chrome browser, if that makes any difference.
                                          2/15/2020, 7:14:53 PM G32
                                          Leadscrew adjustments made: 0.118 0.120 0.109, points used 3, deviation before 0.115 after 0.000
                                          Ok, this is weird. Right in the middle of working on some other things, I stopped getting responses to G32.
                                          I had them earlier. I ran three G32 and watched the actual result get better and better. Later in the evening, suddenly, no output. Between those two, several e-stops (I'm working on probes that jam). Pi was up all the time.
                                          Certainly no release changes, etc.
                                          So far, I haven't been able to get it back.
                                          • Reboot of Pi, still no output.
                                          • E-Stop of firmware, still no output.
                                          • Power Cycle, still no output.
                                          That last one baffles me to no end. Power cycle?
                                            mvieleers @Danal
                                            @Danal Well that's strange behaviour. I'm losing the console output immediately, as soon as DSF 1.2.4.0 is installed.
                                            I really am confident it is the DSF, as I am now running on standalone mode with same firmware and same DWC version without issues.
                                            Hopefully @chrishamm will get around to looking into this.
