    Extruder motor 3 and 4 no power to extrude
    662
    • Beatundefined
      Beat
      @SIam said in Extruder motor 3 and 4 no power to extrude:
      it can be a config problem or a technical problem please post your config.g file and the result of M115
      FIRMWARE_NAME: RepRapFirmware for Duet 2 Maestro FIRMWARE_VERSION: 2.01beta1(RTOS) ELECTRONICS: Duet Maestro 1.0 FIRMWARE_DATE: 2018-06-23b1
      • Beatundefined
        Beat @SIam
        @SIam
        ; Configuration file for Duet Maestro (firmware version 2.03)
        ; generated by RepRapFirmware Configuration Tool v2.1.8 on Wed Feb 12 2020 19:42:29 GMT+0100 (CET) MOD Vers. 1.0 sHaDoW_DeEr
        M550 P"Ender-3 M3D" ; set printer name
        M551 P"" ; set password
        M586 P0 S1 ; enable HTTP
        M586 P1 S1 ; enable FTP
        M586 P2 S0 ; disable Telnet
        M569 P0 S0 ; physical drive 0 goes backwards
        M569 P4 S0 ; physical drive 4 goes backwards
        M569 P5 S0 ; physical drive 5 goes backwards
        M569 P6 S0 ; physical drive 6 goes backwards
        M584 X0 Y1 Z2 E3:4:5:6 ; set drive mapping
        M350 X16 Y16 Z16 E16:16:16:16 I1 ; configure microstepping with interpolation
        M92 X80.00 Y80.00 Z400.00 E471.00:471.00:471.00:471.00 ; set steps per mm
        M566 X600.00 Y600.00 Z60.00 E300.00:300.00:300.00:300.00 ; set maximum instantaneous speed changes (mm/min)
        M203 X9000.00 Y9000.00 Z600.00 E6000.00:6000.00:6000.00:6000.00 ; set maximum speeds (mm/min)
        M201 X500.00 Y500.00 Z120.00 E500.00:500.00:500.00:500.00 ; set accelerations (mm/s^2)
        M906 X800 Y800 Z800 E900:900:900:900 I30 ; set motor currents (mA) and motor idle factor in per cent
        M84 S30 ; Set idle timeout
        M208 X230 Y230 Z260 S0 ; set axis maxima
        M574 X1 Y1 Z1 S1 ; set active high endstops
        M558 P0 H10 F120 T6000 ; disable Z probe but set dive height, probe speed and travel speed
        M557 X10:220 Y10:220 S20 ; define mesh grid
        M305 P0 T98801 B4185 R2200 ; set thermistor + ADC parameters for heater 0
        M143 H0 S90 ; set temperature limit for heater 0 to 90C
        M305 P1 T98801 B4135 R2200 ; set thermistor + ADC parameters for heater 1
        M143 H1 S250 ; set temperature limit for heater 1 to 250C
        M106 P0 S0 I0 F20 H-1 ; set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned off
        M106 P1 S0 I0 F20 H1 T30 ; set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned on
        M106 P2 S0 I0 F20 H1:0 T30 ; set fan 2 value, PWM signal inversion and frequency. Thermostatic control is turned on
        M563 P0 S"Blau" D0 H1 F0 ; define tool 0
        M563 P1 S"Rot" D1 H1 F0 ; define tool 1
        M563 P2 S"Gelb" D2 H1 F0 ; define tool 2
        G10 P2 X0 Y0 Z0 ; set tool 2 axis offsets
        G10 P2 R0 S0 ; set initial tool 2 active and standby temperatures to 0C
        M563 P3 S"Schwarz" D3 H1 F0 ; define tool 3
        G10 P3 X0 Y0 Z0 ; set tool 3 axis offsets
        G10 P3 R0 S0 ; set initial tool 3 active and standby temperatures to 0C
        M911 S21 R23 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000" ; set voltage thresholds and actions to run on power loss
        T0 ; select first tool
        • SIamundefined
          SIam
          if you change the wiring e1 & e2 to e3 & e4 (switch off the board before) does the problem follow the motors ?
          Hypercube-Evolution-Hybrid, Piezo Orion, Orbiter
          Duet WiFi 1.02 or later + DueX5
          RepRapFirmware for Duet 2 WiFi/Ethernet 3.4.0beta4 (2021-09-27 11:30:36)
          Duet WiFi Server: 1.26
          Duet Web Control 3.4.0beta4 (2021-09-27)
          • Beatundefined
            Beat
            If I change the motors, the problem is the same.
            Will replace the expansion boards. I suspect that the problem then resolves. It's not the cables and motors. In my opinion, G code is also correct. I can not judge whether it is a software problem.
            • SIamundefined
              SIam
              that's how I see it too,your config.g is so far ok so it can only be the expansion board
              • Beatundefined
                Beat
                I got another expansion board today 😞 and of course tested it. Unfortunately, I was happy too early. The problem still persists. It wasn't the cables and motors that I tried with another ender today.
                maybe it's because of the software itself
                  droftarts administrators @Beat
                  @Beat said in Extruder motor 3 and 4 no power to extrude:
                  You're on an old version of the firmware. Have you tried the latest? https://github.com/dc42/RepRapFirmware/releases/tag/2.05.1
                  Firmware update instructions: https://duet3d.dozuki.com/Wiki/Installing_and_Updating_Firmware#Section_Usual_procedure
                  I can't see any particular problem with your config.g. However, you also have M501 in your config.g. Please post your config-override.g file.
                  • Beatundefined
                    Beat
                    @droftarts said in Extruder motor 3 and 4 no power to extrude:
                    Ok have Duet Maestro (firmware version 2.03) on it.
                    With M501 I got the following.
                    Warning: Macro file config-override.g not found.
                    Will now install the new version 3.05.1.
                    • Beatundefined
                      Beat
                      The solution can be so simple. Update successful. Test Jupiiiii it works !!
                      Many thanks to @droftarts and of course @slam
                      Now I can do the first test print soon.
                        @Beat I think support for the Maestro Dual Stepper expansion was added in 2.01, as the only mention in the What’s New document is
                        On the Duet 2 Maestro, the 2 optional add-on drivers are now assumed to be TMC2224 with UART interface
                        https://github.com/dc42/RepRapFirmware/blob/dev/WHATS_NEW.md#version-201-duet-2-series-and-122-duet-06085
                        This may not have been in 2.01 beta you were running. If you had 2.03, that should have worked.
                        Beatundefined 1 Reply Last reply Reply Quote 1
                        • Beatundefined
                          Beat @droftarts
                          OK installed 2.03
                            @Beat send M115, post response. 2.05.1 is the latest, has many improvements over 2.03.
                            Beatundefined 1 Reply Last reply Reply Quote 0
                            • Beatundefined
                              Beat @droftarts
                              M115
                              FIRMWARE_NAME: RepRapFirmware for Duet 2 Maestro FIRMWARE_VERSION: 2.03 ELECTRONICS: Duet Maestro 1.0 FIRMWARE_DATE: 2019-06-13b2
                              • Beatundefined
                                Beat
                                @droftarts
                                So far it works. The first test print was completed. It "prints". Well not where I want it yet. 😊 😊 😊
