Extruder motor 3 and 4 no power to extrude
; Configuration file for Duet Maestro (firmware version 2.03)
; generated by RepRapFirmware Configuration Tool v2.1.8 on Wed Feb 12 2020 19:42:29 GMT+0100 (CET) MOD Vers. 1.0 sHaDoW_DeEr; General preferences
M550 P"Ender-3 M3D" ; set printer name; Network
M551 P"" ; set password
M586 P0 S1 ; enable HTTP
M586 P1 S1 ; enable FTP
M569 P0 S0 ; physical drive 0 goes backwards
M569 P4 S0 ; physical drive 4 goes backwards
M569 P5 S0 ; physical drive 5 goes backwards
M569 P6 S0 ; physical drive 6 goes backwards
M584 X0 Y1 Z2 E3:4:5:6 ; set drive mapping
M350 X16 Y16 Z16 E16:16:16:16 I1 ; configure microstepping with interpolation
M92 X80.00 Y80.00 Z400.00 E471.00:471.00:471.00:471.00 ; set steps per mm
M566 X600.00 Y600.00 Z60.00 E300.00:300.00:300.00:300.00 ; set maximum instantaneous speed changes (mm/min)
M203 X9000.00 Y9000.00 Z600.00 E6000.00:6000.00:6000.00:6000.00 ; set maximum speeds (mm/min)
M201 X500.00 Y500.00 Z120.00 E500.00:500.00:500.00:500.00 ; set accelerations (mm/s^2)
M906 X800 Y800 Z800 E900:900:900:900 I30 ; set motor currents (mA) and motor idle factor in per cent
M208 X230 Y230 Z260 S0 ; set axis maxima; Endstops
M574 X1 Y1 Z1 S1 ; set active high endstops; Z-Probe
M558 P0 H10 F120 T6000 ; disable Z probe but set dive height, probe speed and travel speed
M557 X10:220 Y10:220 S20 ; define mesh grid; Heaters
M305 P0 T98801 B4185 R2200 ; set thermistor + ADC parameters for heater 0
M143 H0 S90 ; set temperature limit for heater 0 to 90C
M305 P1 T98801 B4135 R2200 ; set thermistor + ADC parameters for heater 1
M143 H1 S250 ; set temperature limit for heater 1 to 250C; Fans
M106 P0 S0 I0 F20 H-1 ; set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned off
M106 P1 S0 I0 F20 H1 T30 ; set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned on
M106 P2 S0 I0 F20 H1:0 T30 ; set fan 2 value, PWM signal inversion and frequency. Thermostatic control is turned on; Tools
M563 P0 S"Blau" D0 H1 F0 ; define tool 0
M563 P1 S"Rot" D1 H1 F0 ; define tool 1
M563 P2 S"Gelb" D2 H1 F0 ; define tool 2
G10 P2 X0 Y0 Z0 ; set tool 2 axis offsets
G10 P2 R0 S0 ; set initial tool 2 active and standby temperatures to 0C
M563 P3 S"Schwarz" D3 H1 F0 ; define tool 3
G10 P3 X0 Y0 Z0 ; set tool 3 axis offsets
G10 P3 R0 S0 ; set initial tool 3 active and standby temperatures to 0C; Custom settings are not defined
M911 S21 R23 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000" ; set voltage thresholds and actions to run on power loss
T0 ; select first tool -
if you change the wiring e1 & e2 to e3 & e4 (switch off the board before) does the problem follow the motors ?
@SIam said in Extruder motor 3 and 4 no power to extrude:
If I change the motors, the problem is the same.
Will replace the expansion boards. I suspect that the problem then resolves. It's not the cables and motors. In my opinion, G code is also correct. I can not judge whether it is a software problem. -
that's how I see it too,your config.g is so far ok so it can only be the expansion board
I got another expansion board today
and of course tested it. Unfortunately, I was happy too early. The problem still persists. It wasn't the cables and motors that I tried with another ender today.
maybe it's because of the software itself
@Beat said in Extruder motor 3 and 4 no power to extrude:
FIRMWARE_VERSION: 2.01beta1(RTOS)
You're on an old version of the firmware. Have you tried the latest? https://github.com/dc42/RepRapFirmware/releases/tag/2.05.1
Firmware update instructions: https://duet3d.dozuki.com/Wiki/Installing_and_Updating_Firmware#Section_Usual_procedure
I can't see any particular problem with your config.g. However, you also have M501 in your config.g. Please post your config-override.g file.
@droftarts said in Extruder motor 3 and 4 no power to extrude:
I can't see any particular problem with your config.g. However, you also have M501 in your config.g. Please post your config-override.g file.Ok have Duet Maestro (firmware version 2.03) on it.
With M501 I got the following.
Warning: Macro file config-override.g not found.
Will now install the new version 3.05.1. -
The solution can be so simple. Update successful. Test Jupiiiii it works !!
Many thanks to @droftarts and of course @slam
Now I can do the first test print soon.
@Beat I think support for the Maestro Dual Stepper expansion was added in 2.01, as the only mention in the Whatβs New document is
On the Duet 2 Maestro, the 2 optional add-on drivers are now assumed to be TMC2224 with UART interface
This may not have been in 2.01 beta you were running. If you had 2.03, that should have worked.
OK installed 2.03
@Beat send M115, post response. 2.05.1 is the latest, has many improvements over 2.03.
IanM115
FIRMWARE_NAME: RepRapFirmware for Duet 2 Maestro FIRMWARE_VERSION: 2.03 ELECTRONICS: Duet Maestro 1.0 FIRMWARE_DATE: 2019-06-13b2 -
@droftarts
So far it works. The first test print was completed. It "prints". Well not where I want it yet.
