    Tool Calibration Station E3D Toolchanger
    1.6k
    • Danalundefined
      Danal @smoki3
      @smoki3 said in Tool Calibration Station E3D Toolchanger:
      According to documentation it is working.
      It will need a lot of experimentation. I did some when developing those macros... but... several x.x.X have passed, and the use cases are a tiny bit different.
      Keep us posted!
      • smoki3undefined
        smoki3
        So I made some process today.
        I connected my probe.
        It works pretty fine with G38.2. So it should be easy now to calculate the Z Offset.
        I also made some reliable test.
        22.2.2020, 09:08:07	M409 K"move.axes[4]"
        {"key":"move.axes[4]","flags":"","result":{"acceleration":400.0,"babystep":0,"drivers":["4"],"homed":true,"jerk":8.0,"letter":"V","machinePosition":27.392,"max":34.0,"min":0,"speed":1200.0,"userPosition":27.392,"visible":true,"workplaceOffsets":[0,0,0,0,0,0,0,0,0]}}
        22.2.2020, 09:07:53	M409 K"move.axes[4]"
        {"key":"move.axes[4]","flags":"","result":{"acceleration":400.0,"babystep":0,"drivers":["4"],"homed":true,"jerk":8.0,"letter":"V","machinePosition":27.390,"max":34.0,"min":0,"speed":1200.0,"userPosition":27.390,"visible":true,"workplaceOffsets":[0,0,0,0,0,0,0,0,0]}}
        22.2.2020, 09:07:39	M409 K"move.axes[4]"
        Looks like the repeatability is very good just a deviation of 0.002mm.
        But I also noticed some issues:
        I can not probe my titan aero on the tool changer due to the too short axis. I have the same issue on Gregs brush station. So I have to redesign the arm a bit to bring every thing more upwards.
        I wrote a short macro:
        G1 X-29.5 Y124 F30000
        G38.2 P1 V34
        G10 P{state.currentTool} Z{move.axes[4].machinePosition-44.23}
        G91
        G1 V-2 F1000
        G90
        With this the tool offset is applied.
        • smoki3undefined
          smoki3
          So next problem:
          M500 doesn't save the tool offset. It there a way to save it?
            jay_s_uk
            I usually take a copy of the output from M307 and then manually edit the config override with the correct values.
            smoki3undefined 1 Reply Last reply Reply Quote 0
            • smoki3undefined
              smoki3 @jay_s_uk
              @jay_s_uk said in Tool Calibration Station E3D Toolchanger:
              To copy manually isnt what I understand from a automatic probe.
              Anyway M307 reports just the Heating parameter and not the tool offset. These a reported with G10 Px. But I need to save it
                jay_s_uk @smoki3
                @smoki3 sorry, of course it is.
                I don't think tool offsets are currently supported by M500.
                You'd have to request it to be added by dc42 or look at writing some conditional gcode when variables are implemented in 3.02
                  The S-2 option of the G30 command at https://duet3d.dozuki.com/Wiki/Gcode?revisionid=HEAD#Section_G30_Single_Z_Probe may be what you need. If you use G30 S-2 to set the tool Z offset, then a subsequent M500 will save the offset in config-override.g. You can also save it explicitly using M500 P10.
                  • smoki3undefined
                    smoki3 @dc42
                    @dc42 I get the tooloffset applied with meta commands easily. I just want to save it to config override.
                    Will try it tomorrow with M500 P10
                    • Danalundefined
                      Danal
                      What is the 44.23 constant?
                      Or, same question phrased another way: Is it possible to have the station calibrate itself?
                      • smoki3undefined
                        smoki3 @Danal
                        @Danal said in Tool Calibration Station E3D Toolchanger:
                        The offset between the Z Probe and the Tool Probe.
                        I think think this is not possible duet to both micro switches and to the fact that the my V Axis is too short
