    Tool Calibration Station E3D Toolchanger
    1.6k
    • timcurtis67undefined
      timcurtis67 @smoki3
      @smoki3 This is awesome! I'll be following this concept.
      • Danalundefined
        Danal
        @smoki3 said in Tool Calibration Station E3D Toolchanger:
        So with the G1 Hx commands I just can Home the axis and set it to the axis limits. H2 mean it does ignore the Endstop, H1 set to M208 axis limit and H3 overrides the M208 limit.
        H3 in particular moves until it hits an endstop, and will move even if not "homed". Capture the position when it stops.
        H3 also has the side effect of resetting the axis limit, so be sure and reset it.
        • Danalundefined
          Danal
          So the tool (nozzle) touches the glass to click the switch? Given that we want the tool to be hot (this does change Z), will there be a problem with plastic on the glass?
          • smoki3undefined
            smoki3
            No the glass just keep the camera clean. Above there will be a small metal platform which presses the Microswitch.
            I think to do it with G1 H3 isn't a good idea. I will try to test the tool probe command M585.
            UPDATE:
            I found this command: G38.2 to G38.5: Straight Probe
            This sounds interesting but is described very detailed.
            • Danalundefined
              Danal
              G38 series, at the moment, can only work with a Z axis endstop, or Z axis probe. I'm not a million percent clear where your station goes... but... I suspect that your Z axis will still need a switch separate from the station's probe.
              Multi probe support looks like it is coming soon (the K parameter on the probe definition) but it is certainly not there yet.
              You COULD re-define the endstop/probe while using the station, and define it back to Z when finished with the station. Having done this in the past, anything that causes the "define back to z" to be skipped will lead to a physical Z crash at the next home.
              That's why I chose G1 H3, even with its other side effects. Lesser of two evils.
              • Danalundefined
                Danal
                And... if the metal platform clicks the switch, and the nozzle tip is visible to the camera, I am inferring that the nozzle TIP is not what hits the metal and switch?
                If that statement is true, how does this calibrate for different length nozzles?
                smoki3undefined 1 Reply Last reply Reply Quote 0
                • smoki3undefined
                  smoki3 @Danal
                  @Danal said in Tool Calibration Station E3D Toolchanger:
                  So the calibration of the z axis is independent from the XY axis. You calibrate the Z Axis, the you place the nozzle above the camera und calibrate XY Offset.
                  Ate you sure that the G38 is not working with multiple probes? According to documentation it is working. I have to wait for my new rpi zero then I can wire everything and test the gcode
                  • Danalundefined
                    Danal @smoki3
                    It will need a lot of experimentation. I did some when developing those macros... but... several x.x.X have passed, and the use cases are a tiny bit different.
                    Keep us posted!
                    • smoki3undefined
                      smoki3
                      So I made some process today.
                      I connected my probe.
                      It works pretty fine with G38.2. So it should be easy now to calculate the Z Offset.
                      I also made some reliable test.
                      22.2.2020, 09:08:07	M409 K"move.axes[4]"
                      {"key":"move.axes[4]","flags":"","result":{"acceleration":400.0,"babystep":0,"drivers":["4"],"homed":true,"jerk":8.0,"letter":"V","machinePosition":27.392,"max":34.0,"min":0,"speed":1200.0,"userPosition":27.392,"visible":true,"workplaceOffsets":[0,0,0,0,0,0,0,0,0]}}
                      22.2.2020, 09:07:53	M409 K"move.axes[4]"
                      {"key":"move.axes[4]","flags":"","result":{"acceleration":400.0,"babystep":0,"drivers":["4"],"homed":true,"jerk":8.0,"letter":"V","machinePosition":27.390,"max":34.0,"min":0,"speed":1200.0,"userPosition":27.390,"visible":true,"workplaceOffsets":[0,0,0,0,0,0,0,0,0]}}
                      22.2.2020, 09:07:39	M409 K"move.axes[4]"
                      Looks like the repeatability is very good just a deviation of 0.002mm.
                      But I also noticed some issues:
                      I can not probe my titan aero on the tool changer due to the too short axis. I have the same issue on Gregs brush station. So I have to redesign the arm a bit to bring every thing more upwards.
                      I wrote a short macro:
                      G1 X-29.5 Y124 F30000
                      G38.2 P1 V34
                      G10 P{state.currentTool} Z{move.axes[4].machinePosition-44.23}
                      G91
                      G1 V-2 F1000
                      G90
                      With this the tool offset is applied.
                      • smoki3undefined
                        smoki3
                        So next problem:
                        M500 doesn't save the tool offset. It there a way to save it?
                          jay_s_uk
                          I usually take a copy of the output from M307 and then manually edit the config override with the correct values.
                          • smoki3undefined
                            smoki3 @jay_s_uk
                            @jay_s_uk said in Tool Calibration Station E3D Toolchanger:
                            To copy manually isnt what I understand from a automatic probe.
                            Anyway M307 reports just the Heating parameter and not the tool offset. These a reported with G10 Px. But I need to save it
                              jay_s_uk @smoki3
                              @smoki3 sorry, of course it is.
                              I don't think tool offsets are currently supported by M500.
                              You'd have to request it to be added by dc42 or look at writing some conditional gcode when variables are implemented in 3.02
                                The S-2 option of the G30 command at https://duet3d.dozuki.com/Wiki/Gcode?revisionid=HEAD#Section_G30_Single_Z_Probe may be what you need. If you use G30 S-2 to set the tool Z offset, then a subsequent M500 will save the offset in config-override.g. You can also save it explicitly using M500 P10.
                                • smoki3undefined
                                  smoki3 @dc42
                                  @dc42 I get the tooloffset applied with meta commands easily. I just want to save it to config override.
                                  Will try it tomorrow with M500 P10
                                  • Danalundefined
                                    Danal
                                    What is the 44.23 constant?
                                    Or, same question phrased another way: Is it possible to have the station calibrate itself?
                                    • smoki3undefined
                                      smoki3 @Danal
                                      The offset between the Z Probe and the Tool Probe.
                                      I think think this is not possible duet to both micro switches and to the fact that the my V Axis is too short
