    RRF3.01-RC2 CoreXY Movement differences
    Firmware installation
    558
      deckingman @Dr_Ju_Ju
      @Dr_Ju_Ju It sounds rather like one of you XY motors is moving in the wrong direction or maybe it's not moving at all. Did you change anything else apart from firmware? Did you disturb any of the wiring? Suggest you go back to basics and test motor movement as per this - https://duet3d.dozuki.com/Wiki/ConfiguringRepRapFirmwareCoreXYPrinter
      • infiniteloopundefined
        infiniteloop
        @Dr_Ju_Ju The problem reminds me of this thread, maybe it is worth a read?
        • Dr_Ju_Juundefined
          Dr_Ju_Ju
          Nothing has changed physically from the RRF2 system to this RRF3.01 system, all the wiring is correct & working (yes I have tested, I'm an electronics engineer so know what I'm doing), & apart from these weird moving issues, everything else appears to be working ok, i.e. heaters & fans \ lights etc. are all configured(ish) & working with just some minor tweaks needed e.g. PID tuning, speeding things up etc...
          If I physically move the head to the 'opposite' motion ends, (motors powered off) then home that axis, it behaves as I would expect, i.e. travels in a straight line to its relative homing end-stop. Which for a CoreXY, in its simplest form, the motors (both), are being driven in the correct direction and working as expected !!
          Julian,
          Old goat, learning new things….
            droftarts administrators @Dr_Ju_Ju
            @Dr_Ju_Ju Long shot; what version of RRF2 were you on? There was a change in the default direction of one axis a looooong time ago, can’t remember exactly when.
            • Dr_Ju_Juundefined
              Dr_Ju_Ju
              I was on the latest 2.05.1 \ DWC 2.0.7 on Duet Ethernet 1.02 or later
              Board ID: 08DGM-95BNL-MGPSJ-6J1F2-3SD6L-9JZHX
              I'm interested in the new conditional stuff, so went to the latest RC, to at least try & get things going....
              Julian
              Julian,
                deckingman @droftarts
                @droftarts said in RRF3.01-RC2 CoreXY Movement differences:
                @droftarts For info, that was RRF 1.19 whereby on a CoreXY, the direction of the Y axis (beta) motor changed.
                  dc42 administrators @Dr_Ju_Ju
                  @Dr_Ju_Ju said in RRF3.01-RC2 CoreXY Movement differences:
                  If I make any changes to the M574 settings for X\Y, I'm then unable to home an axis with an
                  "G32 X\Y
                  Error: Failed to enable endstops"
                  Try again, this is working for other people. You need M584 Y2 not M584 Y1 M574 Y2 not M574 Y1.
                  • Dr_Ju_Juundefined
                    Dr_Ju_Ju
                    @dc42 said in RRF3.01-RC2 CoreXY Movement differences:
                    M584 Y2 not M584 Y1
                    Now I'm really confused, Why would I need Y2 in M584, as that setting came from the web configurator, & other examples I've seen ???
                    Julian
                    Julian,
                      Sorry, I meant M574.
                      • Nuramoriundefined
                        Nuramori
                        You commented out the number/maxima and also had the y range backwards vs your old one.
                        ;M208 X0:300 Y300:0 Z0:300 ; Set axis minima:maxima
                        The y should be Y0:300 not Y300:0.
                        • Dr_Ju_Juundefined
                          Dr_Ju_Ju
                          Thank you David, I now have movement as I'd expect'ish, even if the Y axis moves 'negatively', which I suspect will be corrected when I update the axis limits....
                          Julian
                          Julian,
                            Which version of RRF2 were you using before you upgraded to RRF3?
                            • Dr_Ju_Juundefined
                              Dr_Ju_Ju
                              David,
                              & yes Nuramori, I was playing with the axis limits to try & get things working in the right direction...
                              Julian,
