    RRF3.01-RC2 CoreXY Movement differences
    Firmware installation
    558
      droftarts administrators @Dr_Ju_Ju
      @Dr_Ju_Ju Long shot; what version of RRF2 were you on? There was a change in the default direction of one axis a looooong time ago, can’t remember exactly when.
      • Dr_Ju_Juundefined
        Dr_Ju_Ju
        I was on the latest 2.05.1 \ DWC 2.0.7 on Duet Ethernet 1.02 or later
        Board ID: 08DGM-95BNL-MGPSJ-6J1F2-3SD6L-9JZHX
        I'm interested in the new conditional stuff, so went to the latest RC, to at least try & get things going....
        Julian
        Julian,
        Old goat, learning new things….
          deckingman @droftarts
          @droftarts said in RRF3.01-RC2 CoreXY Movement differences:
          @droftarts For info, that was RRF 1.19 whereby on a CoreXY, the direction of the Y axis (beta) motor changed.
            dc42 administrators @Dr_Ju_Ju
            @Dr_Ju_Ju said in RRF3.01-RC2 CoreXY Movement differences:
            If I make any changes to the M574 settings for X\Y, I'm then unable to home an axis with an
            "G32 X\Y
            Error: Failed to enable endstops"
            Try again, this is working for other people. You need M584 Y2 not M584 Y1 M574 Y2 not M574 Y1.
            • Dr_Ju_Juundefined
              Dr_Ju_Ju
              @dc42 said in RRF3.01-RC2 CoreXY Movement differences:
              M584 Y2 not M584 Y1
              Now I'm really confused, Why would I need Y2 in M584, as that setting came from the web configurator, & other examples I've seen ???
              Julian
              Julian,
                Sorry, I meant M574.
                • Nuramoriundefined
                  Nuramori
                  You commented out the number/maxima and also had the y range backwards vs your old one.
                  ;M208 X0:300 Y300:0 Z0:300 ; Set axis minima:maxima
                  The y should be Y0:300 not Y300:0.
                  • Dr_Ju_Juundefined
                    Dr_Ju_Ju
                    Thank you David, I now have movement as I'd expect'ish, even if the Y axis moves 'negatively', which I suspect will be corrected when I update the axis limits....
                    Julian
                    Julian,
                      Which version of RRF2 were you using before you upgraded to RRF3?
                      • Dr_Ju_Juundefined
                        Dr_Ju_Ju
                        David,
                        & yes Nuramori, I was playing with the axis limits to try & get things working in the right direction...
                        Julian,
