    Duet 3 Tool Board - Available?
    1.6k
      @CaLviNx said in Duet 3 Tool Board - Available?:
      I see the tool board is supporting 12v fans, for those of us who exclusively run everything at 24v, will the tool board be able accept 24v fans to save mixing and matching fan voltages ?
      The tool board supports 12V fans only. Note, 24V fans with PWM and tacho support are not generally available.
      • mundsenundefined
        mundsen
        Is it possible to get a 3d model? I want to design a housing for it for my printer - if not, the height of the largest component on the board?
        Am I going to get heat problems if i install it in a small enclosure?
          No 3D model yet, but the dimensions are at https://duet3d.dozuki.com/Wiki/Duet_3_Tool_Board. The highest components are the terminal blocks, which are just under 9mm high. When the JST VH power lead is connected, the top of the latch is about 10mm above the top surface of the PCB.
          The PCB is 1.6mm thick and you should allow 3mm below it to clear the soldered joints.
          • mundsenundefined
            mundsen
            Designing in Fusion360 - made a simple toolboard template. Next I have to make the holes in the top cover.
              A Former User
              Any update on the release of the tool board ?
                Tony will list them on the Duet3D shop soon. We expect to start shipping them this coming week.
                mundsenundefined 1 Reply Last reply Reply Quote 1
                • mundsenundefined
                  mundsen @dc42
                  @dc42 do you have the part name/number for the screw terminal used? So I can ask them to my 3d model
                    dc42 administrators @mundsen
                    @mundsen said in Duet 3 Tool Board - Available?:
                    They are Phoenix part numbers 1725656, 1725669 and 1725672.
                    • mundsenundefined
                      mundsen @dc42
                      @dc42 said in Duet 3 Tool Board - Available?:
                      1725672
                      When I`m at it - possible to get the other terminals used + buttons?
                      • mundsenundefined
                        mundsen
                        My toolboard is on it`s way
                        Is the software ready for it?
                        My config:
                        e3d hemera 24V, but with 12V cooling fan
                        12V filament cooling fan
                        BLTouch probe
                          I believe Tony has a CAD model of the board. I've reminded him to publish it.
                            My config:
                            BLTouch probe
                            Yes, except for the BLTouch. For now you would have to run the wires from it back to the main board. I'll see if I can squeeze support for it into 3.01-RC3.
                              T3P3Tony administrators
                              Ok I have published the step file and the schematic here:
                              https://github.com/Duet3D/Duet3-Toolboard-1LC/tree/master/ToolBoard_1LC_v0.6
                                And the Distribution board here:
                                https://github.com/Duet3D/Duet3-Tool-Distribution-Board/tree/master/Tool Distribution v0.5
