    Duet 3 Tool Board - Available?
    1.6k
    • mundsenundefined
      mundsen
      Any news?
      I`ll have to decide if I should start wireing the extruder/hotend, or wait for the Tool Board
      ![alt text](@CorXY.jpg image url)
        I suggest you wait for the Tool Board. They are currently going through testing and we will announce their availability any day now.
        btw Hemeras are in short supply now, due to the issues in China.
        • mundsenundefined
          mundsen
          ok, I`ll wait (my _Hemera is already installed 🙂 )
          I`ll spend the time while waiting for the tool board to learn more about the rrf 3 firmware settings and get all my other functions correct
          This is my first duet based printer project (RADDS/Repetier on my other projects) so a lot to learn - but I love that it is possible to edit the config files from the web server pages.. 🙂
          If possible? you can add me to a pre order list for the Tool Board 🙂
          • Danalundefined
            Danal
            @mundsen said in Duet 3 Tool Board - Available?:
            And if you have questions about how a given line really works, issue that command from the web console. They take effect in real time.
            • mundsenundefined
              mundsen
              Miss one limit switch input - on many RailCore printers there is a limit switch (Y axis) installed together with the extruder..
                dc42 administrators @mundsen
                You could use the filament monitor input or the Z probe input for that, unless you already need both. Possibly also the second thermistor input.
                  A Former User
                  Hi Guys
                  I am eagerly awaiting for the tool board to be released. In the mean time.
                  I see the tool board is supporting 12v fans, for those of us who exclusively run everything at 24v, will the tool board be able accept 24v fans to save mixing and matching fan voltages ?
                    @CaLviNx said in Duet 3 Tool Board - Available?:
                    The tool board supports 12V fans only. Note, 24V fans with PWM and tacho support are not generally available.
                    • mundsenundefined
                      mundsen
                      Is it possible to get a 3d model? I want to design a housing for it for my printer - if not, the height of the largest component on the board?
                      Am I going to get heat problems if i install it in a small enclosure?
                        No 3D model yet, but the dimensions are at https://duet3d.dozuki.com/Wiki/Duet_3_Tool_Board. The highest components are the terminal blocks, which are just under 9mm high. When the JST VH power lead is connected, the top of the latch is about 10mm above the top surface of the PCB.
                        The PCB is 1.6mm thick and you should allow 3mm below it to clear the soldered joints.
                        • mundsenundefined
                          mundsen
                          Designing in Fusion360 - made a simple toolboard template. Next I have to make the holes in the top cover.
                            A Former User
                            Any update on the release of the tool board ?
                              Tony will list them on the Duet3D shop soon. We expect to start shipping them this coming week.
                              mundsenundefined 1 Reply Last reply Reply Quote 1
                              • mundsenundefined
                                mundsen @dc42
                                @dc42 do you have the part name/number for the screw terminal used? So I can ask them to my 3d model
                                  They are Phoenix part numbers 1725656, 1725669 and 1725672.
                                  • mundsenundefined
                                    mundsen @dc42
                                    @dc42 said in Duet 3 Tool Board - Available?:
                                    1725672
                                    When I`m at it - possible to get the other terminals used + buttons?
                                    • mundsenundefined
                                      mundsen
                                      My toolboard is on it`s way
                                      Is the software ready for it?
                                      My config:
                                      e3d hemera 24V, but with 12V cooling fan
                                      12V filament cooling fan
                                      BLTouch probe
                                        I believe Tony has a CAD model of the board. I've reminded him to publish it.
                                          My config:
                                          BLTouch probe
                                          Yes, except for the BLTouch. For now you would have to run the wires from it back to the main board. I'll see if I can squeeze support for it into 3.01-RC3.
                                            T3P3Tony administrators
                                            Ok I have published the step file and the schematic here:
                                            https://github.com/Duet3D/Duet3-Toolboard-1LC/tree/master/ToolBoard_1LC_v0.6
