    Dual Y Motor Configuration
    3.2k
      droftarts administrators @3DPrintingWorld
      @3DPrintingWorld interesting layout! I’m considering something similar for my current build, but single carriage and tool changer. See https://forum.duet3d.com/post/118078
      3DPrintingWorldundefined 1 Reply Last reply Reply Quote 0
      • botundefined
        bot
        What would make the single motor setup more costly? It seems with the difficulty of synchronizing the motors taken into account, it may be easier to do a single motor if the belt is not too long.
        *not actually a robot
        • 3DPrintingWorldundefined
          3DPrintingWorld @droftarts
          @droftarts That looks really cool, your extruders look sweet! What keeps your x-axis from skewing. I know without the y-axis belts on the current setup I have the x-axis would be all over the place.
            3DPrintingWorld @bot
            @bot An additional stepper motor is only like $15, versus a shaft, couplings, and a couple bearings. I guess if you went with version "D" it might be cheaper, depending on the belt.
            Its taking me a little bit to get the homing right but I think it will be the right choice in the long run.
              @3DPrintingWorld pictures aren’t mine, they’re from the RepRap forums link. The ‘double’ markforge layout is basically a CoreXY, just with the idler that usually takes the belts across the top of the frame moved to the X axis. So it’s in balance, just like a CoreXY, unlike an Hbot or single-sided Y Markforge. It’s effectively yours without the Y axis belts and motors, and with one X carriage the joins the two belts, rather than having them independent.
                @droftarts Let me know how it works out when you get it done!
                  3DPrintingWorld
                  Well, I'm not having much luck figuring out anything on my own.... I'm trying to add a second endstop to the y-axis. With one switch its working fine. When I add "+e1stop" to the M574, if either switch is touched it switches the ystop and both motors stop. What am I doing wrong here? Or do I need to add something to my homey to home two motors on a single axis?
                  M584 X0 U2 Y1:9 Z5:6:7 E3:4
                  M574 X2 S1 P"xstop"
                  M574 Y2 S1 P"ystop+e1stop"
                  M574 U1 S1 P"e0stop"
                    3DPrintingWorld @3DPrintingWorld
                    @dc42 I was wondering if you could help me with this. I have two switches for the y-axis now. When I configure it like this all switch indicate properly in the endstops status screen.
                    M574 X2 S1 P"xstop" ; X min active high endstop switch
                    M574 Y2 S1 P"zstop" ; Y min active high endstop switch
                    M574 U1 S1 P"e0stop" ; U max active high endstop switch
                    But when I add the second endstop tag to the y axis like below the ystop switch no longer changes state only the zstop switch.
                    M574 Y2 S1 P"ystop+zstop" ; Y min active high endstop switch
                    Can you enlighten me to what I am doing wrong. The other odd thing is when I unplug the zstop and remove its tag from the config, it shows as triggered. Shouldn't that be the opposite?
                      @3DPrintingWorld, which firmware version are you running? Send M115 to confirm it.
                      Please post your complete config.g file and homing files.
                        3DPrintingWorld @dc42
                        @dc42 RRF 3.0
                        G90                                             ; send absolute coordinates...
                        M83                                             ; ...but relative extruder moves
                        M669 K0 Y1:-1:0:1				; select Markforged Kinematics Y to react with X and U
                        M208 X35 Y0 U-18.4 Z0 S1                        ; set axis min
                        M208 X419 U365 Y336 Z300 S0                     ; set axis max
                        M552 S1                                         ; enable network
                        M586 P0 S1                                      ; enable HTTP
                        M586 P1 S0                                      ; disable FTP
                        M586 P2 S0                                      ; disable Telnet
                        M569 P1 S0                                      ; X physical drive 0 goes backwards
                        M569 P1 S1                                      ; Y right physical drive 1 goes forwards
                        M569 P2 S0                                      ; U physical drive 2 goes backwards
                        M569 P3 S1                                      ; E1 physical drive 3 goes forwards
                        M569 P4 S1                                      ; E2 physical drive 4 goes forwards
                        M569 P5 S0                                      ; Z left physical drive 5 goes backwards
                        M569 P6 S0                                      ; Z center physical drive 6 goes backwards
                        M569 P7 S1                                      ; Z right physical drive 7 goes forwards
                        M569 P9 S0                                      ; Y left physical drive 8 goes backwards
                        M584 X0 U2 Y1:9 Z5:6:7 E3:4                     ; set drive mapping
                        M350 X16 U16 Y16 Z16 E16:16 I1                  ; configure microstepping with interpolation
                        M92 X100.00 U100.00 Y100.00:80.00 Z1096:1096:1096 E1827.00:1827.00       ; set steps per mm
                        M566 X900.00 U900.00 Y900.00:900.00 Z12.00:12.00:12.00 E40.00:40.00      ; set maximum instantaneous speed changes (mm/min)
                        M203 X6000.00 U6000.00 Y6000.00:6000.00 Z1000.00:1000.00:1000.00 E1800.00:1800.00 ; set maximum speeds (mm/min)
                        M201 X500.00 U500.00 Y500.00:500.00 Z20.00:20.00:20.00 E120.00:120.00      ; set accelerations (mm/s^2)
                        M906 X800 U800 Y800:800 Z200:200:200 E500:500 I30                ; set motor currents (mA) and motor idle factor in per cent
                        M84 S30                                         ; Set idle timeout
                        M574 X2 S1 P"xstop"                             ; X max active high endstop switch
                        M574 U1 S1 P"e0stop"                            ; U min active high endstop switch
                        M574 Y2 S1 P"ystop"                             ; Y max active high endstop switch
                        ;M574 Y2 S1 P"ystop+zstop"                      ; Y Double max active high endstop switch
                        M671 X-20.6:200:420.6 Y14.3:333.3:14.3 S2       ;Locations left, center, right
                        M950 S0 C"duex.e6heat"                          ; create servo pin 0 for BLTouch
                        M558 P9 C"zprobe.in+zprobe.mod" H5 F120 T6000   ; set Z probe type to bltouch and the dive height + speeds
                        G31 P25 X28.8 Y0 Z2.15                          ; set Z probe trigger value, offset and trigger height
                        M308 S0 P"bedtemp" Y"thermistor" T100000 B4534 C9.565227e-8  ; configure sensor 0 as thermistor on pin bedtemp
                        M950 H0 C"bedheat" T0                                     ; create bed heater output on bedheat and map it to sensor 0
                        M143 H0 S120                                              ; set temperature limit for heater 0 to 120C
                        M307 H0 B0 S1.00                                          ; disable bang-bang mode for the bed heater and set PWM limit
                        M140 H0                                                   ; map heated bed to heater 0
                        M308 S1 P"e0temp" Y"thermistor" T500000 B4723 C1.19622e-7 ; configure sensor 1 as thermistor on pin e0temp
                        M950 H1 C"e0heat" T1                                      ; create nozzle heater output on e0heat and map it to sensor 1
                        M143 H1 S280                                              ; set temperature limit for heater 1 to 280C
                        M307 H1 B0 S1.00                                          ; disable bang-bang mode for heater  and set PWM limit
                        M308 S2 P"e1temp" Y"thermistor" T500000 B4723 C1.19622e-7 ; configure sensor 2 as thermistor on pin e1temp
                        M950 H2 C"e1heat" T2                                      ; create nozzle heater output on e1heat and map it to sensor 2
                        M143 H2 S280                                              ; set temperature limit for heater 2 to 280C
                        M307 H2 B0 S1.00                                          ; disable bang-bang mode for heater  and set PWM limit
                        M950 F0 C"fan0" Q500                             ; create fan 0 on pin fan0 and set its frequency
                        M106 P0 S0 H-1                                   ; set fan 0 value. Thermostatic control is turned off
                        M950 F1 C"fan1" Q500                             ; create fan 1 on pin fan1 and set its frequency
                        M106 P1 S1 H1 T45                                ; set fan 1 value. Thermostatic control is turned on
                        M950 F2 C"fan2" Q500                             ; create fan 2 on pin fan2 and set its frequency
                        M106 P2 S0 H-1                                   ; set fan 2 value. Thermostatic control is turned off
                        M950 F3 C"duex.fan8" Q500                        ; create fan 3 on pin duex.fan4 and set its frequency
                        M106 P3 S1 H2 T45                                ; set fan 3 value. Thermostatic control is turned on
                        M563 P0 D0 H1 X3 F0 S"Left"                      ; define tool 0 left
                        G10 P0 X0 Y-1.2 Z0                               ; set tool 0 axis offsets
                        G10 P0 R0 S0                                     ; set initial tool 0 active and standby temperatures to 0C
                        M563 P1 D1 H2 F2 S"Right"                        ; define tool 1 Right
                        G10 P1 X0 Y0 Z0                                  ; set tool 1 axis offsets
                        G10 P1 R0 S0                                     ; set initial tool 1 active and standby temperatures to 0C
                        M563 P2 D0:1 H1:2 X0:3 F0:2 S"Copy"              ; define tool 2 copy
                        G10 P2 X-75 Y0 U75 S0 R0                         ; set tool 2 axis offsets
                        M567 P2 E1:1                                     ; set mix ratio 100% on both extruders
                        M501                                             ; Record
                        ; homeall.g
                        ; X,U,Y Homing
                        G91                         ; relative positioning
                        G1 H2 Z5 F6000              ; lift Z relative to current position
                        G1 H1 X475 U-475 Y500 F1800 ; move quickly to X or Y endstop and stop there (first pass)
                        G1 H1 X475                  ; home X axis
                        G1 H1 U-475                 ; home U axis
                        G1 H1 Y500                  ; home Y axis
                        G1 X-5 U5 Y-5 F6000         ; go back a few mm
                        G1 H1 X25 F360              ; move slowly to X axis(second pass)
                        G1 H1 U-25                  ; move slowly to U axis(second pass)
                        G1 H1 Y25                   ; move slowly to Y axis(second pass)
                        ; Z Homing
                        G90 G1 X171 Y150 F10000      ; Move to the center of the bed
                        M558 F500                    ; Fast probing speed
                        G30                          ; First probe
                        M558 F50                     ; Slow probing speed
                        G30                          ; Second probe
                        G32                          ; Level the bed
                        G30                          ; Bed Deviation probe
                        G90 G1 X417                  ; Park x-axis
