    Help: Temp Sensors and Homing Issues
    6.9k
      Can you send movement commands in the console?
      Do the paneldue move buttons work?
      • 94118undefined
        94118
        No i cannot send commands from console or paneldue
          Please post your current config.g and homing files so I can see what state your machine would be in after homing.
          • 94118undefined
            94118
            config (1).g homex.g homey.g homez.g
              In homeX you should have a negative move to back off the endstops.
              G91               ; relative positioning
              G1 H1 X235 F1800 ; move quickly to X axis endstop and stop there (first pass)
              G1 H2 X5 F6000    ; go back a few mm
              G1 H1 X235 F360  ; move slowly to X axis endstop once more (second pass)
              G90               ; absolute positioning
              Should be
              G1 X-5 F6000    ; go back a few mm
              Your homey has the negative, but you don't need the H2 on the second move.
              G1 H1 Y215 F1800 ; move quickly to Y axis endstop and stop there (first pass)
              G1 H2 Y-5 F6000  ; go back a few mm
              G1 H1 Y215 F360  ; move slowly to Y axis endstop once more (second pass)
              Should be
              G1 Y-5 F6000  ; go back a few mm
              Your homez only has a single homing pass. You may want to add a second slower pass. You're also missing the G90 at the end, which could be your movement problem.
              G1 H1 Z200 F1800 ; move Z up until the endstop is triggered
              G92 Z0            ; set Z position to axis minimum (you may want to adjust this)
              Should be
              G1 Z-5
              G1 H1 Z200 F360 ; second pass
              • 94118undefined
                94118
                Got it to home correctly still cannot use jog controls for fine movement
                  Phaedrux Moderator @94118
                  @94118 said in Help: Temp Sensors and Homing Issues:
                  What exactly do you mean by that? Can you post a photo of what you're trying to use?
                  • 94118undefined
                    94118
                    https://drive.google.com/open?id=1E9Nnj0lRRrosyiqkRENvNrMgNKRmSi7d
                    https://drive.google.com/open?id=1E9ZpqFKI_MspoPvdRPRjLaykGRvhTB9-
                    I would use the jog controls for filament load and unload as well as jams or clogging
                      The extruder motor won't move unless it's at printing temp.
                      Are the x and y and z jog buttons working?
                      • 94118undefined
                        94118
                        they will work only if i press the plus side of the controls then press the negative side
                          Ok that probably means that your endstop positions and/or your motor directions aren't correct.
                          Where is the X endstop? Left or right side?
                          Where is the Y endstop? Front or back?
                          Perhaps take a look at this guide on commissioning a printer: https://duet3d.dozuki.com/Guide/Ender+3+Pro+and+Duet+Maestro+Guide+Part+3:+Commissioning/39
                          • 94118undefined
                            94118
                            X is at the Right, y is at the Left rear corner
                              M574 X1 S1 P"!xstop"
                              That should be
                              M574 X2 S1 P"!xstop"
                              Because your X endstop is at the high end of travel on the right side.
                              Change that and see if it works better after homing.
                              • 94118undefined
                                94118
                                when i changed it from x1 to x2 motor direction went in opposite direction so i changed it back to x1
                                • 94118undefined
                                  94118
                                  Should i change my "Z" endstop from x2 to x1 cause current tool postition read (x230, y210, z0) i think it should be 200 or 195
                                  • 94118undefined
                                    94118
                                    Failed to load filaments
                                    Directory 0:/filaments not found
                                    i was trying to setup a filaments list for PLA, ABS, PetG
                                      Leave it as X2, and change the direction of the X motor as well. You have S1, should be S0.
                                      M569 P0 S0                                     ; physical drive 0 goes forwards
                                      No, When the nozzle is at the bed, it's at 0. When the bed or nozzle move away from each other, the Z axis increases position.
                                      Put the SD card in your PC and create the filaments folder manually.
                                      • 94118undefined
                                        94118
                                        the Sd card from the duet 2 wifi board cause i do not have one for the panel
                                          yes.
                                          • 94118undefined
                                            94118
                                            recommended steps per mm for PetG as that is currently the roll of filament i have on the printer
