    Help: Temp Sensors and Homing Issues
    6.7k
      Ok that probably means that your endstop positions and/or your motor directions aren't correct.
      Where is the X endstop? Left or right side?
      Where is the Y endstop? Front or back?
      Perhaps take a look at this guide on commissioning a printer: https://duet3d.dozuki.com/Guide/Ender+3+Pro+and+Duet+Maestro+Guide+Part+3:+Commissioning/39
      • 94118undefined
        94118
        X is at the Right, y is at the Left rear corner
          M574 X1 S1 P"!xstop"
          That should be
          M574 X2 S1 P"!xstop"
          Because your X endstop is at the high end of travel on the right side.
          Change that and see if it works better after homing.
          • 94118undefined
            94118
            when i changed it from x1 to x2 motor direction went in opposite direction so i changed it back to x1
            • 94118undefined
              94118
              Should i change my "Z" endstop from x2 to x1 cause current tool postition read (x230, y210, z0) i think it should be 200 or 195
              • 94118undefined
                94118
                Failed to load filaments
                Directory 0:/filaments not found
                i was trying to setup a filaments list for PLA, ABS, PetG
                  Phaedrux Moderator @94118
                  @94118 said in Help: Temp Sensors and Homing Issues:
                  Leave it as X2, and change the direction of the X motor as well. You have S1, should be S0.
                  M569 P0 S0                                     ; physical drive 0 goes forwards
                  No, When the nozzle is at the bed, it's at 0. When the bed or nozzle move away from each other, the Z axis increases position.
                  Put the SD card in your PC and create the filaments folder manually.
                  • 94118undefined
                    94118
                    the Sd card from the duet 2 wifi board cause i do not have one for the panel
                      yes.
                      • 94118undefined
                        94118
                        recommended steps per mm for PetG as that is currently the roll of filament i have on the printer
                          Is that a question?
                          • 94118undefined
                            94118
                            Yes that is the question!
                              You'll need to calibrate the extruder.
                              https://duet3d.dozuki.com/Guide/Ender+3+Pro+and+Duet+Maestro+Guide+Part+4:+Calibration/40#s165
                              Do you have a known starting value for the extruder typical for that printer/extruder?
                              • 94118undefined
                                94118
                                Example shows an ender 3 i do not own an ender 3
                                • Danalundefined
                                  Danal
                                  Calibrating the extruder is the same process on every printer.
                                  • 94118undefined
                                    94118
                                    have calibrated my extruder here are my numbers.
                                    1. 311.82
                                    2. 336.82
                                    3. 306.82
                                    4. 339.82
                                    5. 281.82
                                    they all seem inconsistent to me
                                      Well it seems to be bouncing around a central value. Try starting with the average. 314.
                                      You may need to do it several more times if your starting value wasn't very close to being correct.
