Help: Temp Sensors and Homing Issues
Got it to home correctly still cannot use jog controls for fine movement
@94118 said in Help: Temp Sensors and Homing Issues:
What exactly do you mean by that? Can you post a photo of what you're trying to use?
https://drive.google.com/open?id=1E9Nnj0lRRrosyiqkRENvNrMgNKRmSi7d
https://drive.google.com/open?id=1E9ZpqFKI_MspoPvdRPRjLaykGRvhTB9-I would use the jog controls for filament load and unload as well as jams or clogging
The extruder motor won't move unless it's at printing temp.
Are the x and y and z jog buttons working?
they will work only if i press the plus side of the controls then press the negative side
Ok that probably means that your endstop positions and/or your motor directions aren't correct.
Where is the X endstop? Left or right side?
Where is the Y endstop? Front or back?Perhaps take a look at this guide on commissioning a printer: https://duet3d.dozuki.com/Guide/Ender+3+Pro+and+Duet+Maestro+Guide+Part+3:+Commissioning/39
X is at the Right, y is at the Left rear corner
; Endstops M574 X1 S1 P"!xstop"
That should be
; Endstops M574 X2 S1 P"!xstop"
Because your X endstop is at the high end of travel on the right side.
Change that and see if it works better after homing.
when i changed it from x1 to x2 motor direction went in opposite direction so i changed it back to x1
Should i change my "Z" endstop from x2 to x1 cause current tool postition read (x230, y210, z0) i think it should be 200 or 195
Failed to load filaments
Directory 0:/filaments not foundi was trying to setup a filaments list for PLA, ABS, PetG
Leave it as X2, and change the direction of the X motor as well. You have S1, should be S0.
; Drives M569 P0 S0 ; physical drive 0 goes forwards
No, When the nozzle is at the bed, it's at 0. When the bed or nozzle move away from each other, the Z axis increases position.
Put the SD card in your PC and create the filaments folder manually.
the Sd card from the duet 2 wifi board cause i do not have one for the panel
recommended steps per mm for PetG as that is currently the roll of filament i have on the printer
Is that a question?
Yes that is the question!
You'll need to calibrate the extruder.
https://duet3d.dozuki.com/Guide/Ender+3+Pro+and+Duet+Maestro+Guide+Part+4:+Calibration/40#s165
Do you have a known starting value for the extruder typical for that printer/extruder?
Example shows an ender 3 i do not own an ender 3
Calibrating the extruder is the same process on every printer.
