    Help: mesh compensation ist not correcting right
    1.8k
    • stewwyundefined
      stewwy @tom_Nbg
      @tom_Nbg Could be, not familiar with magnetic beds, you should see any twist clearly when you look at the bed map side on, alternatively look at heatmap.csv in a spreadsheet to see the actual numbers, I believe it should be first point and last point in the file for xy0,0 and xy max or x min y max depending on where your probe does it's last probe.
      edit, answer to your 2nd post not the last post
      tom_Nbgundefined 1 Reply Last reply Reply Quote 0
      • tom_Nbgundefined
        tom_Nbg @stewwy
        @stewwy
        Yes: the measured right side in the heightmap.csv is "deeper" then the left side, but I see, that it is higher - so the values are mixed up... How to tell the printer that?
        stewwyundefined droftartsundefined 2 Replies Last reply Reply Quote 0
        • stewwyundefined
          stewwy @tom_Nbg
          @tom_Nbg
          You have a Cartesian printer
          G32 is bed leveling using the 2 Z motors to level along the x axis. This does not as far as I know happen during printing it merely attempts to correct for errors before you start printing.
          G29 is mesh leveling this is a correction that occurs during printing to correct for hollows and bumps in your bed, although it can correct for an incorrectly leveled bed.
          • stewwyundefined
            stewwy @tom_Nbg
            @tom_Nbg You can correct for it if you have bed leveling screws, otherwise use (G29)mesh leveling as it looks like you are pretty close anyway
              droftarts administrators @tom_Nbg
              @tom_Nbg There's no way of defining bed 'type', and it doesn't matter. So long as you have 'positive' Z moves that move the nozzle away from the bed (eg X gantry on Z moves up) or the bed away from the nozzle (CoreXY with bed moving down), and 'negative' Z moves move the nozzle towards the bed (either nozzle down or bed up), it's effectively the same to the machine coordinates and to the firmware.
              • tom_Nbgundefined
                tom_Nbg @stewwy
                @stewwy
                I run G32 before I start a print. So if the meassured distance on the right side is different to the left one - then the motors are getting corrected independent - and if then I have my case 1 or case 2 as drawn, the corrections are made are wrong. Example: the right side is too high, the right screw has to rise up but the fw "thinks" the bed has to lower down, then the gantry get lowered down and the effect is, that the nozzle is even closer than it should.... and this is it what I have.... So the measured values just need to be inverted or something like this...?
                  @tom_Nbg If that's the case, you probably need to swap the motor wiring of the Z motors. Your M584 command will state two Z drives, eg M584 Z2:4, where Z2 is the 'Z' driver pins, and Z4 is the 'E1' driver pins. Your M671 command defines your leadscrew positions, but importantly, in the order you defined Z motors in M584. So M671 X-20:220 Y100:100 S0.5 defines the Z2 motor/leadscrew at X-20 Y100 and Z4 motor/leadscrew at X220 Y100. If you connect these the wrong way around, after probing, it will move the bed the wrong way, making the levelling worse. Check that the Z motors are each connected to the correct driver.
                  See https://duet3d.dozuki.com/Wiki/Bed_levelling_using_multiple_independent_Z_motors
                  If that isn't clear, post your config.g (which you should have done at the beginning) and perhaps a picture of your printer and/or wiring.
                  Edit: overlooked config in first post!
                    Phaedrux Moderator @droftarts
                    @droftarts said in Help: mesh compensation ist not correcting right:
                    It's in the first post... 😉
                      Phaedrux Moderator @tom_Nbg
                      @tom_Nbg said in Help: mesh compensation ist not correcting right:
                      M584 X0 Y4 Z2:4 E3
                      I think I see a problem. You have Y mapped to drive 4 as well as Z. You're missing a mapping for drive 1.
                      • tom_Nbgundefined
                        tom_Nbg @Phaedrux
                        @Phaedrux
                        no - it this was a copy/paste "rest" - and when I post it here I correct it to the inital state.
                        y is on 1 (otherwise I think my z-axis would have crashed ;-). I swapped the z- and y-motor to to check if a driver has a problem. So my actual line is:
                        M584 X0 Y1 Z2:4 E3
                        • tom_Nbgundefined
                          tom_Nbg
                          I checked, if the correction is right and it is... I just put a 0.4mm spacer to the right side and the x-gantry was after G32 correct aligned to the bed... But my problem still exists... 😞 I've no further ideas anymore, what the problem could cause....
                            So G32 correction is working. That's good.
                            Have you run G29 after the correction? Or are you loading an old heightmap?
                            • tom_Nbgundefined
                              tom_Nbg @Phaedrux
                              @Phaedrux
                              Hi re-checked all. I printed me some spacers of 8mm to check the bed level manual on each screw. It was fine. Then I'm gone through a sequence:
                              • Power up
                              • M561
                              • G29 S2
                              • G28
                              • G32
                                Then I checked again the Nozzle offset (screwed down the nozzle till it touches a piece of paper, rise it up for 5mm and run G30 S-1. I've done this for 3 times, mean 2.263, deviation 0.002 - so o.k.).
                                Then I put in the new value to the G31 the config.g.
                                After reboot:
                              • M561
                              • G29 S2
                              • G28
                              • G32
                              • G29 (for a new meshmap with 7x7 grid)
                              Then I looked to the map which just looked good for a test deviation mean 0.011, deviation 0.007
                              After this I started a print and it was again the same suffering result... the left side is printed too high, the middle is ok and on the right side the nozzle is too close to - and it really looks as if where the left/right side mixed up (I checked this - it isn't so) - but I'm short befor to give up.
                              This mesh compensation is a horror to get a good result over all. I've no clue if it an issue / interference problem between the BLTouch and the magnetic heatbed (but then why left/right - the magnets are placed symmetrically).
                              I wonder also about this:
                              After homing I go to the middle and checked the height (with a macro which measures 10 times) and I got -0.002 +/- 0.001. But the meshmap shows me at this point -0.019.
                              Something is here very very wrong with G29.
                              My very very last try will be to measure each point with my macro (see below) and I will recheck these measurements with the meshmap ones (I'll put in exactly the same positions from the meshmap) . If it is then still will not work, I'll make one last test with the Prusa-Pinda-Probe - and if it still will noch work - I'llsell the board...
                              For more then 3 or 4 weeks now I don't can get a good first layer even a print. Also I recognized since the last update to RRF3.01RC3 that the board will loss every some minutes its network connection... I'm totally disappointed - I've expected more - and I'm sure, there are enough people out without problems like mine - but what is then their machine setup? If the baord is not suitable for my kind of printer - it should be mentioned somewhere...
                              M401
                              G30 P0 X10 Y175 Z-9999
                              G30 P1 X10 Y175 Z-9999
                              G30 P2 X10 Y175 Z-9999
                              G30 P3 X10 Y175 Z-9999
                              G30 P4 X10 Y175 Z-9999
                              G30 P5 X10 Y175 Z-9999
                              G30 P6 X10 Y175 Z-9999
                              G30 P7 X10 Y175 Z-9999
                              G30 P8 X10 Y175 Z-9999
                              G30 P9 X10 Y175 Z-9999 S-1
                              M402
                                Your sequence looks ok, your config looks ok, the heightmap even looks good, so I'm at a loss to say why your first layer results aren't good.
                                What does the first layer look like with mesh compensation disabled?
                                What happens if you manually level the X gantry without using G32, is it behaved better after running a new G29?
                                • tom_Nbgundefined
                                  tom_Nbg @Phaedrux
                                  @Phaedrux
                                  The problem is, that I need G32 because of the printers setup. When powering off or on the printer, the screws sometimes move a bit and so I have another tilt on the x-gantry...
                                  I'll try now to run my sequence without G29 and measure the 8 screw points manual with the macro above and put these values then into the heightmap. Then I'll look and maybe adjust the values comparing to print results and hope this will work for longer and only needs to adjust some baby steps....
                                  I had have a fully manually measured perfect mesh and the first layer was awsome - but after powering off and on the next day - and maybe I hit a bit the z-threads - it was totally horrible... because I hadn't had a G32 run...
                                    Right, but what I'm saying is can you manually level it instead of G32, just in case there is something wrong with your G32.
                                    If you do it manually and it works fine, then we have narrowed it down to a problem with your bed.g.
