    Compiled Firmware with 5bar-Scara / Dual-Arm-Scara
    Firmware installation
    8
    67
    3.7k
    • Enpixaundefined
      Enpixa
      Hello Jörg. thx. didnt see that at first sight.
      now i installed the endstops. They seem to work hardware-wise. At least the red LEDs next to the Stepper Plug
      on the mainboard lighten up when i trigger them by hand. ( i used the endstops from my old Anet A8 and connected them to GND & Stop of X and Y Endstop Pins on Mainboard)
      Unfortenetly the steppers doesnt stop when triggering the endstop. (Also tried with M574 X1 Y1 Z0 S0 for active low)
      Also tried moving +x and -x and pressing the trigger by hand doesnt stop the movement. (LEDs on mainboard show me
      a nice red light :)) But the steppers are still moving....... I move the arm with G1 S1 X10 F20 this makes my left-arm (x) moving towards me.
      M119 gives me Endstops - X: no endstop, Y: no endstop, Z: no endstop, Z probe: at min stop
      This is the part of my config.g
      M574 X1 Y1 Z0 S1 ; ( Also tried M574 X2 Y2 Z0 S0 )
      M669 B60:60
      M208 X-300 Y-300 Z0 S1 ; Set axis minima
      M208 X300 Y300 Z300 S0 ; Set axis maxima
      M669 K9 L2 X0:0 Y0:0 P265:260 D265:260:25:0 ; arms are 300 mm long, actuators are 100 mm apart, other parameters take defaults
      Any ideas what i am doing wrong ?
      Best, Johannes
      JoergS5undefined dc42undefined 2 Replies Last reply Reply Quote 0
      • JoergS5undefined
        JoergS5 @Enpixa
        @Enpixa I expect that a definition of the endstop pins is missing, please check the document https://duet3d.dozuki.com/Wiki/RepRapFirmware_3_overview , e.g. "Endstop numbers are no longer used in M591. Pin names replace them." At the end of this document is an overview of the pin names for the different boards.
        If you don't find the reason, please post your complete config file and the type of hardware and firmware (I know it, but the others may not).
        • Enpixaundefined
          Enpixa
          Jörg, you are crazy being up that late 🙂
          I am running on a Duet2Wifi 1.04 - with latest Firmware Release 3.01-RC3
          Actually im running my X-Arm with : G1 S2 X10 F20 to make it moving towards me.
          Endstop Pins are connected like shown here:
          This is my complete config.g
          M552 S1 ; Turn network on
          M111 S0 ; Debug off
          M550 P********* ; Machine name and Netbios name (can be anything you like)-
          M551 P********* ; Machine password (used for FTP)
          M586 P0 S1 ; Enable HTTP
          M586 P1 S1 ; Enable FTP
          M586 P2 S1 ; Enable Telnet
          M569 P0 S1 ; Drive 0 (X) goes forwards
          M569 P1 S1 ; Drive 1 (Y) goes forwards
          M569 P2 S1 ; Drive 2 (Z) goes forwards
          M569 P3 S1 ; Drive 3 (E0) goes forwards
          M574 X2 S1 P"xstop" ; X min active high endstop switch
          M574 Y2 S1 P"ystop" ; Y min active high endstop switch
          ;M574 Z1 S0 P"zstop" ; Z min active high endstop switch
          M669 B60:60
          M350 X128 Y128 Z128 E16 I1 S3 ; Configure microstepping with interpolation
          M203 X10000 Y10000 Z300 E3600 ; maximum speeds mm/minute
          M92 X100 Y100 Z400 E95.2 ; Set steps per mm
          M566 X15 Y15 Z2 E2 ; Set maximum instantaneous speed changes (mm/min)
          M201 X20 Y20 Z20 E1000 ; Set accelerations (mm/s^2)
          M906 X1200 Y1200 Z700 E600 ; Set motor currents (mA) and motor idle factor in per cent
          M84 S0 ; Set idle timeout
          If anyone has an idea... this would be really great !
          Thanks alot, Johannes
          • JoergS5undefined
            JoergS5 @Enpixa
            @Enpixa I am not an endstop expert, but I think it is necessary to define and use a Z endstop even you don't need it. But I'm not sure.
              dc42 administrators @JoergS5
              @JoergS5 said in Compiled Firmware with 5bar-Scara / Dual-Arm-Scara:
              No, it's not necessary with RepRapFirmware.
                dc42 administrators @Enpixa
                @Enpixa said in Compiled Firmware with 5bar-Scara / Dual-Arm-Scara:
                As you are running RepRapFirmware 3, you need to specify the endstop pin names. If the endstop LEDs are normally on but go out when the endstop is triggered (which is the case when using normally closed switches, recommended) then you need:
                M574 X1 S1 P"xstop"
                M574 Y1 S1 P"ystop"
                • Enpixaundefined
                  Enpixa
                  Hello DC42,
                  thats what i already did, see my latest post/config: https://forum.duet3d.com/topic/13631/compiled-firmware-with-5bar-scara-dual-arm-scara/18
                  I tried all thinkable variations ( active low/high / trigger min/max )
                  Right now, i dont know what more i could try to make it work.
                  • JoergS5undefined
                    JoergS5 @Enpixa
                    @Enpixa I don't have more ideas. I would try a last test inverting with the ! sign *), then trying other endstop hardware.
                    P"pin_name" Defines the pin name(s) that the endstop(s) for the specified axis are connected to. Needed when S=1. May need ! before pin name to invert signal. in https://duet3d.dozuki.com/Wiki/Gcode#Section_M574_RepRapFirmware_Num_3
                    • Enpixaundefined
                      Enpixa
                      Is the red LED on the mainboard a good indicator if it is working properly hardware-wise ? Because when
                      i press the endstop manually the LED is on. if not pressed it is off.
                      If you have a recommendation for me which endstops i should buy. i would appreciate it.
                      JoergS5undefined dc42undefined 3 Replies Last reply Reply Quote 0
                      • JoergS5undefined
                        JoergS5 @Enpixa
                        @Enpixa i've read "The second line (S1) defines all
                        active high endstops.
                        If you are unsure if your endstops
                        are active high or active low, you
                        can test them by observing the
                        light next to the corresponding
                        stepper motor connector. If the
                        light is lit when the button is
                        pressed, then this would indicate
                        an active low endstop"
                        in https://dozuki-guide-pdfs.s3.amazonaws.com/pdf/duet3d/guide_10_en.pdf page 11. So the light tells you the type of endstop. If it is the light you mean, then it would be a active low endstop.
                        • JoergS5undefined
                          JoergS5 @Enpixa
                          @Enpixa which type of endstop recommendation: for your current printer setup the endstop would be sufficient imho which you use. An alternative would be an optical endstop.
                          I want to go another direction with an optical encoder like described in https://github.com/JoergS5/OpticalEncoder
                          • Enpixaundefined
                            Enpixa
                            Hello Jörg,
                            thx for that information, for my understanding i got an active low endstop. LED next to stepper plug is lit when endstop is pressed.
                            Video of pressing Endstop: http://nörds.de/video_2020-03-05_14-04-43_1.mp4
                            This is the direction setting used in my Config
                            That Information i found for setting the endstops
                            The electrical type of the endstop (S parameter). This used to be just active high (S1, e.g. a normally-closed switch or opto switch), or active low (S0, e.g. normally-open switch or Hall sensor). There are now also options for using a Z probe (S2) and for using motor stall detection (S3).
                            These are the X, Y and Z parameters. 0 means no endstop present, 1 means an endstop switch at the minimum end, 2 means an endstop switch at the maximum end of the axis.
                            As the Arm is moving towards me and the Endstop when using positive X-Values i set X and Y to 2 for maximum checking. (G1 S2 X20 F100 makes the arm moving in direction to the endstop)
                            M574 X2 S0 P"xstop" ; X max active low endstop switch
                            M574 Y2 S0 P"ystop" ; Y max active low endstop switch
                            I just set an Axis-Limit
                            Best, Johannes
                            • bondusundefined
                              bondus
                              Cool! Another 5-bar.
                              By putting the proximal inner joints on top of each other you actually have a 4-bar, the 5'th has zero length. I hope the math in the code works, it is a special case.
                              One effect of that is that most of the work modes no longer work, you will always be in work mode 2. Assuming your proximal arms have the same length.
                              Your case with all arms the same length and inner joints in the same place is actually a much simpler case than what the current implementation can handle, but it should work fine.
                              I think your homing move is not right, you should use the H1 option to G1.
                              My homing file "home5barscara.g":
                              G91              ; relative positioning
                              G1 H1 Z300 F1500 ; move quickly to endstop and stop there (first pass)
                              G1 H2 Z-5 F900      ; go back a few mm
                              G1 H1  Z300 F90  ; move slowly to endstop once more (second pass)
                              G1 H1 X300 Y300  F2500 ; move quickly to endstop and stop there (first pass)
                              G1 H1 X300 F2500
                              G1 H1 Y300 F2500
                              G1 H2 X-2 Y-2 F900      ; go back a few degrees
                              G1 H1 X300 F90  ; move slowly to endstop once more (second pass)
                              G1 H1 Y300 F90  ; move slowly to endstop once more (second pass)
                              G0 Z-2  ; move down a bit to not make mesh calibration move it out of machine limits
                              G90              ; absolute positioning
                              G0 X0 Y0 F6000 ; move to a reasonable position
                              You would have to remove z-homing and make X (or is it Y?) move towards negative instead. I have my right arm homing switch in between the arm joints.
                              I think your steps/mm, G92, is wrong. It should be steps/deg in this case.
                              Assuming you have 200step/rev steppers. it should be 71.1111111111.
                              200 steps/rev * 128microstepping / 360degrees = 71.1111....
                              With the steppers directly attached to the arms you should be able to move stupendously fast but with pretty poor precision.
                                That's as expected for a normally-open switch; however normally-closed switches are preferred (which reverses the sense). The LED is a reliable indicator when the endstop is a simple microswitch. It isn't always reliable if the endstop is an optical switch.
                                • Enpixaundefined
                                  Enpixa
                                  @bondus
                                  Hi Bondus, thx for your feedback. Yes, in future i will use some kind of gears. For the very first protoype
                                  i wanted the Software/Firmware getting working... later on alle the fine-tuning, rigid mechanics etc.
                                  ********* UPDATE **********
                                  I found this important info in the doku.
                                  Endstop type S0 (active low switch) is no longer supported in M574 commands. Instead, use type S1 and invert the input by prefixing the pin name with '!'. Ex: M574 X1 S1 P"!xstop" I think Jörg also mentioned it somewhere before.
                                  Now is see pressing the X-Endstop with M119 !
                                  Endstops - X: at max stop, Y: not stopped, Z: not stopped, Z probe: at min stop
                                  Yeeehaa ! Thx alot, Video of first time homing:
                                  http://nörds.de/first_time_homing.mp4
                                  Best, Johannes
                                  • Enpixaundefined
                                    Enpixa
                                    How can i tell the Firmware that there is no Z-Endstop and homing for it is not needed:
                                    i tried to set M574 Z0 or removed that Line from config.
                                    G28 Error: G0/G1: insufficient axes homed
                                    The following axis is not homed: Z
                                    bondusundefined 1 Reply Last reply Reply Quote 0
                                    • bondusundefined
                                      bondus @Enpixa
                                      @Enpixa Use G92 Z0
                                      • Enpixaundefined
                                        Enpixa
                                        Hello Jörg, Bondus and DC,
                                        thx for your input. As you suggested i built a small transmission for the steppers. Had to wait for the GT2 belts till today and printed some Gear-Pulleys.
                                        Left Arm on Image is X and right Arm Y.
                                        Working Mode 2, Distance of Rods 70mm, Length of arms 260.5mm and the Degree Defintion of Endstops 128/38
                                        This is the most relevant Line in the config.g:
                                        M669 K9 L2 X0:70 Y0:0 P260.5:260.5 D260.5:260.5 B128:38
                                        Is this as it is meant with the forward direction ? (Also tried for X-arm M569 P0 S0 )
                                        Homing seems to work fine First it moves X arm zu Endstop, then Y arm to Endstop.
                                        home5barscara.g
                                        G1 H1 X-120 F2000 ; move quickly to endstop and stop there (first pass)
                                        G1 H1 Y120 F2000 ; move quickly to endstop and stop there (first pass)
                                        G92 X60
                                        G92 Y60
                                        G92 Z0
                                        G90; abs pos
                                        When trying to drawing a square everything seemes to be rotated by 45° and all Lines are very Curvy (and its not really a square, but that comes later, i hope):
                                        Drawing Square Test ( See Cyan Color on Image )
                                        G90
                                        G1 H1 X0 Y0 F2000
                                        G1 H1 X0 Y60 F2000
                                        G1 H1 X60 Y60 F2000
                                        G1 H1 X60 Y0 F2000
                                        G1 H1 X0 Y0 F2000
                                        Any idea what i am doing wrong with the machine-setup/ config ?
                                        Thx in advance, Johannes
                                        JoergS5undefined bondusundefined 3 Replies Last reply Reply Quote 0
                                        • JoergS5undefined
                                          JoergS5 @Enpixa
                                          This post is deleted!
                                          • bondusundefined
                                            bondus @Enpixa
                                            @Enpixa That "square" looks like the firmware still thinks it is a cartesian printer.
                                            Run your M669 command from config.g on the console to make sure there are not errors.
                                            Edit: Looks like the firmware requires 4 parameters to the "D" option, that's not intended. That's a bug. Just add some 0's and it should be fine.
