Continue blocking during printing.
My Duet controlled machine
529
    Fedekossel1
    Hi guys, lately I've been having some serious problems with my delta, for no reason it stops during the press. I have a version 2.05, and web control 2.07 At first I read a discussion of a user who specified the problem was due to 256 microsteps, I had 256 microsteps so I put 16 microsteps interpolation to 256. But the result has not changed. I always have those blocks, everything stays on even the fans, I can only use the emergency stop button. I also replaced the sd memory with a quality thinking it might be there the problem, Place here my configuration
    ; generated by RepRapFirmware Configuration Tool v2.0.4 on Tue Oct 01 2019 19:52:44 GMT+0200 (hora de verano de Europa central)
    M550 P"kossel" ; set printer name
    M665 R185 L360.27 B150 H365 ; Set delta radius, diagonal rod length, printable radius and homed height
    M666 X0 Y0 Z0 ; put your endstop adjustments here, or let auto calibration find them
    M552 S1 ; enable network
    M586 P0 S1 ; enable HTTP
    M586 P1 S0 ; disable FTP
    M586 P2 S1 ; disable Telnet
    M350 X16 Y16 Z16 I1 ; Configure microstepping with interpolation
    M350 E16 I0 ; Configure microstepping without interpolation
    M92 X160 Y160 Z160 ; Set steps per mm for X,Y and Z
    M92 E830 ; Set steps per mm for Extruder
    M566 X1000.00 Y1000.00 Z1000.00 E900.00 ; set maximum instantaneous speed changes (mm/min)
    M203 X18000.00 Y18000.00 Z18000.00 E1200.00 ; set maximum speeds (mm/min)
    M201 X900.00 Y900.00 Z900.00 E800.00 ; set accelerations (mm/s^2)
    M906 X1700 Y1700 Z1700 E1100 I30 ; set motor currents (mA) and motor idle factor in per cent
    M84 S30 ; Set idle timeout
    M208 Z0 S1 ; set minimum Z
    M574 X2 Y2 Z2 S1 ; set active high endstops
    M558 P8 R0.4 H5 F800 T3000 ; set Z probe type to effector and the dive height + speeds
    G31 P100 X0 Y0 Z-0.21 ; set Z probe trigger value, offset and trigger height
    M557 R120 S20 ; define mesh grid
    M305 P0 T100000 B4092 R4700 ; set thermistor + ADC parameters for heater 0
    M305 P1 T100000 B4725 C7.060000e-8 R4700 ; set thermistor + ADC parameters for heater 1
    M106 P1 S1 I0 F500 H1 T40 ; set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned on
    M106 P2 S0 I0 F500 H-1 ; electronic fan
    Diagnosis command
    M122
    === Diagnostica ===
    RepRapFirmware per Duet 2 WiFi / Ethernet versione 2.05 in esecuzione su Duet WiFi 1.02 o successivo
    ID scheda: 08DGM-9T6BU-FG3SW-6J9FD-3SN6M-TVSZG
    Buffer di output usati: 1 di 24 (15 max)
    = == RTOS ===
    Ram statico: 25712 Ram
    dinamico: 92620 di cui 380
    ram di stack di eccezioni riciclati usati: 448
    Ram mai usati: 11912
    Compiti: NETWORK (pronto, 628) HEAT (bloccato, 1232) MAIN (in esecuzione, 348) IDLE (pronto, 160)
    Mutex di proprietà:
    === Piattaforma ===
    Ultimo ripristino 00:14:21 fa, causa: accensione
    Ultimo ripristino del software al 2020-03-08 12:35, motivo: Utente, modulo di rotazione GCodes, disponibile RAM 11896 byte (slot 3)
    Codice di reimpostazione software 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0441f000 BFAR 0xe000ed38 SP 0xffffffff Task 0x4e49414d
    Stato errore: 10
    voci file libere
    rilevate : 9 Scheda SD 0 rilevata, velocità interfaccia: 20,0 MByte / sec
    tempo di scrittura blocco più lungo: 235 ms 0,7
    Temperatura MCU: min 44,3, corrente 53,0, max 53,2
    Tensione di alimentazione: min 24,5, corrente 24,7, max 24,8, eventi di sottotensione: 0, eventi di sovratensione: 0, alimentazione buona: sì
    Driver 0: fermo, SG min / max 0 / 99
    Driver 1: fermo, SG min / max 0/97
    Driver 2: fermo, SG min / max 0/103
    Driver 3: fermo, SG min / max 0/1023
    Driver 4: fermo, SG min / max non disponibile
    Data / tempo: 2020-03-08 13:26:45
    Conteggio risultati dati cache 2063208117 Ciclo
    più lento: 1256,78 ms; più veloce: 0,07 ms
    errori I2C nak 0, invio timeout 0, ricezione timeout 0, finishTimeout 0, reset 0
    singhiozzo: 363416, FreeDm: 90, MinFreeDm: 84, MaxWait: 306358ms
    Compensazione del letto in uso: nessuna , comp offset 0.000
    === DDARing ===
    Mosse pianificate: 2350, mosse completate: 2310, StepErrors: 0, LaErrors: 0, Underruns: 0, 1
    Riscaldatori del letto = 0 -1 -1 - 1, ChamberHeaters = -1 -1 Il
    riscaldatore 0 è acceso, I-accum = 0,0 Il
    riscaldatore 1 è acceso, I-accum = 0.3
    Segmenti rimasti: 1
    Record stack: 2 allocati, 0 in uso
    Blocco movimento detenuto da null
    http è inattivo negli stati 0
    telnet è inattivo negli stati 0 Il
    file sta eseguendo "G1 X-23.857 Y19.214 E0.0409" in stato (s) 0
    seriale è inattivo in stato (s) 0
    aux è inattivo in stato (s) 0
    demone è inattivo negli stati 0 la
    coda è inattiva negli stati 0 l'
    autopausa è inattiva negli stati 0 La
    coda del codice è vuota.
    === Rete ===
    Ciclo più lento: 1257,00 ms; più veloce: 0,08 ms
    Stati del risponditore: HTTP (0) HTTP (0) HTTP (0) HTTP (0) FTP (0) Telnet (0) Telnet (0)
    Sessioni HTTP: 1 di 8
    WiFi -
    Stato della rete in esecuzione Il
    modulo WiFi è collegato al punto di accesso
    Messaggi non riusciti: in attesa 0, non già 0, noresp 1
    Versione firmware
    WiFi 1.23 Indirizzo MAC WiFi ec: fa: bc: 31: 7e: cd
    WiFi Vcc 3.37, motivo di ripristino Acceso dal processore principale
    Dimensione flash WiFi 4194304, heap gratuito 23296
    Indirizzo IP WiFi 192.168.43.42
    Potenza del segnale WiFi -50dBm, riconnessioni 0, modem in modalità sospensione
    Stati socket: 0 0 0 0 0 0 0 0
    undefined 1 Reply Last reply 11 Mar 2020, 03:43 Reply Quote 0
      Phaedrux Moderator @Fedekossel1
      @Fedekossel1 said in Continue blocking during printing.:
      singhiozzo: 363416
      You still have a high number of hiccups.
      If you send M350 in the gcode console, what does it reply with?
      Why do you have interpolation disabled on the extruder?
      undefined 1 Reply Last reply 11 Mar 2020, 06:30 Reply Quote 0
        Fedekossel1 @Phaedrux
        @Phaedrux I have to give the command M350 Just freezes?
          Power up your printer, then send the M350 command. It will report what microstepping is selected.
          undefined 1 Reply Last reply 11 Mar 2020, 09:53 Reply Quote 0
            Fedekossel1 @dc42
            @dc42 I just did the M350 command. Oddly enough, it gives me this result
            Microstepping - x:256, y:256, z:256, e:16:16
            In my configuration posted above I clearly put 16 interpolated microsteps at 256, excluding extruder that I will now also put at 256 interpolation,
              AndreS
              check your config-override.g
              undefined 1 Reply Last reply 11 Mar 2020, 14:43 Reply Quote 0
                Fedekossel1 @AndreS
                @AndreS
                ; config-override.g file generated in response to M500 at 2020-03-10 10:27
                ; Delta parameters
                M665 L360.270:360.270:360.270 R185.353 H364.129 B150.0 X0.229 Y0.060 Z0.000
                M666 X1.793 Y-1.094 Z-0.699 A0.00 B0.00
                ; Heater model parameters
                M307 H0 A90.0 C700.0 D10.0 S1.00 V0.0 B1
                M307 H1 A340.0 C140.0 D5.5 S1.00 V0.0 B0
                M307 H2 A340.0 C140.0 D5.5 S1.00 V0.0 B0
                M307 H3 A340.0 C140.0 D5.5 S1.00 V0.0 B0
                M307 H4 A340.0 C140.0 D5.5 S1.00 V0.0 B0
                M307 H5 A340.0 C140.0 D5.5 S1.00 V0.0 B0
                M307 H6 A340.0 C140.0 D5.5 S1.00 V0.0 B0
                M307 H7 A340.0 C140.0 D5.5 S1.00 V0.0 B0
                G10 L2 P1 X0.00 Y0.00 Z0.00
                G10 L2 P2 X0.00 Y0.00 Z0.00
                G10 L2 P3 X0.00 Y0.00 Z0.00
                G10 L2 P4 X0.00 Y0.00 Z0.00
                G10 L2 P5 X0.00 Y0.00 Z0.00
                G10 L2 P6 X0.00 Y0.00 Z0.00
                G10 L2 P7 X0.00 Y0.00 Z0.00
                G10 L2 P8 X0.00 Y0.00 Z0.00
                G10 L2 P9 X0.00 Y0.00 Z0.00
                  jay_s_uk
                  @Fedekossel1
                  Try sending
                  M350 X16 Y16 Z16 E16 I1
                  Once the machine has started up. Then resend M350 and make sure it reports back 16 microsteps for each axis.
                  If it does, it means that a file somewhere still has incorrect values for M350, causing the wrong values to be loaded on start up
                  undefined 1 Reply Last reply 11 Mar 2020, 14:59 Reply Quote 0
                    Fedekossel1 @jay_s_uk
                    @jay_s_uk
                    I just tried, I always 256 microsteps, besides the config are in other places the parameters of microsteps?
                    undefined 1 Reply Last reply 11 Mar 2020, 15:28 Reply Quote 0
                      Fedekossel1
                      I found inside config.g.bak all the steps at 256 microsteps, I change them to 16?
                      undefined 1 Reply Last reply 11 Mar 2020, 15:24 Reply Quote 0
                        jay_s_uk @Fedekossel1
                        @Fedekossel1
                        config.g.bak doesn't get loaded at system start up
                          dc42 administrators @Fedekossel1
                          @jay_s_uk
                          That's the problem! Change XYZ to x16 microstepping with interpolation. If your E steps/mm is 400 or above, set that to x16 with interpolation too. If it is less than 400, set E microstepping to x64.
                          undefined 1 Reply Last reply 11 Mar 2020, 18:05 Reply Quote 0
                            Fedekossel1 @dc42
                            I fixed, it's normal that it doesn't tell me giving the command M350 "example" X:16 (on),
                            From config I put
                            Typing the M350 command gives me this result
                            M350
                            Microstepping - X:16, Y:16, Z:16, E:16:16```
                            undefined 1 Reply Last reply 12 Mar 2020, 08:52 Reply Quote 0
                              Fedekossel1
                              I just set all the axes correctly to 16 microsteps interpolated to 256, with the same gcode that froze, now goes without stopping. I keep you updated these days if I get problems or blocks during printing. At the moment I thank everyone!
                                From config I put
                                M350
                                Check that you have entered the I1 parameter correctly. That's letter i followed by digit 1.
                                5 out of 15
