    Rat rig v-core pro COREXYU
    8.2k
      droftarts administrators @neetspeed
      @neetspeed can you answer these questions, please.
      Where did you buy your Duet? And when? Because it looks genuine to me, not a clone.
      Do you actually have a Duex?
      Did you connect the LM2496? If yes, how?
      If the USB port reports too much current draw then something is taking too much 5V or 3.3V power. it cold be the blown U3. or it could be the processor, SD card, WiFi module etc. It may be repairable, by replacing U3, but other components may be damaged.
      A blown U3 is normally a warranty replacement, because it shouldn't happen even if the board is mis-wired. Warranty is 6 months.
      • neetspeedundefined
        neetspeed
        the card is authentic duet
        but I buy them in a new batch, and pack but the warranty is over.
        I will order a new one I think these are the best things to do
          neetspeed
          c order 🙂
            @neetspeed I don’t think you should use the LM2596 like that, it won’t work and may damage the Duet/Duex. If you are trying to feed 12V to all fan pins on Duex, remove the DC converter, and put jumper on 12V enable, highlighted in purple in the diagram you posted earlier. This does make all fans on Duex 12V. It’s missing in your image above.
            If you must use external 12V, see https://duet3d.dozuki.com/Wiki/Connecting_and_configuring_fans#Section_Using_12V_fans_when_VIN_is_24V
            Thanks for your order!
            neetspeedundefined 1 Reply Last reply Reply Quote 0
              neetspeed @droftarts
              @droftarts
              thank you droftarts
              I don't need all 12V output,
              just 2 but if I can pass, the duex5 in 12v,
              I am the kings of petrol to see LEDs afterwards I would have the choice in 24v and 12v
              as it will remain available on the duet2 wifi 🙂
              so it's good, if I understood,
              I forget the jumper to change to 12v or 5v (highlight red) I don't touch it,
              I only connect a jumper on the purple highlight of the schema send?
              well i'm not very lucky yet
              the plateau which goes down and which breaks my paneldue and the duet2 which jumps,
              but we’re going to be positive everything else had great progress
              i will try to focus on the rest of the idex system
              for tool change, mirror mode, and copy,
              and these files to modify, according to my reading
              tfree0
              tpost0
              tpre1
              merci droftarts
              Je n'ai pas besoin de toutes les sorties 12V,
              juste 2 mais si je peux passer, le duex5 en 12v,
              Je suis les rois de l'essence pour voir des LED après j'aurais le choix en 24v et 12v
              car il restera disponible sur le wifi duet2 🙂
              donc c'est bien, si j'ai bien compris,
              J'oublie le cavalier pour passer en 12v ou 5v (surbrillance rouge) je ne le touche pas,
              Je connecte uniquement un cavalier sur le point culminant violet de l'envoi de schéma?
              eh bien je n'ai pas encore beaucoup de chance
              le plateau qui descend et qui casse mon paneldue et le duo2 qui saute,
              mais nous allons être positifs tout le reste a fait de grands progrès
              je vais essayer de me concentrer sur le reste du système idex
              pour le changement d'outil, le mode miroir et la copie,
              et ces fichiers Ă  modifier, selon ma lecture
              tfree0
              tpost0
              tpre1
                neetspeed
                I am stuck on the configuration of the trays,
                I followed the suggestions of dc42, which recommended putting the bed at 0 in the middle,
                but the I advance in my idex configuration and I completely lost myself I think
                I have several problems,
                1 when the tool is changed, it strikes and blocks,
                2 when I choose to print in copy mode, or when changing the tool (when its not blocked) c U which is placed to probe with bltouch while these X BLtouch,
                3 the heating does not activate in mirror mode also only one and the second in standby
                4 my survey g32 freezes at half of Y
                if someone could take a look at my configuration and enlighten me it will be nice
                I attach a photo of the dimensions of my trays
                tpost2.g tpost1.g tpost0.g tfree2.g tfree1.g tfree0.g homez.g homey.g homex.g homeu.g homeall.g config.g bed.g
                Je suis coincé sur la configuration des plateaux,
                J'ai suivi les suggestions de dc42, qui recommandait de mettre le lit Ă  0 au milieu,
                mais je progresse dans ma configuration idex et je me suis complètement perdu, je pense
                J'ai plusieurs problèmes,
                1 lorsque l'outil est changé, il frappe et bloque,
                2 lorsque je choisis d'imprimer en mode copie, ou lorsque je change l'outil (lorsqu'il n'est pas bloqué) c U qui est placé pour sonder avec bltouch alors que ces X BLtouch,
                3 le chauffage ne s'active pas en mode miroir également un seul et le second en veille
                4 mon enquête g32 se bloque à la moitié de Y
                si quelqu'un pouvait jeter un oeil à ma configuration et m'éclairer ce sera sympa
                Je joins une photo des dimensions de mes plateaux
                  dc42 administrators @neetspeed
                  Your fan configuratioj is incorrect. In config.g you have:
                  M106 P1 C"hotend 0" S0 I0 F500 H1 T44               ; set fan 1 name, value, PWM signal inversion and frequency. Thermostatic control is turned on
                  M106 P2 C"hotend 1" S0 I0 F500 H2 T44              ; set fan 2 name, value, PWM signal inversion and frequency. Thermostatic control is turned on
                  M106 P4 C"fan couche 2" S0 I0 F500 H-1          ; set fan 4 name, value, PWM signal inversion and frequency. Thermostatic control is turned off
                  M106 P3 C"fan couche 1" S0 I0 F500 H-1        ; set fan 3 name, value, PWM signal inversion and frequency. Thermostatic control is turned off
                  ; Tools outils
                  M563 P0 S"hotend gauche" D0 H1 F0 F3             ; define tool 1
                  G10 P0 X0 Y0 U0 Z0                                 ; set tool 1 axis offsets
                  G10 P0 R0 S0                                    ; set initial tool 1 active and standby temperatures to 0C
                  M563 P1 S"hotend droit" D1 H2 X3 F1 F4                ; define tool 2
                  G10 P1 X0 Y0 U0 Z0                                 ; set tool 2 axis offsets
                  G10 P1 R0 S0                                    ; set initial tool 2 active and standby temperatures to 0C
                  In your M563 commands you should give the fan number of the print cooling fans only, not the hot end fans. So change them to:
                  M563 P0 S"hotend gauche" D0 H1 F3 ; define tool 1
                  M563 P1 S"hotend droit" D1 H2 X3 F4 ; define tool 2
                  Likewise, your mirror tool should use F3:4 in its M563 command.
                  However, I recommend that you change the fan assignment so that fan 0 is one of the print cooling fans, not a hot end fan. The reason is that if the GCode file has a M106 command with no P parameter, and no tool is selected at that time, the command will be applied to fan 0.
                  @neetspeed said in Rat rig v-core pro COREXYU:
                  Please explain exactly what you mean. Can you post a video of this happening?
                  Again, please clarify what this means.
                  Are you sure that the mirror tool was selected before the heating command was processed?
                  So you mean that the printer stops probing the bed and becomes unresponsive; or something else?
                    neetspeed
                    thank you
                    dsl copy mode not mirror 🙂
                    the truth dc42 I don't understand anything anymore,
                    I set the fan I don't use f0 and my layer fan is the duex5
                    I explain to you and I try to make a video,
                    my biggest problem, already c the bltouch I c not 'I did how
                    but if I print with the right head c she who wants to probe outside she cannot c the left chario (X) which holds the Z probe.
                    then the heating I have a problem impossible to light the 2 at the same time, it is 1 in standby to light.
                    when the copy mode launches alone the chario U moves trying to probe then prints the border alone and after the second chario (x arrives and hits the same if I print with U alone)
                    and the shock of the two nozzles can be a tool change problem I'm still looking for
                    I have this error in the console
                    3/11/2020 at 1:21:14 PM Error: Attempting to extrude with no tool selected.
                    3/11/2020 at 1:21:10 PM T-1
                    Error: Attempting to extrude with no tool selected. )
                    I attach a photo of the temperatures
                    tpre2.g tpre1.g tpre0.g tpost2.g tpost1.g tpost0.g tfree2.g tfree1.g tfree0.g test4log.txt test3log.txt test2log.txt test1log.txt stop.g sleep.g retractprobe.g resume.g pause.g homez.g homey.g homex.g homeu.g homedelta.g homeall.g heightmap.csv deployprobe.g config.g cancel.g bed.g
                      neetspeed
                      https://youtu.be/OFnHSr5YJGY
                      • timcurtis67undefined
                        timcurtis67
                        How is your ditto tool setup in your config.g file?
                        Here is an example of mine for my IDEX printer in my config.g.
                        G10 P2 X50 Y0 U-50 Z0 ; Set tool 2 axis Ditto Printing offsets
                        G10 P2 R0 S0 ; Set initial tool 2 active and standby temp to 0C
                        M576 P2 E1:1 ; Set mix ratio 100% on both extruders
                        So my ditto printer heads print at 100mm apart. My X 0 is at the center of my bed.
                        Yours may be set backwards so the heads try to cross over each other.
                          timcurtis67
                          config.g
                          Here is my config.g file to compare to yours if that helps.
                            neetspeed
                            thank you timcurtis67
                            I look at your files a big thank you to you but I still have a problem with the z probe (bltouch),
                            why the chario U want to probe I don't understand,
                            there are parameters for bltouche probe force on X ??
                              I am looking for little by little.
                            the temperature problem seems to be resolved with your settings
                            can be my tool change file or cura (I am doing my tests with cura)
                            thank you
                              neetspeed
                              I advanced a little and start to see a little clearer but when I choose the tool U it controls the axis X and if asks for a g28 it is u which probes'
                              I have to delete g28 from the slicer I think ??
                              timcurtis67undefined 1 Reply Last reply Reply Quote 0
                                timcurtis67 @neetspeed
                                Yes I don't use G28's in my sliced programs. Once the printer is homed there isn't any reason to home it except for maybe at the end of the program. You can have a G28 Y at the end to send the Y axis home out of the way.
                                • hunterbrightonundefined
                                  hunterbrighton
                                  Hey check out my printer I posted to thingiverse. It is a coreXYU with independent heads and a large print volume running off the duet 2 + duex5. I have included assembly instructions, images and configuration files I hope these can help answer some of your questions.
                                  https://www.thingiverse.com/thing:3705247
                                    neetspeed
                                    hi guys
                                    thank you all for your help,
                                    hunterbrighton I just saw your message and yesterday, coincidence I had already download your files to look at it more closely, and a big thank you to you for your sharing,
                                    but these temp ci, my project is in slow motion, with the covid-19, run the store to recover the food that it can stay for the family the children, we are under military order tomorrow in France almost with compulsory confinement, me resident paris my outings will be very limited 🙂
                                    but little by little the project its advance and at the same time I seek for the mirror mode its occupies us
                                    (for information the covid-19 is not like a flu it is much more violent and more infectious take cough your precaution)
