    Wrong cube calibration 20x20x80
    1.4k
    • chris4undefined
      chris4
      HI again guys, I have a problem that I can't solve. I have cartesian.
      It is Z axis, would calibrate with a cube that is 20x20x20 mm slice with Cura4.5, but it becomes after printing 20x20x80mm 80mm is Z axis. i have Nema 1.8, motor curent 800mA, lead screw M8, 2mm pitch, 1600.00 at x16 microstepping.
      what I'm doing wrong.
      attach the config.h and the Cura file.
      Thanks for the help
      ;FLAVOR:RepRap
      ;TIME:3500
      ;Filament used: 2.41289m
      ;Layer height: 0.1
      ;MINX:109.7
      ;MINY:99.7
      ;MINZ:0.3
      ;MAXX:150.3
      ;MAXY:140.3
      ;MAXZ:25
      ;Generated with Cura_SteamEngine 4.5.0
      T0
      M190 S60
      M104 S200
      M109 S200
      M82 ;absolute extrusion mode
      G21 ;metric values
      G90 ;absolute positioning
      M82 ;set extruder to absolute mode
      M107 ;start with the fan off
      M109 S180 B210 F1;activate auto temp min 180 max 210 scaling factor 1 (for PLA)
      G28; Home Axis
      G1 Z5.0 F9000 ;move the head 5mm up for CYA clearance
      G92 E0 ;zero the extruded length
      G1 X100 Y0 F4000 ; move half way along the front edge
      G1 Z1 ; move nozzle close to bed
      M109 S200 ; heat nozzle to 200 degC and wait until reached
      G4 P10000 ; wait 10 seconds for nozzle length to stabilize
      G1 E10 ; extrude 10 mm of filament
      G1 z15 F12000 E5 ; move 15 mm up, fast, while extruding 5mm
      G92 E0 ; reset extruder
      M117 Printing...;Put printing message on LCD screen
      M141 S28
      M83 ;relative extrusion mode
      G1 F1500 E-6.5
      ;LAYER_COUNT:248
      ;LAYER:0
      M107
      G0 F3600 X111.58 Y102.422 Z0.3
      ;TYPE:SKIRT
      G1 F1500 E6.5
      G1 F1800 X112.123 Y101.849 E0.03938
      G1 X112.722 Y101.334 E0.03941
      G1 X113.37 Y100.883 E0.03939
      G1 X114.061 Y100.499 E0.03944
      G1 X114.786 Y100.187 E0.03938
      G1 X115.539 Y99.95 E0.03938
      G1 X116.313 Y99.791 E0.03942
      G1 X117.098 Y99.71 E0.03937
      G1 X142.5 Y99.7 E1.26731
      G1 X143.289 Y99.74 E0.03941
      ; generated by RepRapFirmware Configuration Tool v2.1.8 on Sat Mar 07 2020 00:00:28 GMT+0100 (centraleuropeisk normaltid)
      G90                                     ; send absolute coordinates...
      M83                                     ; ...but relative extruder moves
      M550 P"My Printer"                      ; set printer name
      M552 S1                                 ; enable network
      M586 P0 S1                              ; enable HTTP
      M586 P1 S0                              ; disable FTP
      M586 P2 S0                              ; disable Telnet
      M569 P0 S1                              ; physical drive 0 goes forwards
      M569 P1 S1                              ; physical drive 1 goes forwards
      M569 P2 S0                              ; physical drive 2 goes backwards
      M569 P3 S0                              ; physical drive 3 goes backwards
      M584 X0 Y1 Z2 E3                        ; set drive mapping
      M350 X16 Y16 Z16 E16 I1                 ; configure microstepping with interpolation
      M92 X160.00 Y160.00 Z1600.00 E837.08     ; set steps per mm
      M566 X900.00 Y900.00 Z12.00 E120.00     ; set maximum instantaneous speed changes (mm/min)
      M201 X500.00 Y500.00 Z20.00 E250.00     ; set accelerations (mm/s^2)
      M906 X800 Y800 Z800 E800 I30            ; set motor currents (mA) and motor idle factor in per cent
      M84 S30                                 ; Set idle timeout
      M208 X0 Y0 Z0 S1                        ; set axis minima
      M208 X260 Y240 Z240 S0                  ; set axis maxima
      M574 X1 Y1 Z1 S1                        ; set active low and disabled endstops
      M558 P0 H5 F120 T6000                   ; disable Z probe but set dive height, probe speed and travel speed
      M557 X15:215 Y15:195 S20                ; define mesh grid
      M305 P0 T100000 B4138 R4700             ; set thermistor + ADC parameters for heater 0
      M143 H0 S120                            ; set temperature limit for heater 0 to 120C
      M305 P1 T100000 B4138 R4700             ; set thermistor + ADC parameters for heater 1
      M143 H1 S280                            ; set temperature limit for heater 1 to 280C
      M106 P0 S0 I0 F500 H-1                  ; set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned off
      M106 P1 S1 I0 F500 H1 T45               ; set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned on
      M563 P0 D0 S"TitanAero" H1 F0           ; define tool 0
      G10 P0 X0 Y0 Z0                         ; set tool 0 axis offsets
      G10 P0 R0 S0                            ; set initial tool 0 active and standby temperatures to 0C
        droftarts administrators @chris4
        @chris4 I’d guess you’ve actually got 4-start, 8mm pitch leadscrew. Doesn’t really matter, just set M92 Z400.
        chris4undefined 1 Reply Last reply Reply Quote 0
        • chris4undefined
          chris4 @droftarts
          @droftarts said in Wrong cube calibration 20x20x80:
          Thanks ,
          have tried with the M92 Z400 it too but it will be the same height on the Z axis.
            dc42 administrators @chris4
            @chris4 said in Wrong cube calibration 20x20x80:
            Thanks ,
            Send M92 without parameters and check that the Z parameter it reports matches the value you have set it to. Changing the Z steps/mm from 1600 to 400 cannot fail to reduce the Z height by a factor of 4.
            • chris4undefined
              chris4
              @dc42 said in Wrong cube calibration 20x20x80:
              Should now try M92 without parameters in config.h
              • chris4undefined
                chris4
                Homing failed without M92 parameters on config.h file, have tried to send M92 on G code but nothing happens
                • chris4undefined
                  chris4
                  noticed that when I move Z axis +0,5 =2mm, +5 = 20mm, +25 = 100mm up is it correct?
                  • aidarundefined
                    aidar
                    Your M92 command in config.g file should looks like this M92 X160.00 Y160.00 Z400.00 E837.08
                    • chris4undefined
                      chris4
                      Have tried it with M92 X160.00 Y160.00 Z1600.00 E837.08,
                      aidarundefined 1 Reply Last reply Reply Quote 0
                        No, send M92 without parameters from the console. It will report the current M92 settings. Use this to check that the value that you think you have set in config.g is the value being used by the firmware.
                        • aidarundefined
                          aidar @chris4
                          It is same, if your Z value is 1600. You should change it to 400.
                          • chris4undefined
                            chris4 @dc42
                            The answer from the console :
                            M92
                            Steps/mm: X: 160.000, Y: 160.000, Z: 1600.000, E: 837.080
                            And from config.h
                            M92 X160.00 Y160.00 Z1600 E837.08 ; set steps per mm
                              Change your config.g
                              M92 Z1600 should be M92 Z400
                                droftarts administrators @Phaedrux
                                @Phaedrux that’s six times now we’ve told him to change Z1600 to Z400!
                                Phaedruxundefined chris4undefined 3 Replies Last reply Reply Quote 0
                                  Phaedrux Moderator @droftarts
                                  @droftarts Ten if you count the times I've shouted it at the screen. 😛
                                  • chris4undefined
                                    chris4 @droftarts
                                    @droftarts
                                    • chris4undefined
                                      chris4 @droftarts
                                      @droftarts
                                      • chris4undefined
                                        chris4 @Phaedrux
                                        @Phaedrux
                                        • aidarundefined
                                          aidar
                                          How have you "tried" this? Have you changed your config file? Btw its config.g, not config.h
                                            deckingman @aidar
                                            @aidar said in Wrong cube calibration 20x20x80:
                                            @chris4 Repeat - Change the M92 in CONFIG.G from 1600 to 400
