    Another Predator
    204
    14.9k
    • Carloundefined
      Carlo @dc42
      No just unplugged and it has stopped plugged back in and not flashing that must be a poor connection on the fan?
      I'll change it now to fair I have had this apart once or twice.
      Sorry I've changed my setting back to 2.0.5 could someone please have quick check of my configs as I've homed again and it's showing homed height way off but end stops fine,
      Also Heater 1 is missing so figure I've missed something though it works
      ; generated by RepRapFirmware Configuration Tool v2 on Tue Feb 26 2019 21:31:01 GMT+0000 (Greenwich Mean Time)
      ; Delta Settings
      M665 L440.470:440.470:440.470 R232.088 H420.498 B185.0 X0.237 Y-0.015 Z0.000 ; Set delta radius, diagonal rod length, printable radius and homed height
      M666 X-0.09 Y0.10 Z-0.01 A0.00 B0.00 ; Put your endstop adjustments here, or let auto calibration find them
      M550 P"Street Predator" ; Set machine name
      M551 P"" ; Set password
      M552 P192.168.0.25 S1 ; Enable network and acquire dynamic address via DHCP
      M586 P0 S1 ; Enable HTTP
      M586 P1 S0 ; Disable FTP
      M586 P2 S0 ; Disable Telnet
      M569 P3 S0 ; Drive 3 goes backwards
      M584 X0 Y1 Z2 E3:4:1.0:1.1
      M92 X80.00 Y80.00 Z80.00 E867 ; Set steps per mm
      M566 X3000 Y3000 Z3000 E40 ; Set maximum instantaneous speed changes (mm/min)
      M203 X12000.00 Y12000.00 Z12000.00 E446 ; Set maximum speeds (mm/min)
      M201 X9000.00 Y9000.00 Z9000.00 E9000.00 ; Set accelerations (mm/s^2)
      M906 X1000.00 Y1000.00 Z1000.00 E1000.00 I30 ; Set motor currents (mA) and motor idle factor in per cent
      M84 S30 ; Set idle timeout
      ; Retraction
      M207 S0.4 F1200 R0.1 T1200 Z0.2 ; Firmware retraction
      M208 Z0 S1 ; Set minimum Z
      M574 X1 Y1 Z1 U1 S1 ; active high endstop switches, XYZ U at max
      M558 P8 R0.4 F1200 H20 T2000 C"zprobe.in+zprobe.mod" ; Set Z probe type to switch and the dive height + speeds
      G31 P100 X0 Y0 Z-0.05 ; Set Z probe trigger value, offset and trigger height
      M557 R135 S16 ; Define mesh grid
      ;Heated bed
      M305 P0 T100000 B3950 ; bed heater uses a B3950 thermistor ; Disable bang-bang mode for the bed heater and set PWM limit
      M143 P0 S125 ; Set temperature limit for heater 0 to 120C
      ;Hotend
      M305 P1 S"T0" X200 R395 W2 ; configure sensor 1 as PT100 on daughter board
      M143 P1 S400 ; set temperature limit for heater 1 to 400C
      M307 P1 B0 S1.00
      M950 F0 Cfan0 Q500 ; create fan 0 on pin fan0 and set its frequency
      M950 F1 Cfan1 Q500 ; create fan 1 on pin fan1 and set its frequency
      M563 P0 D0 H1 ; Define tool 0
      M591 P3 C3 S1 ; filament monitor connected to E0_stop
      M404 N1.75 D0.4 ; Set for print monitor
      M501 ; Load saved parameters from non-volatile memory
      ; config-override.g file generated in response to M500 at 2020-03-15 13:17
      ; Delta parameters
      M665 L440.470:440.470:440.470 R232.163 H421.126 B185.0 X0.095 Y0.043 Z0.000
      M666 X-2.720 Y-0.764 Z3.484 A0.00 B0.00
      ; Heater model parameters
      M307 H0 A113.4 C472.3 D0.6 S1.00 V23.8 B0
      M307 H1 A655.5 C296.8 D4.5 S1.00 V24.0 B0
      M307 H2 A340.0 C140.0 D5.5 S1.00 V0.0 B0
      M307 H3 A340.0 C140.0 D5.5 S1.00 V0.0 B0
      M307 H4 A340.0 C140.0 D5.5 S1.00 V0.0 B0
      M307 H5 A340.0 C140.0 D5.5 S1.00 V0.0 B0
      M307 H6 A340.0 C140.0 D5.5 S1.00 V0.0 B0
      M307 H7 A340.0 C140.0 D5.5 S1.00 V0.0 B0
      G10 L2 P1 X0.00 Y0.00 Z0.00
      G10 L2 P2 X0.00 Y0.00 Z0.00
      G10 L2 P3 X0.00 Y0.00 Z0.00
      G10 L2 P4 X0.00 Y0.00 Z0.00
      G10 L2 P5 X0.00 Y0.00 Z0.00
      G10 L2 P6 X0.00 Y0.00 Z0.00
      G10 L2 P7 X0.00 Y0.00 Z0.00
      G10 L2 P8 X0.00 Y0.00 Z0.00
      G10 L2 P9 X0.00 Y0.00 Z0.00
        The config files between 2.x and 3.x are not compatible. If you want to switch back to 2.x you'll have to use a backup of your config file, or if you don't have one, you might have to recreate one using the web configurator tool.
        Carloundefined 1 Reply Last reply Reply Quote 0
        • Carloundefined
          Carlo @Phaedrux
          @Phaedrux
          I have switched the settings back all seems to be working except I get a homed error as per the picture above
          and the Heater 1 is missing so I can't activate or switch off via it.
          Actually the homed error is only if I M500 and have a config overide file if I delete that it shows what I assume is correct home height.
          Thanks for your help.
            Your config still has a lot of commands specific to 3.0.
            In the gcode console send M98 Pconfig.g and report back with any errors that come up.
            • Carloundefined
              Carlo @Phaedrux
              @Phaedrux
              It reported 2 fan command not supported which I corrected with M106 now only no config override but I deleted it.
                What do you mean by heater1 is missing?
                • Carloundefined
                  Carlo @Phaedrux
                  @Phaedrux
                  If you look at the above screen shot its missing Heater 1 from Tools .
                  Thanks
                    Phaedrux Moderator @Carlo
                    @Carlo said in Another Predator:
                    ;Hotend
                    Your R value looks to be missing a 0.
                    • Carloundefined
                      Carlo @Phaedrux
                      @Phaedrux
                      it's a PT100 if I add a 0 it shows 2000c
                      Thanks
                        You can remove the R value entirely. The Duet knows what resistor value it's using.
                        • Carloundefined
                          Carlo @Phaedrux
                          @Phaedrux
                          Thanks I've removed the R value.
                          The temps have always been correct as they both show very similar values at room temp I just can't switch the hotend off via Tool0 only to standby and active.
                          I think I'll redo the configs from scratch as you suggested.
                          • Carloundefined
                            Carlo
                            So regenerated the files via on-line tool this did fix the Heater 1 missing but not the homed height or endstops being way off also can't move any axis once homed without:
                            M120 G91 G1 Z-50 F3000 G90 M121
                            Error: G0/G1: target position not reachable from current position.
                            Had this before new files were uploaded if I delete config override it shows correct height.
                            Config override below
                            ; config-override.g file generated in response to M500 at 2020-03-15 20:01
                            ; Delta parameters
                            M665 L440.470:440.470:440.470 R231.558 H420.618 B185.0 X-0.122 Y-0.159 Z0.000
                            M666 X0.100 Y-1.507 Z1.407 A0.00 B0.00
                            M307 H0 A90.0 C700.0 D10.0 S1.00 V0.0 B0
                            M307 H1 A340.0 C140.0 D5.5 S1.00 V0.0 B0
                              what's in your homedelta now?
                              Carloundefined 2 Replies Last reply Reply Quote 0
                              • Carloundefined
                                Carlo @Phaedrux
                                @Phaedrux
                                As below thanks for the help I am completely new to reprap and get I must be doing something wrong but I follow the Docs online.
                                ; homedelta.g
                                ; called to home all towers on a delta printer
                                ; generated by RepRapFirmware Configuration Tool v2.1.8 on Sun Mar 15 2020 19:14:10 GMT+0000 (Greenwich Mean Time)
                                G91 ; relative positioning
                                ;*** Slow homing has been configured. Change F180 to F1800 below when your configuration is working
                                G1 H1 X450 Y450 Z450 F1800 ; move all towers to the high end stopping at the endstops (first pass)
                                ;G1 H2 X-5 Y-5 Z-5 F1800 ; go down a few mm
                                ;*** Slow homing has been configured. Change F180 to F360 below when your configuration is working
                                ;G1 H1 X10 Y10 Z10 F180 ; move all towers up once more (second pass)
                                ;G1 Z-5 F6000 ; move down a few mm so that the nozzle can be centred
                                G90 ; absolute positioning
                                ;G1 X0 Y0 F6000 ; move X+Y to the centre
                                • Carloundefined
                                  Carlo @Phaedrux
                                  @Phaedrux
                                  Is there anything in the home file to suggest why my machine is homing at twice the actual height ?
                                  I did think it was because of the config override but it's not as it's deleted and still appears to do it without one
                                  As soon as I hit emergency stop it returns to the correct height if that help until I try to print or delta calibrate and return to home
                                  Also setting the probe height to 0.05 means it can't extrude as it's to close to the bed I'm experimenting with the heights some more ..though it leaves a nice keyed surface for when I eventually get it to print a layer(that's a joke by the way)! keeping it lite hearted and all that.
                                    Nothing that I can see or understand given my rudimentary experience with deltas. All I can suggest is to go through this very carefully. It holds the key to your success:
                                    https://duet3d.dozuki.com/Wiki/Calibrating_a_delta_printer
                                    • Carloundefined
                                      Carlo @Phaedrux
                                      @Phaedrux
                                      Cheers that's my bible.
                                      Actually a new board holds my success!
                                      OK does anyone know what would cause it in a Cartesian or XY ?
                                      • Carloundefined
                                        Carlo @Phaedrux
                                        @Phaedrux
                                        Sorry just so I understand where you've confirmed it's a calibration error why are you directing me to the Calibrating a delta printer wiki as I've stated I use the documentation to setup always..so I guess I'm asking where in that document does it answer the issues I'm having as I am constantly using those very pages to try to resolve my issues with no success as in no change what so ever.
                                        Is it possible to have a faulty board with no error showing as in nothing on the board because I follow the guides and all appears to work as expected until I try to print and then it does not know where it is in relation to the bed
                                        because if it is possible I won't waste any more of your time on it.
                                        And yes not keeping it light hearted but I've followed every suggestion made here and no change and it's a little frustrating.
                                        Cheers
                                          I'm inclined to think it's mechanical or a configuration error. It almost always ends up being mechanical in some way. Something loose, cracked, stripped, shifted, binding, skipping, etc. And when it's not, it's a config error of some kind.
                                          The G1/G0 error you're getting reminds me of a recent thread. See here: https://forum.duet3d.com/topic/14821/error-g0-g1?_=1584397103870
                                          I think that may be your solution to that issue.
                                          • Carloundefined
                                            Carlo @Phaedrux
                                            @Phaedrux
                                            I’m not running slicer software this is homing when switching machine on or after trying to print with no start commands in slicer Or if I try to calibrate,
                                            I’ll try G28 in my home file ?
                                            Rather than G1 commands
                                            I do get a G1 error when trying to move -Z from home when the home height is wrong and have to reset to obtain the correct ish height but I can’t calibrate when the height is wrong also the endstops show as 10mm ish + or - when height is wrong
                                            Cheers
