    Another Predator
    204
    14.7k
      Your config still has a lot of commands specific to 3.0.
      In the gcode console send M98 Pconfig.g and report back with any errors that come up.
      Carloundefined 1 Reply Last reply Reply Quote 0
      • Carloundefined
        Carlo @Phaedrux
        @Phaedrux
        It reported 2 fan command not supported which I corrected with M106 now only no config override but I deleted it.
        Thanks for your help
          What do you mean by heater1 is missing?
          • Carloundefined
            Carlo @Phaedrux
            @Phaedrux
            If you look at the above screen shot its missing Heater 1 from Tools .
            Thanks
              Phaedrux Moderator @Carlo
              @Carlo said in Another Predator:
              ;Hotend
              M305 P1 S"T0" X200 R395 W2 ; configure sensor 1 as PT100 on daughter board
              Your R value looks to be missing a 0.
              • Carloundefined
                Carlo @Phaedrux
                @Phaedrux
                it's a PT100 if I add a 0 it shows 2000c
                Thanks
                  You can remove the R value entirely. The Duet knows what resistor value it's using.
                  • Carloundefined
                    Carlo @Phaedrux
                    @Phaedrux
                    Thanks I've removed the R value.
                    The temps have always been correct as they both show very similar values at room temp I just can't switch the hotend off via Tool0 only to standby and active.
                    I think I'll redo the configs from scratch as you suggested.
                    Thanks for your help.
                    • Carloundefined
                      Carlo
                      So regenerated the files via on-line tool this did fix the Heater 1 missing but not the homed height or endstops being way off also can't move any axis once homed without:
                      M120 G91 G1 Z-50 F3000 G90 M121
                      Error: G0/G1: target position not reachable from current position.
                      Had this before new files were uploaded if I delete config override it shows correct height.
                      Config override below
                      ; config-override.g file generated in response to M500 at 2020-03-15 20:01
                      ; Delta parameters
                      M665 L440.470:440.470:440.470 R231.558 H420.618 B185.0 X-0.122 Y-0.159 Z0.000
                      M666 X0.100 Y-1.507 Z1.407 A0.00 B0.00
                      ; Heater model parameters
                      M307 H0 A90.0 C700.0 D10.0 S1.00 V0.0 B0
                      M307 H1 A340.0 C140.0 D5.5 S1.00 V0.0 B0
                      M307 H2 A340.0 C140.0 D5.5 S1.00 V0.0 B0
                      M307 H3 A340.0 C140.0 D5.5 S1.00 V0.0 B0
                      M307 H4 A340.0 C140.0 D5.5 S1.00 V0.0 B0
                      M307 H5 A340.0 C140.0 D5.5 S1.00 V0.0 B0
                      M307 H6 A340.0 C140.0 D5.5 S1.00 V0.0 B0
                      M307 H7 A340.0 C140.0 D5.5 S1.00 V0.0 B0
                      G10 L2 P1 X0.00 Y0.00 Z0.00
                      G10 L2 P2 X0.00 Y0.00 Z0.00
                      G10 L2 P3 X0.00 Y0.00 Z0.00
                      G10 L2 P4 X0.00 Y0.00 Z0.00
                      G10 L2 P5 X0.00 Y0.00 Z0.00
                      G10 L2 P6 X0.00 Y0.00 Z0.00
                      G10 L2 P7 X0.00 Y0.00 Z0.00
                      G10 L2 P8 X0.00 Y0.00 Z0.00
                      G10 L2 P9 X0.00 Y0.00 Z0.00
                        what's in your homedelta now?
                        Carloundefined 2 Replies Last reply Reply Quote 0
                        • Carloundefined
                          Carlo @Phaedrux
                          @Phaedrux
                          As below thanks for the help I am completely new to reprap and get I must be doing something wrong but I follow the Docs online.
                          ; homedelta.g
                          ; called to home all towers on a delta printer
                          ; generated by RepRapFirmware Configuration Tool v2.1.8 on Sun Mar 15 2020 19:14:10 GMT+0000 (Greenwich Mean Time)
                          G91 ; relative positioning
                          ;*** Slow homing has been configured. Change F180 to F1800 below when your configuration is working
                          G1 H1 X450 Y450 Z450 F1800 ; move all towers to the high end stopping at the endstops (first pass)
                          ;G1 H2 X-5 Y-5 Z-5 F1800 ; go down a few mm
                          ;*** Slow homing has been configured. Change F180 to F360 below when your configuration is working
                          ;G1 H1 X10 Y10 Z10 F180 ; move all towers up once more (second pass)
                          ;G1 Z-5 F6000 ; move down a few mm so that the nozzle can be centred
                          G90 ; absolute positioning
                          ;G1 X0 Y0 F6000 ; move X+Y to the centre
                          • Carloundefined
                            Carlo @Phaedrux
                            @Phaedrux
                            Is there anything in the home file to suggest why my machine is homing at twice the actual height ?
                            I did think it was because of the config override but it's not as it's deleted and still appears to do it without one
                            As soon as I hit emergency stop it returns to the correct height if that help until I try to print or delta calibrate and return to home
                            Also setting the probe height to 0.05 means it can't extrude as it's to close to the bed I'm experimenting with the heights some more ..though it leaves a nice keyed surface for when I eventually get it to print a layer(that's a joke by the way)! keeping it lite hearted and all that.
                              Nothing that I can see or understand given my rudimentary experience with deltas. All I can suggest is to go through this very carefully. It holds the key to your success:
                              https://duet3d.dozuki.com/Wiki/Calibrating_a_delta_printer
                              • Carloundefined
                                Carlo @Phaedrux
                                @Phaedrux
                                Cheers that's my bible.
                                Actually a new board holds my success!
                                OK does anyone know what would cause it in a Cartesian or XY ?
                                • Carloundefined
                                  Carlo @Phaedrux
                                  @Phaedrux
                                  Sorry just so I understand where you've confirmed it's a calibration error why are you directing me to the Calibrating a delta printer wiki as I've stated I use the documentation to setup always..so I guess I'm asking where in that document does it answer the issues I'm having as I am constantly using those very pages to try to resolve my issues with no success as in no change what so ever.
                                  Is it possible to have a faulty board with no error showing as in nothing on the board because I follow the guides and all appears to work as expected until I try to print and then it does not know where it is in relation to the bed
                                  because if it is possible I won't waste any more of your time on it.
                                  And yes not keeping it light hearted but I've followed every suggestion made here and no change and it's a little frustrating.
                                  Cheers
                                    I'm inclined to think it's mechanical or a configuration error. It almost always ends up being mechanical in some way. Something loose, cracked, stripped, shifted, binding, skipping, etc. And when it's not, it's a config error of some kind.
                                    The G1/G0 error you're getting reminds me of a recent thread. See here: https://forum.duet3d.com/topic/14821/error-g0-g1?_=1584397103870
                                    I think that may be your solution to that issue.
                                    • Carloundefined
                                      Carlo @Phaedrux
                                      @Phaedrux
                                      I’m not running slicer software this is homing when switching machine on or after trying to print with no start commands in slicer Or if I try to calibrate,
                                      I’ll try G28 in my home file ?
                                      Rather than G1 commands
                                      I do get a G1 error when trying to move -Z from home when the home height is wrong and have to reset to obtain the correct ish height but I can’t calibrate when the height is wrong also the endstops show as 10mm ish + or - when height is wrong
                                      Cheers
                                        Any delta gurus wanna take another crack at this one? @Danal @jay_s_uk @droftarts
                                        • Danalundefined
                                          Danal
                                          Sure, let me read the thread a little. And take a look at this suddenly popular printer.
                                          Meanwhile, @Carlo, I know you've posted a lot of stuff... but would you mind posting your current config.g and homedelta.g, one more time? And I see you've been on V3 and V2 of the software, which is loaded at this moment? (M122 will tell you).
                                          • Carloundefined
                                            Carlo @Danal
                                            @Danal
                                            Thanks Phaedrux
                                            Hi Danal,
                                            Appreciate you having a look,
                                            FIRMWARE_NAME: RepRapFirmware for Duet 2 WiFi/Ethernet FIRMWARE_VERSION: 2.05 ELECTRONICS: Duet Ethernet 1.02 or later FIRMWARE_DATE: 2019-12-13b1
                                            M550 P"Street Predator" ; set printer name
                                            M665 L440.470:440.470:440.470 R232.245 H422.803 B185.0 X-0.054 Y-0.244 Z0.000
                                            M666 X-0.263 Y0.223 Z0.040 A0.00 B0.00
                                            M551 P"" ; set password
                                            M552 P192.168.0.25 S1 ; Enable network
                                            M586 P0 S1 ; enable HTTP
                                            M586 P1 S0 ; disable FTP
                                            M586 P2 S0 ; disable Telnet
                                            M92 X80.00 Y80.00 Z80.00 E867.00 ; set steps per mm
                                            M566 X1200.00 Y1200.00 Z1200.00 E1200.00 ; set maximum instantaneous speed changes (mm/min)
                                            M203 X18000.00 Y18000.00 Z18000.00 E1200.00 ; set maximum speeds (mm/min)
                                            M201 X1000.00 Y1000.00 Z1000.00 E1000.00 ; set accelerations (mm/s^2)
                                            M906 X1000 Y1000 Z1000 E800 I30 ; set motor currents (mA) and motor idle factor in per cent
                                            M84 S30 ; Set idle timeout
                                            M208 Z0 S1 ; set minimum Z
                                            M574 X1 Y1 Z1 S1 ; set active high endstops
                                            M558 P5 R0.4 H5 F1200 T6000 ; set Z probe type to effector and the dive height + speeds
                                            M558 H30 ;*** Remove this line after delta calibration has been done and new delta parameters have been saved
                                            G31 P100 X0 Y0 Z-0.08 ; set Z probe trigger value, offset and trigger height
                                            M557 R175 S20 ; define mesh grid
                                            M305 P0 T100000 B3950 R4700 ; set thermistor + ADC parameters for heater 0
                                            M305 P1 X200 ; configure PT100 for heater 1
                                            M143 H1 S400 ; set temperature limit for heater 1 to 400C
                                            ; homedelta.g
                                            3/16/2020, 11:42:51 PM M122
                                            RepRapFirmware for Duet 2 WiFi/Ethernet version 2.05 running on Duet Ethernet 1.02 or later
                                            Board ID: 08DGM-917DA-G4MSJ-6J1FJ-3S86N-TBN3A
                                            Used output buffers: 3 of 24 (8 max)
                                            Static ram: 25712
                                            Dynamic ram: 92244 of which 380 recycled
                                            Exception stack ram used: 272
                                            Never used ram: 12464
                                            Tasks: NETWORK(ready,628) HEAT(blocked,1176) MAIN(running,3728) IDLE(ready,160)
                                            Owned mutexes:
                                            Last reset 00:06:01 ago, cause: power up
                                            Last software reset at 2020-03-16 19:20, reason: User, spinning module GCodes, available RAM 12304 bytes (slot 0)
                                            Error status: 0
                                            Free file entries: 10
                                            MCU temperature: min 32.5, current 38.0, max 38.2
                                            Supply voltage: min 24.1, current 24.1, max 24.2, under voltage events: 0, over voltage events: 0, power good: yes
                                            Date/time: 2020-03-16 23:42:50
                                            Cache data hit count 703568711
                                            Slowest loop: 10.47ms; fastest: 0.07ms
                                            Hiccups: 0, FreeDm: 160, MinFreeDm: 160, MaxWait: 0ms
                                            === DDARing ===
                                            Segments left: 0
                                            Movement lock held by null
                                            http is idle in state(s) 0
                                            telnet is idle in state(s) 0
                                            file is idle in state(s) 0
                                            serial is idle in state(s) 0
                                            aux is idle in state(s) 0
                                            daemon is idle in state(s) 0
                                            queue is idle in state(s) 0
                                            Code queue is empty.
                                            === Network ===
                                            Slowest loop: 30.44ms; fastest: 0.02ms
                                            HTTP sessions: 1 of 8
                                            Interface state 5, link 100Mbps full duplex
                                            3/16/2020, 11:41:17 PM M115
                                            Thanks
